Suzuki Jimny M13A engine 2017
ahaghshenas
Сообщение ahaghshenas »
Hello,
OBD dongle : OBDLINK MX
I have read the forum for settings with other Suzuki cars, I have similar issues!
I can only connect to my car with SZ viewer app, with Hobdrive there is an error (bus init error) when connecting.
Settings used
Screens/Settings/Vehicle settings:
- vehicle type - Suzuki_JDM_KWP11
- ELM Init Template - SuzukiKWP
I have attached a trace log file and a btsnoop of SZ viewer
btsnoop_hci.log
(514.42 КБ) 2479 скачиваний
logcat.txt
(33.98 КБ) 2621 скачивание
Re: Suzuki Jimny M13A engine 2017
Hello.
You have a new car with a CAN bus
ahaghshenas писал(а):Settings used
Try it like this
- vehicle type - Standard OBD2
- ELM Init Template - select protocol 6
Send me log.txt (logging level trace)
ahaghshenas
Thanks for your quick response.
I have attached the files.
I have a different error now, error timeout
logcat.txt
(102.66 КБ) 2652 скачивания
(741.11 КБ) 2465 скачиваний
Make changes.
- ELM Init - ATSP6; ATAL; ATSH7E0; ATST32; ATAT0; 1A8A; 1A8E; 1A9A; 1A91; 1A99; 2100; 2101;
the start of the system log is not necessary.
Run auto and run programm.
Send log.txt.
PS. Sensor values may not be correct
ahaghshenas
New log file attached
Yes it connected with wrong values.
Thanks
(963.51 КБ) 2512 скачиваний
excellent
it takes several days to finalize the protocol
how will the test version be ready - I'll write here
ahaghshenas
Thank you for your help.
Look forward to receive the test version
Install demo version 1.5.38: https://drive.google.com/file/d/1oejYpk ... sp=sharing
- vehicle type - Suzuki_JDM_CAN
read/clear dtc work in full version
MartyGek
Сообщение MartyGek »
Hi I want 04-05 ZX10R Kawasaki front forks for my Suzuki GSX-R 1100 -94.
Is there anyone which would have done this before?
Thanks
