HOBD just show only Battery Voltage.
Hi.
I have one Buletooth OBD2. I test HOBD on PDA Wince 5.0 and Winmobile 6.1 phone . Everything work ok in 2 days but today, it just shows only Battery Voltage. I buy other new Bluetooth OBD2 and it still shows only Battery Voltage.
I had remove (use clean remove software) and reinstall HOBD on WinCE and on Winmobile but it still shows only Battery voltage!
May HOBD just for use in some day or some times ? Or ECU lock signal out over obd2 ?!
Re: HOBD just show only Battery Voltage.
You most probably have changed ECU type or other settings in "vehicle settings" dialog.
Try to choose clean profile. What vehicle do you have?
My car is Ford Mondeo V6 2005 (MK3).
For testing before order full ver, i install on both WinCE device and WinMobile 6.1 hpone. I setup Common / OBD2 and it work ok. I dont change any thing and today it just show Battery Voltage on both two devices !
have you used your ELM adapter with some other software? External software could change persistent settings in an adapter.
Try choosing "ELM Reset" in ELM init template field ("vehicle settings" dialog)
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 19
