Hobdrive hangs
СообщениеДобавлено: 23 дек 2012, 06:48
gulfyankee
Hi Cail. I'm running hob drive on a vizio tablet in my truck, 2006 Dodge Ram Hemi. First of all, congrats, your program is the only one that has been able to accurately calculate my mpg, even compensating for the multiple displacement system. Anyways, I'm using llama to shut off my screen and activate airplane mode when I turn the ignition off. No problems there. However, when I restart the vehicle, llama turns on my screen and deactivates airplane mode. At this point hobdrive is frozen. The gauge screen is up, but there is no activity whatsoever, and no response to any of my inputs. I have to wait for the android 'not responding' screen to come up so I can restart hob drive. Any suggestions, other than manually starting and stopping hob drive each time I drive?
Re: Hobdrive hangs
СообщениеДобавлено: 24 дек 2012, 04:56
Hm.. it would be definitely useful to see the system logs here..
In hobdrive options click "start system log", then reproduce the issue, then, after hobdrive hangs, take file /sdcard/hobd/logcat.txt (or /hobdrive if using a full version).
Re: Hobdrive hangs
СообщениеДобавлено: 25 дек 2012, 03:58
gulfyankee
Emailed you the log file, hopefully it is helpful
Re: Hobdrive hangs
СообщениеДобавлено: 25 дек 2012, 04:26
Thanks, will check this out
