Hello,
OBD dongle : OBDLINK MX
I have read the forum for settings with other Suzuki cars, I have similar issues!
I can only connect to my car with SZ viewer app, with Hobdrive there is an error (bus init error) when connecting.
Settings used
Screens/Settings/Vehicle settings:
- vehicle type - Suzuki_JDM_KWP11
- ELM Init Template - SuzukiKWP
I have attached a trace log file and a btsnoop of SZ viewer
Suzuki Jimny M13A engine 2017
btsnoop_hci.log
- (514.42 КБ) 2543 скачивания
logcat.txt
- (33.98 КБ) 2687 скачиваний
Re: Suzuki Jimny M13A engine 2017
Hello.
- vehicle type - Standard OBD2
- ELM Init Template - select protocol 6
Send me log.txt (logging level trace)
You have a new car with a CAN busSuzuki Jimny M13A engine 2017
Try it like thisahaghshenas писал(а):Settings used
Thanks for your quick response.
I have attached the files.
I have a different error now, error timeout
logcat.txt
- (102.66 КБ) 2731 скачивание
- (741.11 КБ) 2530 скачиваний
Make changes.
- ELM Init - ATSP6; ATAL; ATSH7E0; ATST32; ATAT0; 1A8A; 1A8E; 1A9A; 1A91; 1A99; 2100; 2101;
the start of the system log is not necessary.
Run auto and run programm.
Send log.txt.
PS. Sensor values may not be correct
Send log.txt.
New log file attached
Yes it connected with wrong values.
Thanks
Thanks
- (963.51 КБ) 2590 скачиваний
excellent
it takes several days to finalize the protocol
how will the test version be ready - I'll write here
Thank you for your help.
Look forward to receive the test version
Install demo version 1.5.38: https://drive.google.com/file/d/1oejYpk ... sp=sharing
- vehicle type - Suzuki_JDM_CAN
read/clear dtc work in full version
Hi I want 04-05 ZX10R Kawasaki front forks for my Suzuki GSX-R 1100 -94.
Is there anyone which would have done this before?
Thanks
Thanks
