Vehicle compatibility
СообщениеДобавлено: 15 дек 2011, 16:05
Please inform us if you have a OBD2 compatible vehicle, not listed in our list:
http://hobdrive.com/faq/obd2vehicles.html
Re: Vehicle compatibility
СообщениеДобавлено: 27 апр 2012, 07:49
smitty124
2006 Chevorlet Optra 5 LS
(although I cant see why it wouldn't work on any Chevy Optra model)
СообщениеДобавлено: 02 окт 2012, 16:26
hgt
I have a cheap chinese gps running HobDrive linked via Bluetooth to the car.
The car is a Alfa Romeo Guilietta JTDM 2ltr 2011 model, I have only just tried it, but so far it all seems to work ok.
The only gauge that is not reading is the outside temperature, but I have not set any of the parameters yet. I will post more information when I have given it a full test.
СообщениеДобавлено: 24 мар 2013, 01:06
ralf.mars21202
hi,
tried to get data out from my vehicle OBD2 socket with ELM transmitter - Subaru Legacy 2000 2,5 AT
no success, swapped ELM transmitters etc, nothing.
will send you VIN code on private mail, if you interested.
Ralf
СообщениеДобавлено: 22 июл 2013, 14:39
Alton0
I posted on here some months back about getting a Win CE 6.0 Chinese GPS running with Hobdrive, but gave up as the OS was so severely stripped and refused to work with a USB or BT OBDII adapter.
СообщениеДобавлено: 28 июл 2013, 05:17
yillw
Hi All,
I have a 2006 Chevorlet Equinox (US market) using 11bit CAN bus. HobDrive works, I just wished that more sensors were implemented in hobdrive. ie EGR Error, Commanded EGR, Catalyst temp,total misfire(which is very useful when diag trouble on the car). ...
СообщениеДобавлено: 05 авг 2013, 05:20
Thanks for the info.
There are some of them on "all sensors" page. You can check it out.
СообщениеДобавлено: 06 авг 2013, 13:15
yillw
Hi Cail,
Some of them worked before, but since upgraded to beta 1182, none of the sensors worked in the all sensors page. Aren't they all for toyoto can21?
СообщениеДобавлено: 07 авг 2013, 22:53
You should not see any of toyota can21 sensors unless you've selected this ECU explicitly. Please check your settings.
СообщениеДобавлено: 27 сен 2013, 21:06
phuarchi
Is possible to connect Passat B5 1997?
I try HD 1.1.1 and connect to ELM but can read only battery voltage. I try many configuration but can read only this.
СообщениеДобавлено: 29 сен 2013, 05:39
Unfortunately the year is too old, vehicles of these years do not support OBD2 specification.
СообщениеДобавлено: 18 ноя 2013, 18:24
boow
ralf.mars21202 писал(а):hi,
Ralf
hobdrive works with my subaru legacy 2000 USA 2,5 manual gear in russia perfectly =)
