Peugeot 307 2002 with ECU Siemens Sid 801
СообщениеДобавлено: 18 мар 2015, 00:27
gabriele.giammatteo73062
Hello,
my setup is the following: Peugeot 307 2.0 HDI 90 Hp Diesel (year 2002) + ECU "Siemens Sid 801" + ELM327 Bluetooth adapter + HobDrive demo for Android.
I tried several combination of protocols: with some of them I manage to connect, but only the Battery Voltage is readable. With all the others I cannot connect at all.
Given the production year, I suspect my car is not fully compatible with OBD-II, but I can see HObDrive has custom ELM init templates for some specific ECUs and the possibility to write new ones. I'm wondering if there is the possibility that I need a specific init string for my ECU and how I can find the proper string.
Thank you very much for the support,
Gabriele
Re: Peugeot 307 2002 with ECU Siemens Sid 801
СообщениеДобавлено: 18 мар 2015, 15:04
Hello.
In addition to the initialization string must know PIDs for your computer.
Try searching for ...
PS. sorry for my english. Google translate
