Alfa 159 2008 jtdm sensors
I successfully run the program in my wince navigator connected with elm327 at my car.
Not all sensors work... one of most important is the turbo pressure, it not show any data.... why?
Sorry for my english
Re: Alfa 159 2008 jtdm sensors
marmotta,
TC sensors are quite rarely supported. Do you know any other software which reads TC pressure fine on your vehicle? Probably it could be coded in other PID.
FiatEcuScan correct read all sensors
Is possible to add/modify with custom pids for adapt hobdriver to my car? The standard obd2 pid list is not sufficient.
Hobdrive supports adding custom sensors. You may checkout ecu/*.ecuxml files for examples.
Unfortunately we don't have a manual in english on how to use/modify these files, hope will create this soon.
For now you may only refer to examples when editing your custom PIDs.
cail писал(а):Hobdrive supports adding custom sensors. You may checkout ecu/*.ecuxml files for examples.
Unfortunately the pids for my car is impossible to find....
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 13
