Toyota auris 2007 NOT CONNECTING
СообщениеДобавлено: 03 окт 2015, 22:07
marcinek40
Hello I am a connection to the elm but 327 is not connected to the Vehicle protocol automatically searches but there is nothing I have to type ?? but chose not joined Toyota
Re: Toyota auris 2007 NOT CONNECTING
СообщениеДобавлено: 05 окт 2015, 13:34
Hello, please try manually setup vehicle protocol in "Vehicle Settings".
Autosearch may sometimes fail.
СообщениеДобавлено: 05 окт 2015, 16:18
marcinek40
ok about which type to choose Vehicle Settings, Toyota does not work
СообщениеДобавлено: 05 окт 2015, 21:51
what version elm327 (1.5 or 2.1) you use?
СообщениеДобавлено: 13 окт 2015, 07:57
marcinek40
СообщениеДобавлено: 13 окт 2015, 10:01
It is necessary to check the adapter to the command ATAL
If you return a question mark, then the adapter will not work with Toyota
http://hobdrive.userecho.com/topic/8888 ... terov-elm/
СообщениеДобавлено: 14 окт 2015, 21:51
hpcnr73402
СообщениеДобавлено: 14 окт 2015, 23:01
which corresponds to the command ATAL Elm327 ?
