Suzuki Kei (JDM)
Suzuki Kei (JDM)
Hi,
I have a Suzuki Kei Car (JDM) , with K6A engine. Hobdrive demo app is unable to connect to it. I'm sure that my adapter is working, because couple of other apps can connect to it.
I found out that it uses Suzuki K-Line protocol. But I couldn't find a similar one. I tried with all other available Suzuki car settings available in app, but no success.
Can you help on what settings to use? Is it supported in paid version?
Thanks..
Thanks..
Re: Suzuki Kei (JDM)
Hi.
Screens/Settings/Vehicle settings:
- vehicle type - Suzuki_JDM_KWP
- ELM Init Template - SuzukiKWP
Hi kdika,
Thank you very much for your reply. I have tried tried that, but not successful.
It gives connection error threshold error.
Any idea why?
Any idea why?
What app?theamila писал(а):I'm sure that my adapter is working, because couple of other apps can connect to it.
29/5000theamila писал(а):I found out that it uses Suzuki K-Line protocol
Sure, that is not used CAN protocol?
Screens/Settings/Vehicle settings/System settings/Logging level - trace
try again with the auto connection setup
put the file log.txt
SZ Viewer - https://play.google.com/store/apps/deta ... er.androidWhat app?
OBD Driver - https://play.google.com/store/apps/deta ... .obddriver
Both apps can connect successfully.
I'll post the log file too.
Thanks...
put the 2 file log.txt from
1 Init string:
ATH1; ATSP5; ATAL; ATIB10; ATSH8101F1; ATST10; ATSW00; ATFI; 1A8E; 1A9A; 2100;
2. Init string:
1 Init string:
2. Init string:
Hi,
Log Files Attached...
Thanks for your effort...
put the log.txt from Init string:
ATTP5; ATAL; ATIB10; ATSH8101F1; ATKW0; ATST32; ATAT1; ATFI; ATKW; ATSH8101F1; ATSW00; 1A8A; 2100; 1A8E; 1A9A;
1. enable Developer Options
4. attache file btsnoop_hci.log
2. enable bluetooth HCI snoop log
3. connect auto app sz viewer4. attache file btsnoop_hci.log
Got the Bluetooth log in the way you have mentioned...
btsnoop_hci.log
- (80.74 КБ) 2282 скачивания
1. replace file hobd/ecu
2. put the file log.txt from
- Init string:
ATH1; ATTP5; ATAL; ATIB10; ATSH8101F1; ATST32; ATSW00; ATFI; ATSH8001F1; 1A8A; 1A8E; 1A9A; 1A91; 1A99; 2100; 2101; 18000000;
- Init string:
Suzuki_JDM_KWP.ecuxml
- (4.68 КБ) 2188 скачиваний
Finally seems to be connected without errors, though the displayed values are wrong.
Log file attached...
- (371.39 КБ) 2262 скачивания
1. while make this line
2. All-Union and examined the amendments, if necessary.
Thank you very much...
Most of the things seems to work fine with this setting...
But diagnostics (DTC) screen stuck at initializing, and not seems to read codes.
So is it a problem with ecuxml file? will a future version will replace it?
Theamila,
Demo version will not read out DTCs for Custom ECUs. You have to purchase hobdrive license for this.
With the next beta update there'll be a separate vehicle ECU type for your Suzuki.
Sure.. I will definitely purchase. This is the best app of this category that I have tried..
Now I have the full version. Everything else seems fine, but still the DTC doesn't show anything. WHy?
Insert into ecuxml code:
<parameter id="MIL">
<class>KWPMILSensor</class>
<raw>18000000</raw>
</parameter>
<parameter id="PMIL">
<class>KWPPMILSensor</class>
<raw>18000000</raw>
</parameter>
<parameter id="ClearDTC">
<raw> 140000 </raw>
</parameter>
