Ivan_DN » 30 мар 2018, 15:00
Здравствуйте Eml327 перестал подключаться к ЭБУ, подскажите это аппаратная ошибка или программная?
Авто Деу Сенс 2003г
Лог файл выдает:
[ERROR] 30.03.2018 11:10:28.566[ECUXMLSensorProvider] Sensor is null: MIL
[ERROR] 30.03.2018 11:10:28.567[ECUXMLSensorProvider] Sensor is null: PMIL
[TRACE] 30.03.2018 11:10:28.589[HOBD] RegisterProvider: hobd.CommonSensors
[TRACE] 30.03.2018 11:10:28.606[HOBD] RegisterProvider: hobd.GPSSensorProvider
[TRACE] 30.03.2018 11:10:28.610[HOBD] RegisterProvider: hobd.MiscSensorsProvider
[TRACE] 30.03.2018 11:10:28.614[HOBD] RegisterProvider: hobd.FuelType_Petrol_Provider
[TRACE] 30.03.2018 11:10:28.621[HOBD] RegisterProvider: hobd.FilteredFPHProvider
[TRACE] 30.03.2018 11:10:28.622[HOBD] RegisterProvider: hobd.StatsSensorProvider
[TRACE] 30.03.2018 11:10:28.623[HOBD] RegisterProvider: hobd.FuelTrackingProvider
INIT: FB ERROR[INFO] 30.03.2018 11:10:32.373[OBD2Engine] Sensor Init:BUS INIT: FB ERROR[TRACE] 30.03.2018 11:10:32.373[OBD2Engine] -> QUERY_PROTOCOL
[ERROR] 30.03.2018 11:10:32.824[DerivedSensor] Micas76.Speed a:Core b: Value_get exception
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at hobd.ECUXMLSensorProvider+<>c__DisplayClass32.<ReadConfig>b__1a (Sensor a, Sensor b) [0x00000] in <filename unknown>:0
at hobd.DerivedSensor.get_Value () [0x000b1] in <filename unknown>:0
kdika » 30 мар 2018, 17:06
Аппаратная
FB ERROR
When an OBD output is energized, a check is
always made to ensure that the signal also appears at
the respective input. If there is a problem, and no
active input is detected, the IC turns the output off and
declares that there was a problem with the FeedBack
(FB) of the signal. If this is an initial trial with your
ELM327, this is almost certainly a wiring problem.
Check your wiring before proceeding.
Ghg79 » 28 май 2018, 21:26
1) что такое накопительная эффективность?
2) что обозначают все параметры на экране Мощность (НЕ НАШЁЛ В СПРАВКЕ )?
koalexx » 08 июл 2018, 02:22
Вопрос о корректности идентификации ошибок. У меня используется протокол Daihatsu - на вид все работает (ну имеется ввиду подключенные датчики, понятно что не все). Сегодня делал эксперимент, отключал первый датчик кислорода, Ваша программа выдала ошибку
P0101 (OBD) "Выход сигнала из допустимого диапазона. Неправильный показатель/не отрегулирован расходометр воздуха"
Ну т.е. как бы совсем "не то", что должна бы...
В то же время стационарно установленный БК Multitronics, при подключении выдает верную ошибку P0135 "неисправность нагревателя ДК1"
Вы не могли бы, как-нибудь проверить достоверность выдаваемых ошибок? Иначе смысл в этой диагностике...
HobDrive(1.5.33)
kdika » 08 июл 2018, 07:45
Лог trace с ошибкой положите сюда
koalexx » 08 июл 2018, 19:43
Ну отсоединил опять первый датчик, завел авто, подключил Хоб - ниже лог (если все правильно сделал :)
HobDrive(1.5.33)
kdika » 09 июл 2018, 08:59
Спасибо, все правильно сделали.
Закрался баг. Ошибка должна отображаться Р0135. Исправим.
kdika » 10 июл 2018, 20:59
koalexx, замените файл из вложения в папке hobdrive/ecu
Проверьте правильность отображаемых ошибок
daihatsu.ecuxml
prouri » 13 июл 2018, 01:19
l_tyt писал(а):
Добрый день.Подскажите пожалуйста. Периодически стала зависать программа-помогает если передернуть шнурок USB.Потом может работать до выключения головного устройства , а может вылететь почти сразу.
Решил проблему? У меня тоже такая проблема на ГУ Андроид с УСБ ЭЛМ. Вот ищу как от нее избавится
prouri » 13 июл 2018, 22:56
В машине стоит Гу на Андроиде. Имеется ELM 327 USB. Не могу подружить ГУ с ELM 327 USB. Запускаю программу HobDriv на ГУ, выставляю шаблон на свою машину HONDA HR-V. Программа запускается, данные считываются. Выходит зеленый кружочек. Поработав секунд 10 программа зависает . ГУ на кнопки не реагирует. Помогает если передернуть шнурок USB. Много я с этим мучился ну ни как не получалось завести программу. Решил снять лог и отправить Вам для оказания помощи. Когда запускал сохранения лога, после этого у меня программа вдруг стала чуть подольше работать. Минут пять я ехал и она не зависала. Я даже подумал, что это она почувствовала что ей будет плохо когда я отправлю Вам логи и решила немного поработать. Если я ставлю свои параметры на машину, то программа вообще не хочет запускаться, а просто виснет и все. Только если выбираю из шаблона она немного работает. Но из шаблона параметры не совсем верные на мою машину. У меня HONDA HR-V 2004 года, VTEC, 1,6 литров, 124 л/с пятиступенчатая коробка передач. Может вы мне и поможете. Сперва грешил на ELM 327 USB, но после того как он проработал 5 минут без сбоев стал сомневаться.
koalexx » 16 июл 2018, 00:43
kdika писал(а):koalexx, замените файл из вложения в папке hobdrive/ecu
Спасибо! Именно эта стала отображаться правильно, другие не было времени потестировать - может позже :)
В продолжение вопроса... возможно ли использовать пиды (добавить) например эти
В торке (при их использовании) имеются и коррекции топлива (у Вас они по нулям при работе) и некоторые другие, которых у Вас я не нашел.
Кроме того вопрос, в Вашей программе указан угол зажигания 60 градусов на ХХ, это корректные показания!? У торка около 6 градусов показывает.
И еще один вопрос, какими настройками можно изменить масштаб по горизонтали датчика? Что бы получилось примерно такое как на отображении справа (торк)
HobDrive(1.5.33)
Allbaer » 18 июл 2018, 01:01
1. Недавно начал использовать бету 1.5.33. В сравнении с 1.5.27. появилась ошибка смены темы с дня на ночь и обратно, если окно программы в фоне или свёрнуто. Выглядит как чёрный экран, где мерцают датчики программы и никак не установятся. Помогает принудительная перезагрузка программы. Впервые это наблюдаю именно на 1.5.33. Ошибка не проявляется, если окно программы в момент смены темы активно.
2. Хотел бы добавить у себя в конфигурации возможность вызова меню пропущенной поездки по "oneclick" одного из сенсоров (в данном случае одометра). Можно или нельзя? Если можно, то что и куда прописать? Сам не нашёл.
3. Также хотел бы себе добавить возможность сброса поездки (авто трип, трип А, трип Б) в зависимости от того, что открыто по "oneclick" одного из сенсоров (в данном случае средней скорости). Можно или нельзя? Если можно, то что и куда прописать?
kdika » 18 июл 2018, 02:13
Allbaer писал(а):1. Недавно начал использовать бету 1.5.33.
попробуйте 1.5.36
Allbaer писал(а):2. Хотел бы добавить у себя в конфигурации возможность вызова меню пропущенной поездки по "oneclick" одного из сенсоров (в данном случае одометра). Можно или нельзя? Если можно, то что и куда прописать? Сам не нашёл.
onclick="EnterMissingTrip" inherit="_EditAction"
      <item id="Odometer" onclick="EnterMissingTrip" size="large" inherit="_EditAction"/>
в user.layout
Allbaer » 18 июл 2018, 20:10
1.5.36. для Win32 не выкладывали. Я к тому привык, поскольку я тут, видимо, один.
Код про пропущенную поездку работает. Спасибо!
Про сброс Автотрип, ТрипА, ТрипБ по onclick я понимаю возможности нет?
Ну и, конечно, меня интересует история со старинными багами про сброс максимальной температуры и скорости при вводе данных о новой заправке.
YUra.Veterinarov6468 » 19 июл 2018, 22:29
нажимаю диагностика/сброс ошибок и программа вылетает, что может быть?
kdika » 19 июл 2018, 22:32
Номер версии какой?
На версии 1.5.36 пробовали?
ЗЫ. сделайте себе подпись.
YUra.Veterinarov6468 » 19 июл 2018, 23:39
1.5.32
kdika » 20 июл 2018, 00:04
обновитесь до 1,5,36 и проверьте на ней
YUra.Veterinarov6468 » 24 июл 2018, 17:57
kdika писал(а):обновитесь до 1,5,36 и проверьте на ней
обновился до 1.5.36 все равно прога вылетает, а вот демо не вылетает
kdika » 24 июл 2018, 19:41
Положите лог и ваш файл user.layout
