İnstalling on Navking i66
xiuh » 12 сен 2012, 00:01
Hi,
i got navking i66 navigation unit.
deleted its rıute66 and installed igo primo.
now want to install hobd but cant do it.
could you help me pls about installing hobd to it ?
- device gives .net error coz it has .net 2.0. Tried to upgrade 3.5 but couldnt do.
how can i do ?
and can you give me some tricks about making it desktop free (try to see wince desktop)
Thanks for your helps.
Sincerly.
Re: İnstalling on Navking i66
cail » 12 сен 2012, 08:57
xiuh, have you tried using hobd-standalone package? this normally helps.
xiuh » 12 сен 2012, 11:07
yes Cail,i tried but didnt work.
But will try again,and let you know if it works.
Thanks.
cail » 12 сен 2012, 11:36
There is also a .net37 package on site in Downloads section. Try it - some people report it works.
BTW, is your device arm or mips? For mips you should have another .net35 package.
xiuh » 02 окт 2012, 22:35
Hi Cail,
i can use standalone package but got issues about connection with elm bluetooth adapter.
So checked this forum ;
viewtopic.php?f=5&t=30
want to try to use bluetooth dongle for connection with elm.
added registry entry then run the otgloader.exe
selected otg device mode and it prompted,clicked ok.
For now,everything is fine but get a huge disappointment..
that is my device no longer connects to pc via neither activesync nor massstorage..
now my device is working on usb only for charge.. no other connection with pc.
could you help me about this sitiuation pls ?
Thanks.
cail » 03 окт 2012, 10:12
That's normal- you can't use your device as a slave, when it is in usb host mode.
you should switch it back to slave with the same tool.
xiuh » 03 окт 2012, 12:05
Thanks for your reply,
I tried that u mentioned but still no change occurs.
Selecting otg device mode but still no connection with pc.
Or Do i miss anything about it ?
Thanks
cail » 03 окт 2012, 13:39
In OTGLoader you should select not device, but slave mode. To revert back to usb-slave mode. Are you sure you did this?
xiuh » 03 окт 2012, 14:40
when i run the otgloader.exe,there is 2 options appears ;
OTG Host
OTG Device
and there is no more options. select otg device the press the button under these selections,a new window opens and shows some written in russian(i think its russian but not sure).
cail » 03 окт 2012, 16:35
Sorry, then you doing everything right, OTG Device should switch device back into slave mode. It strange it does not help. could you share a screenshot of a message? that could be an error..
xiuh » 03 окт 2012, 22:41
now no errors occur but still same sitiuation continues..
i'm giving my usbotg1.reg file as an attachment,
so please could you check it ?
and can access all areas of my device via totalcommander(not from pc,using on device)
btw i cant erase or rename usbotg1 entry in registry of my device,only can copy,move and replace
thanks for your helps
USBOTG1.rar
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 22
