customize screen
Common discussion area
customize screen
rezabeigi » 14 апр 2012, 10:17
hi please describe how we can change screen layout to data chart and other indicator ..i tghink that is some complicated . thanks cail
Re: customize screen
cail » 14 апр 2012, 12:49
rezabeigi, setup and configuration of concrete sensor view is quite simpe (via "configure UI" mode).
But if you want to setup your own screens - this is now only possible with manual configuration files edit and can be considered quite difficult.
Working on some helpers to make this easier.
rezabeigi » 14 апр 2012, 13:44
ok would you train me how can i change ui configoration when ever i try to change screen layout in setting i change widget but that is not effective . has this any user manual for change correct?
thanks cail
cail » 14 апр 2012, 13:49
with demo version you can change only two widgets: RPM and fuel level.
All others are just plain in demo.
I'll post some insturctions on how to do lowlevel layout configuration later.
rezabeigi » 14 апр 2012, 14:13
thanks my freind
WuMeiGuang » 15 апр 2012, 07:25
I'll be waiting that instructions also Cail, thanks :lol:
cail писал(а):with demo version you can change only two widgets: RPM and fuel level.
Go HobDrive Go !
cail » 16 апр 2012, 10:14
Here is a draft: viewtopic.php?f=11&t=136
you can ask more in that thread - I'll help with answers as much as I can.
