ิีBUG on shift position
Добавлено: 14 сен 2015, 04:42
Hi, I currently use it is much better hobdrive 1.2.7. Since version 1.2.8, but I find is to find bug display gear position is that it will show the gear does not match. That put ratio similar to that put in all respects 1.2.7 and 1.2.12 is the latest experimental results also show the same.
