i want to reading Air Fuel Ratio
Добавлено: 28 июл 2018, 01:25
Hello everybady;
i have got a İmpreza (1.5R 2007 model ) and i use to Hobd 1.3.2 free version.
and i want to reading Air Fuel Ratio .
I can read with Torque Pro, but I can not read with Hobd.
Torque has a special ID ff1249 and it is working. i dont know Torque used witch OBD PID.
i guess used, 01 24 (Oxygen Sensor 1 AB: Fuel–Air Equivalence Ratio). and i checked Wikipedia , formula is 2/65536(256A+B)
but i checked source code of the Hobdcore.dll ver 0.53 has a different calculation method and formula.
If I think that the formula is not wrong ,I can not do this.
i create a new ecuxlm and try ;
<parameter id="A/F">
<description>
<name>Air Fuel Ratio</name>
<unit></unit>
</description>
<address>
<byte>0x24</byte>
</address>
<valueab>0.0000305</valueab>
</parameter>
return value :32651 , it is not correct value .
Please help me for correct parameter and read for AF/R
And,
Which configuration should I use.
Thank you.
<description>
<unit></unit>
</description>
<address>
<byte>0x24</byte>
</address>
</parameter>
And,
Thank you.
