Vehicle compatibility
Please inform us if you have a OBD2 compatible vehicle, not listed in our list:
http://hobdrive.com/faq/obd2vehicles.html
Re: Vehicle compatibility
2006 Chevorlet Optra 5 LS
(although I cant see why it wouldn't work on any Chevy Optra model)
I have a cheap chinese gps running HobDrive linked via Bluetooth to the car.
The car is a Alfa Romeo Guilietta JTDM 2ltr 2011 model, I have only just tried it, but so far it all seems to work ok.
The only gauge that is not reading is the outside temperature, but I have not set any of the parameters yet. I will post more information when I have given it a full test.
hi,
tried to get data out from my vehicle OBD2 socket with ELM transmitter - Subaru Legacy 2000 2,5 AT
no success, swapped ELM transmitters etc, nothing.
will send you VIN code on private mail, if you interested.
Ralf
Ralf
I posted on here some months back about getting a Win CE 6.0 Chinese GPS running with Hobdrive, but gave up as the OS was so severely stripped and refused to work with a USB or BT OBDII adapter.
learn-language learn language | learn language online
learn-language learn language - learn spanish language
Hi All,
I have a 2006 Chevorlet Equinox (US market) using 11bit CAN bus. HobDrive works, I just wished that more sensors were implemented in hobdrive. ie EGR Error, Commanded EGR, Catalyst temp,total misfire(which is very useful when diag trouble on the car). ...
Thanks for the info.
There are some of them on "all sensors" page. You can check it out.
Hi Cail,
Some of them worked before, but since upgraded to beta 1182, none of the sensors worked in the all sensors page. Aren't they all for toyoto can21?
You should not see any of toyota can21 sensors unless you've selected this ECU explicitly. Please check your settings.
Is possible to connect Passat B5 1997?
I try HD 1.1.1 and connect to ELM but can read only battery voltage. I try many configuration but can read only this.
Unfortunately the year is too old, vehicles of these years do not support OBD2 specification.
ralf.mars21202 писал(а):hi,
Ralf
hobdrive works with my subaru legacy 2000 USA 2,5 manual gear in russia perfectly =)
HobDrive(1.6.28_лицензия) + RedMi7 + Elm327 BluetoothV1.5 + Discovery3 4.4
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 24
