Hobdrive on Android Beta
Installation and usage on Android phones, tablets, etc
cail » 28 мар 2012, 15:00
hobDrive for Android full version is available for purchase
http://hobdrive.com/buy
Android only license, allows two simultaneous installations on any of your devices.
On Google Play:
License is linked against your google acc.
For existing Windows license owners we give a 40% discount for second purchase. Contact support@hobdrive.com to receive discount.
hobdrive Demo
Download hobdrive demo 1.1.55
From this version, all future updates you can do on your own: "Screens" - "Settings" - "Network" - "Use beta channel" - "Check for updates".
For license beta updates, you should enter your account page:
enter your email, account ID.
There you can download beta packages and copy files from ZIP into your current install folder.
Verify that your original useragent.dll file is in there (that is your license) Please do backup before use. Unofficial beta releases could contain some bugs or cause problems - use these with care.
Android owners could use account page to reset serial ID activations (in case theirs phone IDs were changed for some reason)
Re: Hobdrive on Android Beta
Zafar » 10 май 2012, 13:19
Works well but sometimes minimizes itself and it doesnt calculate my fuel economy. Running my CE config.xml and user.vehicles.
job4wes » 06 июн 2012, 10:48
Hi guys, i tried to use hobd 1.1.21 beta on my Samsung Galaxy S2, but can't connect the app with the OBD2 elm327 bluetooth adapter, here a log cut:
[INFO] 05.06.2012 20:18:10.000[HOBD]  HOBD 1.1.21 02.05.2012  11:43
[INFO] 05.06.2012 20:18:10.042[HOBD]  Env: 4.0.50524.0
[INFO] 05.06.2012 20:18:10.657[HOBD]  Vehicle: OBD-II compatible
[ERROR] 05.06.2012 20:18:10.797[SensorStorage]  error reading
System.IO.FileNotFoundException: Could not find file "/mnt/sdcard/hobd/persistent.data"
  at System.IO.FileStream..ctor (System.String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean anonymous, FileOptions options) [0x00000] in <filename unknown>:0
  at System.IO.FileStream..ctor (System.String path, FileMode mode) [0x00000] in <filename unknown>:0
  at hobd.SensorStorage.Attach (hobd.SensorRegistry registry) [0x00000] in <filename unknown>:0
[ERROR] 05.06.2012 20:18:11.593[HOBD]  locale: ru
[INFO] 05.06.2012 20:18:11.721[HomePage]  System DPI: 240
[INFO] 05.06.2012 20:18:11.721[HomePage]  App DPI: 144
[INFO] 05.06.2012 20:18:11.722[HomePage]  layout: 288x480
[ERROR] 05.06.2012 20:18:16.745[BT]  Java.Lang.Exception
Java.Lang.Exception: Exception of type 'Java.Lang.Exception' was thrown.
[ERROR] 05.06.2012 20:18:16.757[OBD2Engine]  Init Error
System.Exception: Can't connect socket btspp://00:19:5D:25:86:59 - 00:19:5D:25:86:59
  at hobdroid.AndroidBlueToothStream.Open (System.String url) [0x00000] in <filename unknown>:0
  at hobd.OBD2Engine.SetState (System.String state2) [0x00000] in <filename unknown>:0 BaseException:
[ERROR] 05.06.2012 20:18:41.597[BT]  Java.Lang.Exception
[ERROR] 05.06.2012 20:18:41.600[OBD2Engine]  Init Error
Is there any advice for solve initial issue ?
cail » 06 июн 2012, 11:35
job4wes, could you try the latest beta:
http://hobdrive.com/download/hobd/hobd. ... 1.1.35.apk
it has "alternative connection method" in settings - that could help.
alawadhi3000 » 07 июн 2012, 02:38
The thing I noticed in build 1.1.21 beta is that you can't set a custom initialization string.
Will try 1.1.35 beta later.
cail » 22 июн 2012, 11:08
hobdrive full version for android is available. still in beta, giving a discound because of that. see first message for details.
alexspires » 15 июл 2012, 18:28
Hi!
Will it also works on the new Multimedia units that are now using Android 2.3 at 800x480?
cail » 16 июл 2012, 08:56
Sure it will. Notice however hobdrive android doesn not support for now USB-ELM adapters. So your unit should have BT (or Wifi) on board to be able to link with ELM BT or ELM WiFi.
cail » 11 ноя 2012, 08:17
beta 1.1.55 is now available (see first post)
stephenoneufer » 19 ноя 2012, 16:33
Found out that my program is displaying speed in KPH but everything else is set to english units. This messes up MPG's
cail » 19 ноя 2012, 19:11
Thanks, that was a regression on latest betas. Will fix in next update.
stephenoneufer » 19 ноя 2012, 20:03
Great...
maxman » 06 фев 2013, 23:39
Hi,
when i need to use http://hobdrive.com/payment/orders/manage
it shows: "translation missing: en.Invalid order details"
I use my android license and email.
cail » 08 фев 2013, 11:23
replied in private.
rogerlee » 24 окт 2013, 12:32
The demo is in limited function but this looks to be cool apps to have. I don't know but i am thinking to try the full version.. although $21 is cost that much, perhaps once I have saving on my debit card I will try it since I already have Google Wallet link to my card.
"customizing samsung galaxy cases by request"
