Toyota auris 2007 NOT CONNECTING
marcinek40 » 03 окт 2015, 22:07
Hello I am a connection to the elm but 327 is not connected to the Vehicle protocol automatically searches but there is nothing I have to type ?? but chose not joined Toyota
Re: Toyota auris 2007 NOT CONNECTING
cail » 05 окт 2015, 13:34
Hello, please try manually setup vehicle protocol in "Vehicle Settings".
Autosearch may sometimes fail.
marcinek40 » 05 окт 2015, 16:18
ok about which type to choose Vehicle Settings, Toyota does not work
kdika » 05 окт 2015, 21:51
what version elm327 (1.5 or 2.1) you use?
marcinek40 » 13 окт 2015, 07:57
kdika » 13 окт 2015, 10:01
It is necessary to check the adapter to the command ATAL
If you return a question mark, then the adapter will not work with Toyota
http://hobdrive.userecho.com/topic/8888 ... terov-elm/
hpcnr73402 » 14 окт 2015, 21:51
kdika » 14 окт 2015, 23:01
which corresponds to the command ATAL Elm327 ?
