Suzuki Kei (JDM)
Suzuki Kei (JDM)
theamila » 09 янв 2017, 13:56
Hi,
I have a Suzuki Kei Car (JDM) , with K6A engine. Hobdrive demo app is unable to connect to it. I'm sure that my adapter is working, because couple of other apps can connect to it.
I found out that it uses Suzuki K-Line protocol. But I couldn't find a similar one. I tried with all other available Suzuki car settings available in app, but no success.
Can you help on what settings to use? Is it supported in paid version?
Thanks..
Re: Suzuki Kei (JDM)
kdika » 10 янв 2017, 15:38
Hi.
Screens/Settings/Vehicle settings:
- vehicle type - Suzuki_JDM_KWP
- ELM Init Template - SuzukiKWP
theamila » 14 янв 2017, 19:48
Hi kdika,
Thank you very much for your reply. I have tried tried that, but not successful.
It gives connection error threshold error.
Any idea why?
kdika » 16 янв 2017, 11:37
theamila писал(а):I'm sure that my adapter is working, because couple of other apps can connect to it.
What app?
theamila писал(а):I found out that it uses Suzuki K-Line protocol
29/5000
Sure, that is not used CAN protocol?
Screens/Settings/Vehicle settings/System settings/Logging level - trace
try again with the auto connection setup
put the file log.txt
theamila » 16 янв 2017, 14:51
What app?
SZ Viewer - https://play.google.com/store/apps/details?id=com.malykh.szviewer.android
OBD Driver - https://play.google.com/store/apps/details?id=com.obddriver
Both apps can connect successfully.
I'll post the log file too.
Thanks... :)
theamila » 16 янв 2017, 18:33
Log file also attached...
kdika » 17 янв 2017, 02:17
put the 2 file log.txt from
1 Init string:
ATH1; ATSP5; ATAL; ATIB10; ATSH8101F1; ATST10; ATSW00; ATFI; 1A8E; 1A9A; 2100;
2. Init string:
theamila » 18 янв 2017, 06:50
Hi,
Log Files Attached...
Thanks for your effort... :) :)
log2.txt
log1.txt
kdika » 22 янв 2017, 23:31
put the log.txt from Init string:
ATTP5; ATAL; ATIB10; ATSH8101F1; ATKW0; ATST32; ATAT1; ATFI; ATKW; ATSH8101F1; ATSW00; 1A8A; 2100; 1A8E; 1A9A;
theamila » 23 янв 2017, 12:49
Log file attached...
kdika » 23 янв 2017, 22:39
1. enable Developer Options
2. enable bluetooth HCI snoop log
3. connect auto app sz viewer
4. attache file btsnoop_hci.log
theamila » 30 янв 2017, 19:04
Got the Bluetooth log in the way you have mentioned... :)
btsnoop_hci.log
kdika » 31 янв 2017, 01:31
1. replace file hobd/ecu
2. put the file log.txt from
- Init string:
ATH1; ATTP5; ATAL; ATIB10; ATSH8101F1; ATST32; ATSW00; ATFI; ATSH8001F1; 1A8A; 1A8E; 1A9A; 1A91; 1A99; 2100; 2101; 18000000;
Suzuki_JDM_KWP.ecuxml
theamila » 31 янв 2017, 15:33
Finally seems to be connected without errors, though the displayed values are wrong.  :) :)
kdika » 31 янв 2017, 17:53
1. while make this line
2. All-Union and examined the amendments, if necessary.
theamila » 07 фев 2017, 06:33
Thank you very much... :D
Most of the things seems to work fine with this setting...
But diagnostics (DTC) screen stuck at initializing, and not seems to read codes.
So is it a problem with ecuxml file? will a future version will replace it?
cail » 07 фев 2017, 15:59
Theamila,
Demo version will not read out DTCs for Custom ECUs. You have to purchase hobdrive license for this.
With the next beta update there'll be a separate vehicle ECU type for your Suzuki.
theamila » 13 фев 2017, 09:44
Sure.. I will definitely purchase. This is the best app of this category that I have tried.. :D
theamila » 27 фев 2017, 07:13
Now I have the full version. Everything else seems fine, but still the DTC doesn't show anything. WHy?
kdika » 27 фев 2017, 09:51
Insert into ecuxml code:
  <parameter id="MIL">
    <class>KWPMILSensor</class>
    <raw>18000000</raw>
  </parameter>
  <parameter id="PMIL">
    <class>KWPPMILSensor</class>
    <raw>18000000</raw>
  </parameter>
  <parameter id="ClearDTC">
    <raw> 140000 </raw>
  </parameter>
След.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 10
