Hobdrive on Lexus RX300 MY2003
Добавлено: 11 авг 2014, 10:49
Hi everyone,
I pulled out ATF Temp from Toyota sensors in one of the main screens. The problem is that there are no "units" (degrees Celsius) like in other temp readings. The only place I could find reference to link ATF Temp and units was in the folder doc/hobdSensors.html file and it was in the Russian translation. I add there the same lines in the English description but no success. So two questions:
1. How can I link the Toyota ATF Temp reading with it's respective units?
2. Remembering in the past when I was using ScanGaugeII in another car it was relatively easy to pull out Horse Power (HP) insted of Engine Load. It seems to me that there is someting wrong with this reading in HOBD. For Lexus 3.0 liter it shows 20% engine load in idle??? This shouldn't be true. So is there a way to pull out HP reading if the ECU supports it?
