Core.datetime sensor
yillw
Сообщение yillw »
Hi Cail,
Kindly advise on how to convert or setup the return and display from the core.datetime sensor ID, so that it can display the tine in 12 hr format.
Thanks in advance.
Re: Core.datetime sensor
Ahh, will put this pending into next update. There is no such option now.
Alton0
Re: Vehicle compatibility
Сообщение Alton0 »
In next beta update there'll be "time12" and "datetime12" custom-units attribute option values.
yillw
Сообщение yillw »
Hi Cail,
I would like to report that even in beta 1187, the time12 attribute is still showing up wrong, that is at noon time 12:00 it should be 12:00pm not 12:00am.
Oh, I also fofund out that if I use screen->exit, Hobdrive doesn't exit properly, it remains in memory. However, if I use Screen->Settings->System Settings-> and then hit OK in the "Exit hobdrive and restart " popup screen, then Hobdrive exit properly! Kindly check this out, may be it could slove the problem for some of the wince device like mine. Thanks in advance.
