hi
good day
i have Car Kia Pride ( KIA Avella ) included ECU Siemens 1.3i
i try connect with ELM USB version FTDI Chip . But Do not connect and communicated my care and hobdrive android version
also not included template kia/ pride or Avella Car . If possible please add this model to hobdrive
But i can connect with original software hi scan pro pc base version
Can you hellp me fo solve this problem ?
Iranian Care Connect
Re: Iranian Care Connect
Hi.
What year is the car?
Hi
my car year is after 1996 . i mean is 2003
Then you basically should try to connect with "Standard OBD" profile.
hi
thank you
do you mean this page ?
https://www.overpic.net/viewer.php?file ... 4u4wfu.jpg
and please tell me how to setting other field . for example
elm lnit template
elm lnit string
MPG method
please help Full
thank you
thank you
elm lnit template
elm lnit string
MPG method
please help Full
thank you
hicail писал(а):Then you basically should try to connect with "Standard OBD" profile.
i try to connect this model . But not connect . also change other protocol and test many vehicle model . not response on hobdrive . But very good work with original software on desktop windows
i think my care not obd2 standard . maybe obd1 . but i don't know witch protocol using .
please tell me how to connect hobdrive or how to use hobdrive on this care .
for Remind . my care very simple kia avella because on original software when use kia avella section
is ok and connect very well
i have question , Is there any other protocol? Except all obd2 iso ?
Can you help me for run this way ?
can do scan k line signal for know with protocol use .? and use on hobdrive software ?
excuse me for bad English typing
thank you and best regards
Hi.
What is soft?hamed-pc писал(а): But very good work with original software on desktop windows
maybehamed-pc писал(а):i think my care not obd2 standard . maybe obd1
Hikdika писал(а):Hi.
What is soft?hamed-pc писал(а): But very good work with original software on desktop windowsmaybehamed-pc писал(а):i think my care not obd2 standard . maybe obd1
The soft Hi scan Pro Desktop windows .
if this ecu obd1 How to connect with hobdrive ?
elm not support obd1
hi
what do you mean of eml ? inside elm adapter have FT Chip and level converter ic . i have this adapter work on my car but with original soft well , and support obd2 all of Asian Korean and European Care up to 2011 .
i think this adapter should be work with hobdrive and mycar . If Config and setting k line signal only receive for RX pin . do not send signal with TX pin
Hi.hamed-pc писал(а):hi
Elm adapter has internally programmed chip: https://www.elmelectronics.com/wp-conte ... M327DS.pdf
You probably have an ordinary k-line adapter. With such adapters hobdrive does not work.hamed-pc писал(а): i have this adapter work on my car but with original soft well , and support obd2 all of Asian Korean and European Care up to 2011 .
hi
thank you answer me
i Have Interface VAG 409.1 this picture
Do you mean i need programmable chip for example ELm327 CHIP ?
Can i use STN1110 ?
please send me with model of adapter compatible hobdrtive . i need see chip for this model adapter becuse i want to make with myself . because i'm living in Iran . i have not this model adapter on store
thank you
thank you answer me
Can i use STN1110 ?
thank you
