Gear shift indicator
Common discussion area
zakarevicius » 20 мар 2013, 21:07
Is there a possibility to insert Gear shift indicator in to Hobdrive?
Re: Gear shift indicator
cail » 20 мар 2013, 21:43
Hello. Right now only toyota vehicles support custom sensors with current shift position.
We evaluate an option to introduce calculated shift position, based on transmission conversion numbers.
zakarevicius » 21 мар 2013, 17:14
I am not sure if you understand what I wanted to say. Is there a possibility to install HobDrive function, which recommend when shift gear. For example from 5 to 6 and so on.
Thanks for answer.
zakarevicius » 21 мар 2013, 17:57
And one more thing. I think that it would be useful for hobd user function which let to reset counter (km counter) when change oil.
