Honda City vehicle settings
Hi Cail, how are you, wish you fine always
Cail, would u help me how to enter the right value for the vehicle setting for Honda City car 2007, December, 1500cc, CBU Thailand, in this cases:
MPG Method: MAP Sensor (only this one is working properly)
Engine Displacement (in liters): ???
Volumetric Efficiency: ???
Stoich Air-Fuel Ratio: ???
I have tried many values even blank, all will give different result for fuel consumption, and no one match for my car.
Thanks in advanced
Thanks in advanced
Go HobDrive Go !
Re: Honda City vehicle settings
Hi,
Displacement is for sure 1.5
Stoich you may leave empty (default)
VE - start with 65 - but then you should see a consumption on rather big iterval and compare it with real consumption (calculated by full tank). If results are no match, scale VE accordingly.
