customize screen
customize screen
hi please describe how we can change screen layout to data chart and other indicator ..i tghink that is some complicated . thanks cail
Re: customize screen
rezabeigi, setup and configuration of concrete sensor view is quite simpe (via "configure UI" mode).
But if you want to setup your own screens - this is now only possible with manual configuration files edit and can be considered quite difficult.
Working on some helpers to make this easier.
ok would you train me how can i change ui configoration when ever i try to change screen layout in setting i change widget but that is not effective . has this any user manual for change correct?
thanks cail
thanks cail
with demo version you can change only two widgets: RPM and fuel level.
All others are just plain in demo.
I'll post some insturctions on how to do lowlevel layout configuration later.
thanks my freind
I'll be waiting that instructions also Cail, thanks
cail писал(а):with demo version you can change only two widgets: RPM and fuel level.
Go HobDrive Go !
Here is a draft: viewtopic.php?f=11&t=136
you can ask more in that thread - I'll help with answers as much as I can.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 10
