PC version: is Bluesoleil supported?
Common discussion area
Byrd » 08 июн 2013, 05:06
Hi,
I posted on here some months back about getting a Win CE 6.0 Chinese GPS running with Hobdrive, but gave up as the OS was so severely stripped and refused to work with a USB or BT OBDII adapter.
Now it's been hacked with a HDMI screen, carPC and Centrafuse car front end software (running Bluesoleil stack for GPS) :) Fired up the Windows version of Hobdrive ... it doesn't detect any BT drivers.
Should Bluesoleil work with hobd?
Thanks
JB
Re: PC version: is Bluesoleil supported?
cail » 20 июн 2013, 08:48
Hi Byrd,
Probably not directly.
But you always can manually assign ELM device with a COM port number, and use that port in hobdrive to connect.
That should be supported with any BT stack.
Byrd » 16 ноя 2013, 13:46
Hi,
I'm still having no luck with Bluesoleil and HobDrive. I'm successful with a USB OBD2 adapter, but can't get BlueSoleil 10 + reasonable quality BT USB adapter (+ OBD2 dongle) to connect.
Using EasyOBD2 as a test, I can confirm COM6 and baud 38400 works using the above setup. Hobdrive detects this as COM6:38400 in hobdrive's OBD2 setup. I've tried every combination of baud rate, etc. but to no avail - it simply doesn't register with Hobdrive.
cail, any tips?
JB
cail » 16 ноя 2013, 18:57
Byrd,
Its abit ambiguous - are you able to connect via mapped com port? with BT COM ports you normally don't have to choose any specific speed.
