Different consumed fuel calculate between sensors.
Common discussion area
Papamaci » 14 мар 2015, 13:37
Hi,
I'd like know what's the reason of different fuel consumption between the 'Fuel Consumed' and 'Fuel in Tank' sensors.
'Fuel Consumed' calculate 32.86 L consumed fuel, the 'Fuel in Tank' does 28.62 L
I use full version of HD 1.1.1
Re: Different consumed fuel calculate between sensors.
cail » 23 мар 2015, 19:59
Papamaci,
"Fuel Consumed" is a total amount of fuel you spent in current trip cycle/period.
"Fuel in tank" is your current estimated amount of fuel you have in tank.
These two are absolutely unrelated parameters.
Papamaci » 02 апр 2015, 10:33
Cail,
Understood it, but reseted both sensors when load fuel. So current trip is 'Fill Up'.
"Fuel Consumed" : 0L
"Fuel in Tank" 41L (100%)
Subsequently, the differences arise. I think in this case should be the same as measured by the two sensors quantities.
Thank you in advance for your response.
P.M.
Sorry for my english. (Google translate.)
