Medianav dacia installation bt elm327
Hello, I would like to test your software on my gps medianav Dacia car.
it is equipped with a MIPSII proceseur with WinCE 6. I have a bluetooth lm327 + usb bt.
I read viewtopic.php?f=5&t=30, do you have a consistent MIPSII dll ?
What hobddrive file should I download for my system?
bonjour, j'aimerais bien tester votre logiciel sur le gps medianav de ma voiture Dacia.
il est équipé d'un proceseur MIPSII avec WinCe 6. Je dispose d'un bluetooth lm327 + bt usb.
j'ai lu viewtopic.php?f=5&t=30, avez-vous une dll compatible MIPSII ?
Quel fichier hobddrive dois-je télécharger pour mon système ?
Re: Medianav dacia installation bt elm327
Hello, thank you but does not work, I hobd.exe click and nothing happens
new link: viewtopic.php?f=4&t=120&p=6706&hilit=MIPS#p6706
try two versions
try two versions
the framework that starts correctly, but an hourglass appears and nothing when I run hobd.exe
Do you have any log.txt file being created in program folder?
Hello, no log.txt file created in program folder
Bonjour, j'ai réussie à installer hobdrive sur ma dacia logan mcv2 en changeant les drivers bluetooth officiels. Cependant je rencontre un problème de lenteur, les information s'affiche toutes les 30 secondes, voir plus
. il existe une vidéo où c'est plus rapide. https://youtu.be/z_UsGoqq6IE
voici mon log http://www95.zippyshare.com/v/pgtP9cub/file.html
Hello, I managed to install my renault loganMCV2 hobdrive changing the official bluetooth drivers. However I encounter a problem of slowness, the information is displayed every 30 seconds, see
there is a video where it's faster. https://youtu.be/z_UsGoqq6IE
here is my log http://www95.zippyshare.com/v/pgtP9cub/file.html
![Плачет или сильно расстроен :cry:](./images/smilies/icon_cry.gif)
buldo, could you try to make sure there is no software running beside hobdrive? Unfortunately nothing we can do here, that could be some clutch between hobdrive and your system.
there is nothing else that runs behind.
Is possicle limit playback of pid to only 1 or 2? I would earn maybe responsiveness.
you may try insert ELM reading delay (in connection settings). That will make hobdrive to read slowly.
But honestly I'm in doubt this is the reason.
Do you see the slowness without connection to the ELM?
Hello Buldo, Gianluca are an Italian guy I would kindly to know how to install Hobd of Medianav installed on Dacia Duster with mediaskinv2 installed, because I'm implementing on a skin, I tried installing it but when I click on Hobd.exe nothing happens. Kindly help me to solve everything. Thank you
Bonjour Buldo, Gianluca sont un Italien je vouloir savoir comment installer Hobd de Medianav installé sur Dacia Duster avec mediaskinv2 installés, parce que je suis mise en œuvre sur une peau, j'ai essayé de l'installer mais quand je clique sur Hobd.exe rien ne se passe. Veuillez me aider à résoudre tous les problèmes. merci![Плачет или сильно расстроен :cry:](./images/smilies/icon_cry.gif)
Postby buldo » 22 Jun 2016, 21:06
buldo
gianlgor
Top
buldo
gianlgor
Top
Hello Cail, Gianluca are an Italian guy I would kindly to know how to install Hobd of Medianav installed on Dacia Duster with mediaskinv2 installed, because I'm implementing on a skin, I tried installing it but when I click on Hobd.exe nothing happens. Kindly help me to solve everything. Thank you
buldo
gianlgor
Top
buldo
gianlgor
Top
Some of our users have provided Renault specific .netcf package, working with hobdrive:
http://hobdrive.com/download/hobdrive/h ... navrus.zip
You should extract hobdrive distribution above these files.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 13
