Hi, Thanks for this Cali.
I have one question. I am hanging around the UI for my own personal preference just now. I am removing the russian price symbol and trying to insert the british £ symbol to use and display instead.
No matter how I try and place the £ into the config file on screen when HOBD is running it will not diplay the symbol just a square in it's place.
How would I get the £ symbol inserted. Do I have to call a specific ASCII character in machine code?
Thanks in advance.
Waz.
Currency setup (£)
Re: Layout manual edit guide
Have you tried to enter fuel price dialog, and enter this symbol £ directly in there? This should work.
that worked!!
Excellent, thank you! I have been wanting to sort that since I installed the full programme! Perhaps you should write this functionality for others in a sticky note? I know people in the UK or say Japan would appreciate it!
Fantastic programme by the way. I have the android version also and I am very impressed with the port. Of course on a fast android Dynavin carp and a can bus connection it runs very very smoothly - almost OEM smooth. So, sir - I congratulate you on a job well done!
Well worth the money.
Re: Currency setup (£)
Thanks for the good words, working handly to improve it further.
Will clarify this better in users manual.
In iphone, you can not set to other currencies. For example, how to I set up TL (Turkish Lira).
Thank.
Thank.
think thats a limitation now. Will work on this.
