Hi! Im using the hobd evaluation version in a GM corsa C. Most of the readings are ok, but I cannot read the fuel level. This is a limitation of evaluation version or I have to configure it?
thanks!
Cannot read fuel level
Re: Cannot read fuel level
Real fuel level is supported only on a small percent of vehicles.
Both demo and full version support "estimated" fuel level by default: you should first setup your current level, enter all fueling records - then hobdrive will calculate current level for you.
I know these may be too much to ask for you to help me with these sensors, so I would like to thank you in advance even if there are not enough information for you to get going with it or there are too complicated to merage into hobdrive.
gre preparation gre preparation
ged classes ged classes
itil training itil training
network+ book network+ book
ged study guide ged study guide
