HOBDrive not communicate with ECU 3ZR-FE Toyota Corolla
- andypeterles
Hi,
my "problem" is that HOBDrive can not communicate with the ECU of my car, a brazilian Toyota Corolla 2011 2.0 Dual VVT-i (3ZR-FE).
Has anyone seen this problem and knows a solution?
Regards!
Regards!
HOBDrive 1.1.97-Beta + RoadRover MotorOne(M1) WinCE6 800x480 + ELM327BTmini + Kevler Bluetooth(generical) + Toyota Corolla 2011 XEi FLEX 2.0 Dual VVT-i (3ZR-FE)
Re: HOBDrive not communicate with ECU 3ZR-FE Toyota Corolla
Andy, are you sure hobdrive sees and can reach your ELM adapter? Because it should work absolutely fine with these toyotas.
- andypeterles
Yes Cail, I'm sure. I visualize the LEDs of the device in action during the commands sent by HOBDrive. I also tested with Torque Pro software (Android) and the result is the same, arriving just yet to talk to the ECU.
I'm putting a few pieces of logs below:
Regards!
============TRACE
[INFO] 10/3/2014 21:21:03.002[HOBD] HOBD 1.1.1 24.02.2012 14:34
[INFO] 10/3/2014 21:21:03.187[HOBD] Env: 3.5.7283.0
[INFO] 10/3/2014 21:21:05.009[HOBD] SN: 00540054-0034-0058-0030-545434583042445F3000
[INFO] 10/3/2014 21:21:11.466[HOBD] Vehicle: My Vehicle
[TRACE] 10/3/2014 21:21:11.649[HOBD] RegisterProvider: hobd.OBD2Sensors
[INFO ] 10/3/2014 21:21:11.745[SpeedSensor] Using default coefficient
[TRACE] 10/3/2014 21:21:11.764[HOBD] RegisterProvider: ecuxml://ecu/obd2.ecuxml
[ERROR] 10/3/2014 21:21:11.826[HOBD] bad provider ecuxml://\Storage Card\Programas\HOBD1.1.1\ecu/obd2.ecuxml
System.Exception: unknown tag `command` while creating PID Lambda11
at hobd.ECUXMLSensorProvider.init(SensorRegistry registry)
at hobd.ECUXMLSensorProvider.Activate(SensorRegistry registry)
at hobd.SensorRegistry.RegisterProvider(SensorProvider provider)
at #=queSlQ6WOwqlLYH3QsyFJK3LG9wDtR6wuXiVTPMnBgSo=.#=qYbfmgSv9IK7nU8yg9itpObmzP2a8HTUFWGe0jLVvkvE=(String #=qCpA2yT9JmyyxP5CYdok8Cw==)
at #=queSlQ6WOwqlLYH3QsyFJK3LG9wDtR6wuXiVTPMnBgSo=.#=q4p1l7P2TL5YDzMbY2p0Dew==()
at #=queSlQ6WOwqlLYH3QsyFJK3LG9wDtR6wuXiVTPMnBgSo=.#=qNkRdgpRnBCG8_s7mBF4X6g==()
at #=qemyrhFzVjqMRdsGEWu$9lQ==.#=qrIZO76EQPMJEaiXgp3O51Q==()
at #=qsn5YiReJqOOgWguWkwcpkg==.#=qp$Y68N4sL$EWs2aDqswyWA==(String[] #=qM$ch0Osy81ygpZG0onoQ5g==)
[TRACE] 10/3/2014 21:21:11.871[HOBD] RegisterProvider: hobd.ELMSensors
[TRACE] 10/3/2014 21:21:11.883[HOBD] RegisterProvider: hobd.MAFSensors
[INFO ] 10/3/2014 21:21:11.895[LitersPerHourSensor] Using default stoich ratio
System.Collections.Generic.KeyNotFoundException: KeyNotFoundException
at System.ThrowHelper.ThrowKeyNotFoundException()
at System.Collections.Generic.Dictionary`2.get_Item(String key)
at hobd.elm.maf.LitersPerHourSensor.SetRegistry(SensorRegistry registry)
at hobd.SensorRegistry.Add(Sensor sensor)
at hobd.MAFSensors.Activate(SensorRegistry registry)
[TRACE] 10/3/2014 21:21:11.939[HOBD] RegisterProvider: hobd.CommonSensors
[TRACE] 10/3/2014 21:21:11.960[HOBD] RegisterProvider: ecuxml://ecu/default.ecuxml
[TRACE] 10/3/2014 21:21:11.981[HOBD] RegisterProvider: ecuxml://user.ecuxml
[ERROR] 10/3/2014 21:21:12.046[HOBD] bad provider ecuxml://\Storage Card\Programas\HOBD1.1.1\user.ecuxml
System.IO.FileNotFoundException: An error message is available for this exception but cannot be displayed because these messages are optional and are not currently installed on this device. Please install ‘NETCFv35.Messages.EN.wm.cab’ for Windows Mobile 5.0 and above or ‘NETCFv35.Messages.EN.cab’ for other platforms. Restart the application to see the message.
[TRACE] 10/3/2014 21:21:12.249[FCS] lph: MAF.LitersPerHour
[TRACE] 10/3/2014 21:21:12.267[FCS] lph: MAF.LitersPerHour
[TRACE] 10/3/2014 21:21:12.278[FCS] lph: MAF.LitersPerHour
[TRACE] 10/3/2014 21:21:12.569[HOBD] Connecting stream: btspp://000D18A04E35;pin=1234
[INFO] 10/3/2014 21:21:12.656[HOBD] system width: 800, height: 480
[INFO] 10/3/2014 21:21:12.666[HOBD] wa width: 800, wa height: 454
[TRACE] 10/3/2014 21:21:14.058[HomePage] tap distance 26
[INFO] 10/3/2014 21:21:14.183[HomePage] System DPI: 96
[INFO] 10/3/2014 21:21:14.199[HomePage] App DPI: 57
[INFO] 10/3/2014 21:21:14.212[HomePage] layout: 475x269
[INFO] 10/3/2014 21:21:14.224[HomePage] form: 242x293
[INFO ] 10/3/2014 21:21:16.279[HomePage] no layout file user.layout
[TRACE] 10/3/2014 21:21:17.382[OBD2Engine] -> INIT
[INFO ] 10/3/2014 21:21:17.584[OBD2Engine] Open btspp://000D18A04E35;pin=1234
[TRACE] 10/3/2014 21:21:19.248[BluetoothStream] Open 000D18A04E35 serviceid pin 1234
[TRACE] 10/3/2014 21:21:20.196[OBD2Engine] -> ATZ
[TRACE] 10/3/2014 21:21:20.254[OBD2Engine] SendCommand:ATZ
[TRACE] 10/3/2014 21:21:21.164[OBD2Engine] HandleReply: ?
ELM327 v1.5
[TRACE] 10/3/2014 21:21:21.173[OBD2Engine] SendCommand:ATZ
[TRACE] 10/3/2014 21:21:21.993[OBD2Engine] HandleReply: ATZ
ELM327 v1.5
[INFO] 10/3/2014 21:21:22.011[OBD2Engine] VersionInfo: ?ELM327 v1.5
[TRACE] 10/3/2014 21:21:22.020[OBD2Engine] -> ATE0
[TRACE] 10/3/2014 21:21:22.066[OBD2Engine] SendCommand:ATE0
[TRACE] 10/3/2014 21:21:22.128[OBD2Engine] HandleReply: ATE0
OK
[TRACE] 10/3/2014 21:21:22.138[OBD2Engine] -> ATL0
[TRACE] 10/3/2014 21:21:22.189[OBD2Engine] SendCommand:ATL0
[TRACE] 10/3/2014 21:21:22.251[OBD2Engine] HandleReply: OK
[TRACE] 10/3/2014 21:21:22.261[OBD2Engine] -> EXTRAINIT
[TRACE] 10/3/2014 21:21:22.346[OBD2Engine] SendCommand:ATSP 0
[TRACE] 10/3/2014 21:21:22.409[OBD2Engine] HandleReply: OK
[TRACE] 10/3/2014 21:21:22.419[OBD2Engine] -> EXTRAINIT
[TRACE] 10/3/2014 21:21:22.465[OBD2Engine] -> SENSOR_INIT
[TRACE] 10/3/2014 21:21:22.512[OBD2Engine] SendCommand:0100
[TRACE] 10/3/2014 21:21:26.767[OBD2Engine] HandleReply: SEARCHING...
UNABLE TO CONNECT
[ERROR] 10/3/2014 21:21:26.790[OBD2Engine] Critical error:SEARCHING...
UNABLE TO CONNECT
[TRACE] 10/3/2014 21:21:26.809[OBD2Engine] -> ERROR
[TRACE] 10/3/2014 21:21:48.061[OBD2Engine] -> INIT
[INFO ] 10/3/2014 21:21:48.527[OBD2Engine] Open btspp://000D18A04E35;pin=1234
[TRACE] 10/3/2014 21:21:49.158[BluetoothStream] Open 000D18A04E35 serviceid pin 1234
[INFO ] 10/3/2014 21:21:49.932[HOBD] app exit
============ERROR
[INFO] 10/3/2014 21:07:04.002[HOBD] HOBD 1.1.1 24.02.2012 14:34
[INFO] 10/3/2014 21:07:04.198[HOBD] Env: 3.5.7283.0
[INFO] 10/3/2014 21:07:05.986[HOBD] SN: 00540054-0034-0058-0030-545434583042445F3000
[INFO] 10/3/2014 21:07:06.360[HOBD] Vehicle: My Vehicle
[ERROR] 10/3/2014 21:07:06.556[HOBD] bad provider ecuxml://\Storage Card\Programas\HOBD1.1.1\ecu/obd2.ecuxml
[ERROR] 10/3/2014 21:07:06.617[HOBD] bad provider ecuxml://\Storage Card\Programas\HOBD1.1.1\user.ecuxml
[INFO] 10/3/2014 21:07:07.075[HOBD] system width: 800, height: 480
[INFO] 10/3/2014 21:07:07.094[HOBD] wa width: 800, wa height: 480
[INFO] 10/3/2014 21:07:08.656[HomePage] System DPI: 96
[INFO] 10/3/2014 21:07:08.672[HomePage] App DPI: 57
[INFO] 10/3/2014 21:07:08.681[HomePage] layout: 475x285
[INFO] 10/3/2014 21:07:08.692[HomePage] form: 242x293
[INFO] 10/3/2014 21:07:17.425[OBD2Engine] VersionInfo: ?ELM327 v1.5
[ERROR] 10/3/2014 21:07:22.093[OBD2Engine] Critical error:SEARCHING...
UNABLE TO CONNECT
==============DUMP
[INFO] 10/3/2014 21:23:48.001[HOBD] HOBD 1.1.1 24.02.2012 14:34
[INFO] 10/3/2014 21:23:48.185[HOBD] Env: 3.5.7283.0
[INFO] 10/3/2014 21:23:49.991[HOBD] SN: 00540054-0034-0058-0030-545434583042445F3000
[INFO] 10/3/2014 21:23:54.051[HOBD] Vehicle: My Vehicle
[TRACE] 10/3/2014 21:23:54.117[HOBD] RegisterProvider: hobd.OBD2Sensors
[INFO ] 10/3/2014 21:23:54.193[SpeedSensor] Using default coefficient
[TRACE] 10/3/2014 21:23:54.207[HOBD] RegisterProvider: ecuxml://ecu/obd2.ecuxml
[ERROR] 10/3/2014 21:23:54.267[HOBD] bad provider ecuxml://\Storage Card\Programas\HOBD1.1.1\ecu/obd2.ecuxml
[TRACE] 10/3/2014 21:23:54.325[HOBD] RegisterProvider: hobd.ELMSensors
[TRACE] 10/3/2014 21:23:54.340[HOBD] RegisterProvider: hobd.MAFSensors
[INFO ] 10/3/2014 21:23:54.352[LitersPerHourSensor] Using default stoich ratio
[TRACE] 10/3/2014 21:23:54.384[HOBD] RegisterProvider: hobd.CommonSensors
[TRACE] 10/3/2014 21:23:54.406[HOBD] RegisterProvider: ecuxml://ecu/default.ecuxml
[TRACE] 10/3/2014 21:23:54.432[HOBD] RegisterProvider: ecuxml://user.ecuxml
[ERROR] 10/3/2014 21:23:54.444[HOBD] bad provider ecuxml://\Storage Card\Programas\HOBD1.1.1\user.ecuxml
[DUMP ] 10/3/2014 21:23:54.552[SensorRegistry] AddListener Common.DistanceRun System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:54.571[SensorRegistry] AddListener OBD2.Speed System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 5000
[DUMP ] 10/3/2014 21:23:54.583[SensorRegistry] AddListener Common.FuelConsumed System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[TRACE] 10/3/2014 21:23:54.597[FCS] lph: MAF.LitersPerHour
[DUMP ] 10/3/2014 21:23:54.607[SensorRegistry] AddListener MAF.LitersPerHour System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 2000
[DUMP ] 10/3/2014 21:23:54.619[SensorRegistry] AddListener OBD2.MAF System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:54.633[SensorRegistry] AddListener Common.IdleTime System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:54.644[SensorRegistry] AddListener OBD2.Speed System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 2000
[DUMP ] 10/3/2014 21:23:54.654[SensorRegistry] AddListener Common.TripTime System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:54.669[SensorRegistry] AddListener OBD2.Speed System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 2000
[DUMP ] 10/3/2014 21:23:54.679[SensorRegistry] AddListener FuelConsumed_tank System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[TRACE] 10/3/2014 21:23:54.689[FCS] lph: MAF.LitersPerHour
[DUMP ] 10/3/2014 21:23:54.702[SensorRegistry] AddListener MAF.LitersPerHour System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 2000
[DUMP ] 10/3/2014 21:23:54.712[SensorRegistry] AddListener FuelConsumed_fueling System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[TRACE] 10/3/2014 21:23:54.722[FCS] lph: MAF.LitersPerHour
[DUMP ] 10/3/2014 21:23:54.732[SensorRegistry] AddListener MAF.LitersPerHour System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 2000
[DUMP ] 10/3/2014 21:23:54.745[SensorRegistry] AddListener DistanceRun_fueling System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:54.755[SensorRegistry] AddListener OBD2.Speed System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 5000
[DUMP ] 10/3/2014 21:23:54.809[SensorRegistry] TriggerListeners Common.DistanceRun 0
[DUMP ] 10/3/2014 21:23:54.828[SensorRegistry] TriggerListeners Common.FuelConsumed 0
[DUMP ] 10/3/2014 21:23:54.846[SensorRegistry] ListenerHandler Common.DistanceRun 63530083434025
[DUMP ] 10/3/2014 21:23:54.859[SensorRegistry] ListenerHandler Common.FuelConsumed 63530083434038
0 0
S c a l e A l p h a59[SensorRegistry] ListenerHandler Common.FuelConsumedn s \ P a i n t . i c o
S c a l e A l p h a = 8 0
±‹\Þ+¿žë©ÂïÒ[Å.ÚÆ0øvÛ²Gsc¨¿“[DUMP ] 10/3/2014 21:23:54.899[SensorRegistry] TriggerListeners Common.IdleTime 0
[DUMP ] 10/3/2014 21:23:54.905[SensorRegistùžlÉä>ñˆÒi áßÀù44÷„Š”‘|\eêx‘¬œÜÜe‚@oaWçÒtJ¼jƒ¹*ŒcõÖ‚’TïjÓyİk².I€Ì˜Y½.n.Ö“ãhry] ListenerHandler Common.TripTime 63530083434084
[DUMP ] 10/3/2014 21:23:54.926[SensorRegistry] TriggerListeners FuelConsumed_tank 0
[DUMP ] 10/3/2014 21:23:54.946[SensorRegistry] ListenerHandler FuelConsumed_tank 63530083434125
UMP ] 10/3/2014 21:23:54.936[SensorRegistry] ListenerHandler FuelConsumed_tank 63530083434125
# C o n n e c t
I C O N X P B U T T O N
x = 6 7 2
y = 2 1 5
O f f s e t = 0
C o m m a n d = SensorRegistry] ListenerHandler FuelConsumed_tank 635300[DUMP ] 10/3/2014 21:23:54.978[SensorRegistry] TriggerListeners DistanceRun_fueling 0
[DUMP ] 10/3/2014 21:23:54.981[SensorRe \ I c o n s \ c o n n e c t . i c o
I c o n P u sgistry] ListenerHandler FuelConsumed_fueling 63530083434160
[DUMP ] 10/3/2014 21:23:55.017[SensorRegistry] ListenerHandler DistanceRun_fueling 63530083434196
[DUMP ] 10/3/2014 21:23:55.040[SensorRegistry] AddListener Common.DistanceRun System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:55.051[SensorRegistry] AddListener Common.FuelConsumed System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:55.061[SensorRegistry] AddListener Common.TripTime System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:55.074[SensorRegistry] AddListener Common.IdleTime System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:55.085[SensorRegistry] AddListener FuelConsumed_tank System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:55.098[SensorRegistry] AddListener FuelConsumed_fueling System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:55.108[SensorRegistry] AddListener DistanceRun_fueling System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:55.159[SensorRegistry] AddListener OBD2.CoolantTemp System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 60000
[DUMP ] 10/3/2014 21:23:55.175[SensorRegistry] AddListener OBD2.LTFT1 System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 60000
[DUMP ] 10/3/2014 21:23:55.186[SensorRegistry] AddListener OBD2.LTFT2 System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 60000
[DUMP ] 10/3/2014 21:23:55.197[SensorRegistry] AddListener OBD2.MIL System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 300000
[DUMP ] 10/3/2014 21:23:55.211[SensorRegistry] AddListener OBD2.PMIL System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 300000
[TRACE] 10/3/2014 21:23:55.417[HOBD] Connecting stream: btspp://000D18A04E35;pin=1234
[INFO] 10/3/2014 21:23:55.532[HOBD] system width: 800, height: 480
[INFO] 10/3/2014 21:23:55.542[HOBD] wa width: 800, wa height: 454
[TRACE] 10/3/2014 21:23:56.999[HomePage] tap distance 26
[INFO] 10/3/2014 21:23:57.163[HomePage] System DPI: 96
[INFO] 10/3/2014 21:23:57.187[HomePage] App DPI: 57
[INFO] 10/3/2014 21:23:57.204[HomePage] layout: 475x269
[INFO] 10/3/2014 21:23:57.480[HomePage] form: 242x293
[INFO ] 10/3/2014 21:23:59.636[HomePage] no layout file user.layout
[DUMP ] 10/3/2014 21:23:59.962[SensorRegistry] AddListener Common.FuelLevel System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:23:59.986[SensorRegistry] AddListener FuelInTank System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:24:00.005[SensorRegistry] AddListener FuelConsumed_tank System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 10000
[DUMP ] 10/3/2014 21:24:00.062[SensorRegistry] AddListener Common.FuelEconomy_trip System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:24:00.092[SensorRegistry] AddListener Common.DistanceRun System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 2000
[DUMP ] 10/3/2014 21:24:00.103[SensorRegistry] AddListener Common.FuelConsumed System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 2000
[DUMP ] 10/3/2014 21:24:00.113[SensorRegistry] AddListener ELM.BatteryVoltage System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 5000
[DUMP ] 10/3/2014 21:24:00.128[SensorRegistry] AddListener OBD2.RPM System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:24:00.139[SensorRegistry] AddListener OBD2.Speed System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:24:00.152[SensorRegistry] AddListener Common.Acceleration System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 0
[DUMP ] 10/3/2014 21:24:00.169[SensorRegistry] AddListener OBD2.Speed System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 3000
[DUMP ] 10/3/2014 21:24:00.180[SensorRegistry] AddListener OBD2.CoolantTemp System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 10000
[DUMP ] 10/3/2014 21:24:00.191[SensorRegistry] AddListener OBD2.IntakeAirTemp System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 10000
[DUMP ] 10/3/2014 21:24:00.205[SensorRegistry] AddListener OBD2.AirTemp System.Action`1[[hobd.Sensor, hobdcore, Version=1.0.4435.31199, Culture=neutral, PublicKeyToken=null]] 10000
[DUMP ] 10/3/2014 21:24:00.216[SensorRegistry] TriggerListeners Common.DistanceRun 63530083434025
[DUMP ] 10/3/2014 21:24:00.226[SensorRegistry] TriggerListeners Common.FuelConsumed 63530083434038
[DUMP ] 10/3/2014 21:24:00init>ATSP 0</engine-init>
<sensors>hobd.ELMSensors<.234[SensorRegistry] ListenerHandler Common.DistanceRun 63530083439413
[DUMP ] 10/3/2014 21:24:00.258[SensorRegistry] TriggerListeners Common.TripTime 63530083434084
[DUMP ] 10/3/2014 21:24:00.278g PID Lambda11
at hobd.ECUXMLSe[SensorRegistry] TriggerListeners Common.FuelEconomy_trip 0
[DUMP ] 10/3/2014 21:24:00.325[SensorRegistry] ListenerHandler Common.FuelConsumed 63530083439504
[DUMP ] 10/3/2014 21:24:00.335[SensorRegistry] TriggerListeners Common.FuelEconomy_trip 0
[DUMP ] 10/3/2014 21:24:00.344[SensorRegistry] ListenerHandler Common.FuelEconomy_trip 63530083439523
[DUMP ] 10/3/2014 21:24:00.360[SensorRegistry] ListenerHandler Common.FuelEconomy_trip 63530083439539
[DUMP ] 10/3/2014 21:24:00.371[SensorRegistry] TriggerListeners Common.IdleTime 63530083434116
[DUMP ] 10/3/2014 21:24:00.381LAN šr<X@W@ '/[?W ´ Bs . l a n Šg ÿÿÿÿÿÿÿÿ ÿÿÿÿi t . h o Šb d s e n s o r ITHOBD~1L[SensorRegistry] ListenerHandler Common.TripTime 63530083439560
[DUMP ] 10/3/2014 21:24:00.403[SensorRegistry] TriggerListeners FuelConsumed_tank 63530083434125
[DUMP ] 10/3/2014 21:24:00.413[SensorRegistry] ListenerHandler Common.IdleTime 63530083439592
[DUMP ] 10/3/2014 21:24:00.425[SensorRegistry] ListenerHandler FuelConsumed_tank 63530083439604
[DUMP ] 10/3/2014 21:24:00.436[SensorRegistry] TriggerListeners FuelInTank 0
[DUMP ] 10/3/2014 21:24:00.447[SensorRegistry] ListenerHandler FuelInTank 63530083439626
[DUMP ] 10/3/2014 21:24:00.457[SensorRegistry] TriggerListeners Common.FuelLevel 0
[DUMP ] 10/3/2014 21:24:00.467[SensorRegistry] ListenerHandler Common.FuelLevel 63530083439645
[TRACE] 10/3/2014 21:24:00.536[OBD2Engine] -> INIT
[INFO ] 10/3/2014 21:24:01.435[OBD2Engine] Open btspp://000D18A04E35;pin=1234
[TRACE] 10/3/2014 21:24:02.225[BluetoothStream] Open 000D18A04E35 serviceid pin 1234
[TRACE] 10/3/2014 21:24:04.180[OBD2Engine] -> ATZ
[TRACE] 10/3/2014 21:24:04.231[OBD2Engine] SendCommand:ATZ
[DUMP ] 10/3/2014 21:24:04.316[OBD2Engine] BUFFER: ?
[DUMP ] 10/3/2014 21:24:05.082[OBD2Engine] BUFFER: ?
ELM327 v1.5
[TRACE] 10/3/2014 21:24:05.112[OBD2Engine] HandleReply: ?
ELM327 v1.5
[TRACE] 10/3/2014 21:24:05.126[OBD2Engine] SendCommand:ATZ
[DUMP ] 10/3/2014 21:24:05.188[OBD2Engine] BUFFER: ATZ
[DUMP ] 10/3/2014 21:24:05.950[OBD2Engine] BUFFER: ATZ
ELM327 v1.5
[TRACE] 10/3/2014 21:24:05.970[OBD2Engine] HandleReply: ATZ
ELM327 v1.5
[INFO] 10/3/2014 21:24:05.980[OBD2Engine] VersionInfo: ?ELM327 v1.5
[TRACE] 10/3/2014 21:24:05.989[OBD2Engine] -> ATE0
[TRACE] 10/3/2014 21:24:06.036[OBD2Engine] SendCommand:ATE0
[DUMP ] 10/3/2014 21:24:06.098[OBD2Engine] BUFFER: ATE0
OK
[TRACE] 10/3/2014 21:24:06.108[OBD2Engine] HandleReply: ATE0
OK
[TRACE] 10/3/2014 21:24:06.117[OBD2Engine] -> ATL0
[TRACE] 10/3/2014 21:24:06.164[OBD2Engine] SendCommand:ATL0
[DUMP ] 10/3/2014 21:24:06.230[OBD2Engine] BUFFER: OK
[TRACE] 10/3/2014 21:24:06.240[OBD2Engine] HandleReply: OK
[TRACE] 10/3/2014 21:24:06.249[OBD2Engine] -> EXTRAINIT
[TRACE] 10/3/2014 21:24:06.333[OBD2Engine] SendCommand:ATSP 0
[DUMP ] 10/3/2014 21:24:06.394[OBD2Engine] BUFFER: OK
[TRACE] 10/3/2014 21:24:06.404[OBD2Engine] HandleReply: OK
[TRACE] 10/3/2014 21:24:06.413[OBD2Engine] -> EXTRAINIT
[TRACE] 10/3/2014 21:24:06.460[OBD2Engine] -> SENSOR_INIT
[TRACE] 10/3/2014 21:24:06.510[OBD2Engine] SendCommand:0100
[DUMP ] 10/3/2014 21:24:06.572[OBD2Engine] BUFFER: SEARCHING...
[DUMP ] 10/3/2014 21:24:11.798[OBD2Engine] BUFFER: SEARCHING...
UNABLE TO CONNECT
Please try using "Toyota CAN 21" profile (Open vehicle setttings, "Type" field)
- andypeterles
Cail,
I got some success by changing the "Vehicle Type" field to "Toyota" and "ELM Init Template" field to "5 Select protocol (ISO 14230-4 ...)".
But, I'm still in doubt when the MPG method because despite seeing the green circle at the bottom left, I only see information about the battery voltage. When accelerating the engine I did not get results on the screen.
Greetings!
Greetings!
Please try changing "Vehicle Type" to "Toyota CAN21", ELM init string to the same "Toyota CAN 21"
- andypeterles
Hi Cail,
I do not see the type of vehicle "Toyota CAN21" in combobox. I still lost as to MPG Method and changed MAF to MAP to EngineLoadSensor and nothing was shown beyond the battery voltage and 100% in fuel.
What are the parameters for the type "Toyota CAN21"? I can create a new profile ...
Follows the log generated this morning going to office:
Thank you for your patience!
[INFO] 18/3/2014 09:24:55.002[HOBD] HOBD 1.1.1 24.02.2012 14:34
[INFO] 18/3/2014 09:24:55.181[HOBD] Env: 3.5.7283.0
[INFO] 18/3/2014 09:24:56.990[HOBD] SN: 00540054-0034-0058-0030-545434583042445F3000
[INFO] 18/3/2014 09:24:57.591[HOBD] Vehicle: My Vehicle
[ERROR] 18/3/2014 09:24:57.805[HOBD] bad provider ecuxml://\Storage Card\Programas\HOBD1.1.1\ecu/obd2.ecuxml
[ERROR] 18/3/2014 09:24:57.948[HOBD] bad provider ecuxml://\Storage Card\Programas\HOBD1.1.1\user.ecuxml
[INFO] 18/3/2014 09:24:58.473[HOBD] system width: 800, height: 480
[INFO] 18/3/2014 09:24:58.486[HOBD] wa width: 800, wa height: 480
[INFO] 18/3/2014 09:25:00.332[HomePage] System DPI: 96
[INFO] 18/3/2014 09:25:00.344[HomePage] App DPI: 57
[INFO] 18/3/2014 09:25:00.350[HomePage] layout: 475x285
[INFO] 18/3/2014 09:25:00.359[HomePage] form: 242x293
[INFO] 18/3/2014 09:25:09.374[OBD2Engine] VersionInfo: ?ELM327 v1.5
[INFO] 18/3/2014 09:25:10.703[OBD2Engine] Sensor Init:BUS INIT: ERROR
[INFO] 18/3/2014 09:25:10.806[OBD2Engine] ProtocolId: 5
[ERROR] 18/3/2014 09:25:18.425[MILTrace] dataraw:
[ERROR] 18/3/2014 09:25:19.335[MILTrace] dataraw:
[ERROR] 18/3/2014 09:30:22.890[MILTrace] dataraw:
[ERROR] 18/3/2014 09:30:23.805[MILTrace] dataraw:
[ERROR] 18/3/2014 09:30:51.332[MILTrace] dataraw:
[ERROR] 18/3/2014 09:30:52.245[MILTrace] dataraw:
[INFO] 18/3/2014 09:32:50.832[HOBD] Vehicle: My Vehicle
[ERROR] 18/3/2014 09:32:50.865[HOBD] bad provider ecuxml://\Storage Card\Programas\HOBD1.1.1\ecu/obd2.ecuxml
at hobd.HomePage.#=q$5aNkDzW5Yv_NfXBIMtS9g==(#=qBMJMYTSMEd4NYTyE5bizaSWJYKefxFY8uHKOcuZrT7E= #=qPLL$o6ivrGQ$TGURQBtebQ==)
at hobd.HomePage.#=qezklVWnb8QTEN3hVS8vyyA==(#=qBMJMYTSMEd4NYTyE5bizaSWJYKefxFY8uHKOcuZrT7E= #=q1DWEi_LAzi$$qaE1XcaGHw==)
at hobd.HomePage.#=q4tqpcve_sKcQ8AjIfirf7A==(String #=qK_j2hSF6Ay5u4oM0XiX2$Q==, Sensor #=qa5Cg36WOWkrM4Y3mY7TpVQ==)
at hobd.HomePage.#=q_I3dem$m9sLQXAdirR2y9WCGjlGytReoUjWlZqj7rpg=.#=qNstp_U5bub1SYCDWE1meNmk4I9mq5O6dDaaUklvT6B0=(Point #=qbxJkkxklnS9qEbcPJWnZ3w==)
at Fleux.UIElements.UIElement.Tap(Point p)
at Fleux.UIElements.UIElement.<>c__DisplayClassa.<Tap>b__9(UIElement el)
at Fleux.UIElements.UIElement.TraverseHandle(Point start, Func`2 elementHandler)
at Fleux.UIElements.Panorama.PanoramaElement.Tap(Point p)
at Fleux.Controls.FleuxControl.<>c__DisplayClass1b.<Tap>b__19()
at System.Reflection.RuntimeMethodInfo.InternalInvoke(RuntimeMethodInfo rtmi, Object obj, BindingFlags invokeAttr, Binder binder, Object parameters, CultureInfo culture, Boolean isBinderDefault, Assembly caller, Boolean verifyAccess, StackCrawlMark& stackMark)
at System.Reflection.RuntimeMethodInfo.InternalInvoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean verifyAccess, StackCrawlMark& stackMark)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at System.Reflection.MethodBase.Invoke(Object obj, Object[] parameters)
at System.Windows.Forms.Control.TASK.Invoke()
at System.Windows.Forms.Control._InvokeAll()
at System.Windows.Forms.Control.InvokeHelper(Delegate method, Boolean fSynchronous, Object[] rgobjArgs)
at Fleux.Controls.FleuxControl.Tap(Point p)
at Fleux.Controls.Gestures.GesturesEngine.RaiseTap(Point p)
at Fleux.Controls.Gestures.GesturesEngine.MouseUp(Point point)
at Fleux.Controls.FleuxControl.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WnProc(WM wm, Int32 wParam, Int32 lParam)
at System.Windows.Forms.Control._InternalWnProc(WM wm, Int32 wParam, Int32 lParam)
at Microsoft.AGL.Forms.EVL.EnterMainLoop(IntPtr hwnMain)
at System.Windows.Forms.Application.Run(Form fm)
at Fleux.Core.FleuxApplication.Run(FleuxPage mainPage)
at #=qemyrhFzVjqMRdsGEWu$9lQ==.#=q5ir67gooYkvb4akERGWjRQ==(String #=qPWCaamlevqDfMrc2HMTttg==)
[ERROR] 18/3/2014 09:32:51.884[HOBD] bad provider ecuxml://\Storage Card\Programas\HOBD1.1.1\user.ecuxml
[INFO] 18/3/2014 09:32:52.048[HomePage] System DPI: 96
[INFO] 18/3/2014 09:32:52.054[HomePage] App DPI: 57
[INFO] 18/3/2014 09:32:52.060[HomePage] layout: 475x285
[INFO] 18/3/2014 09:32:52.068[HomePage] form: 800x480
[INFO] 18/3/2014 09:32:55.270[OBD2Engine] VersionInfo: ?ELM327 v1.5
[INFO] 18/3/2014 09:32:56.551[OBD2Engine] Sensor Init:BUS INIT: ERROR
[INFO] 18/3/2014 09:32:56.656[OBD2Engine] ProtocolId: 5
[ERROR] 18/3/2014 09:33:00.340[MILTrace] dataraw:
[ERROR] 18/3/2014 09:33:01.261[MILTrace] dataraw:
[ERROR] 18/3/2014 09:38:03.946[MILTrace] dataraw:
[ERROR] 18/3/2014 09:38:04.846[MILTrace] dataraw:
[ERROR] 18/3/2014 09:41:40.394[MILTrace] dataraw:
[ERROR] 18/3/2014 09:41:41.302[MILTrace] dataraw:
[INFO] 18/3/2014 09:46:22.435[HOBD] Vehicle: My Vehicle
[ERROR] 18/3/2014 09:46:23.159[HOBD] bad provider ecuxml://\Storage Card\Programas\HOBD1.1.1\ecu/obd2.ecuxml
[ERROR] 18/3/2014 09:46:23.467[HOBD] bad provider ecuxml://\Storage Card\Programas\HOBD1.1.1\user.ecuxml
[INFO] 18/3/2014 09:46:24.022[HomePage] System DPI: 96
[INFO] 18/3/2014 09:46:24.034[HomePage] App DPI: 57
[INFO] 18/3/2014 09:46:24.040[HomePage] layout: 475x285
[INFO] 18/3/2014 09:46:24.046[HomePage] form: 800x480
[ERROR] 18/3/2014 09:46:25.796[HomePage] Invalid Action: default
[INFO] 18/3/2014 09:46:29.247[OBD2Engine] VersionInfo: ?ELM327 v1.5
[INFO] 18/3/2014 09:46:30.522[OBD2Engine] Sensor Init:BUS INIT: ERROR
[INFO] 18/3/2014 09:46:30.620[OBD2Engine] ProtocolId: 5
[ERROR] 18/3/2014 09:46:34.471[MILTrace] dataraw:
[ERROR] 18/3/2014 09:46:35.377[MILTrace] dataraw:
Ah, sorry, you have to install latest beta version (1.1.95) to see that ECU.
- andypeterles
Cail,
I'm not finding the 1.1.95 beta version for download (for use with CarAudio with WinCE6). In the payment document only have links to version 1.1.1.
Thank you!
Thank you!
or license beta updates, you should enter your account page:
enter your email, account ID.
There you can download beta packages and copy files from ZIP into your current install folder.
Verify that your original useragent.dll file is in there (that is your license) Please do backup before use. Unofficial beta releases could contain some bugs or cause problems - use these with care.
Android owners could use account page to reset serial ID activations (in case theirs phone IDs were changed for some reason)
viewtopic.php?f=10&t=37
- andypeterles
Thanks kdika,
I sent a message to support to solve now for the license file, due to the "Licence Error 31370666 ..." when running HOBDRIVE.EXE at the media center device.
Regards!!
Regards!!
kdika писал(а):or license beta updates, you should enter your account page:
- andypeterles
Hi guys,
I have not received a return of support department but has found the useragent.dll file and reused in version 1.1.95-Beta folder...
Cail: The CAN21 setup did not work on my car!
Even getting into the mode of self-configuration, not an ideal configuration has been found.
In version 1.1.1 I select the protocol 5 for Toyota JDM and reaches to the noise from the ignition catching but not shows the sensor values.
In version 1.1.95-Beta I select the protocol 5 for Toyota JDM and only gives the sound of misfire.
Good job!
Looking forward!
Good job!
Looking forward!
This means your toyota has some custom unknown ECU.
Could you try choosing different "Toyota JDM" types? There are couple of elm init strings with "JDM" word in them - try choosing different items as well.
If that not help, please post you log.txt file here.
- andypeterles
Cail,
I can swap the "JDM" strings and test immediately or have to restart the HOBDrive?
And the auto-configuration mode? Should not find the right setting?
Hug!
Hug!
You may check for result immediately after pressing "OK" with new settings.
Autoconfig can't help in complex cases, but you may try it. Check if it can find any setting with some data except voltage. Make sure you have ignition/engine on.
- andypeterles
Unsuccessful tests. I'm expecting new device purchased at DealExtreme website.
- andypeterles
Hello Cail,
I received my new device and everything worked!
See below:
Regards!!
See below:
[INFO] 25/6/2014 09:35:18.013[HOBD] HOBD 1.1.97 Thu 04/17/2014 03:18 AM
[INFO] 25/6/2014 09:35:18.230[HOBD] Env: 3.5.7283.0
[INFO] 25/6/2014 09:35:20.299[HOBD] SN: 00540054-0034-0058-0030-545434583042445F3000
[INFO] 25/6/2014 09:35:22.222[HOBD] Vehicle: My Vehicle
[ERROR] 25/6/2014 09:35:23.506[HOBD] File Not Found in ecuxml://\Storage Card\Programas\HOBD1.1.97\user.ecuxml : Could not find file '\Storage Card\Programas\HOBD1.1.97\user.ecuxml'.
[INFO] 25/6/2014 09:35:24.719[HOBD] system width: 800, height: 480
[INFO] 25/6/2014 09:35:24.734[HOBD] wa width: 800, wa height: 480
[INFO] 25/6/2014 09:35:25.840[HOBDAll] hobDrive lhxgs6496757<=8=4 - Erhivwsr$Evevmti$Tixivpi
[INFO] 25/6/2014 09:35:26.957[HomePage] System DPI: 96
[INFO] 25/6/2014 09:35:26.971[HomePage] App DPI: 57
[INFO] 25/6/2014 09:35:26.978[HomePage] layout: 475x285
[INFO] 25/6/2014 09:35:26.988[HomePage] form: 242x293
[INFO] 25/6/2014 09:35:38.059[OBD2Engine] VersionInfo: ELM327 v1.5
[INFO] 25/6/2014 09:35:38.505[OBD2Engine] Sensor Init:SEARCHING...
41 00 BE 1F B8 13
[INFO] 25/6/2014 09:35:38.568[OBD2Engine] ProtocolId: 6
[INFO ] 25/6/2014 09:35:40.666[MILTrace] dataraw: 43 00
[INFO ] 25/6/2014 09:35:40.760[MILTrace] dataraw: 47 00
[INFO ] 25/6/2014 09:35:50.974[MILTrace] dataraw: 43 00
[INFO ] 25/6/2014 09:35:51.092[MILTrace] dataraw: 47 00
[INFO ] 25/6/2014 09:35:52.002[MILTrace] dataraw: 43 00
[INFO ] 25/6/2014 09:40:51.174[MILTrace] dataraw: 47 00
[INFO ] 25/6/2014 09:40:52.208[MILTrace] dataraw: 43 00
[INFO ] 25/6/2014 09:45:51.357[MILTrace] dataraw: 47 00
[INFO ] 25/6/2014 09:45:52.403[MILTrace] dataraw: 43 00
[INFO ] 25/6/2014 09:50:51.556[MILTrace] dataraw: 47 00
[INFO ] 25/6/2014 09:50:52.456[MILTrace] dataraw: 43 00
Glad for you!
