Vehicle compatibility
cail » 15 дек 2011, 16:05
Please inform us if you have a OBD2 compatible vehicle, not listed in our list:
http://hobdrive.com/faq/obd2vehicles.html
Re: Vehicle compatibility
smitty124 » 27 апр 2012, 07:49
2006 Chevorlet Optra 5 LS
(although I cant see why it wouldn't work on any Chevy Optra model)
hgt » 02 окт 2012, 16:26
I have a cheap chinese gps running HobDrive linked via Bluetooth to the car.
The car is a Alfa Romeo Guilietta JTDM 2ltr 2011 model, I have only just tried it, but so far it all seems to work ok.
The only gauge that is not reading is the outside temperature, but I have not set any of the parameters yet. I will post more information when I have given it a full test.
ralf.mars21202 » 24 мар 2013, 01:06
hi,
tried to get data out from my vehicle OBD2 socket with ELM transmitter - Subaru Legacy 2000 2,5 AT
no success, swapped ELM transmitters etc, nothing.
will send you VIN code on private mail, if you interested.
Ralf
Alton0 » 22 июл 2013, 14:39
I posted on here some months back about getting a Win CE 6.0 Chinese GPS running with Hobdrive, but gave up as the OS was so severely stripped and refused to work with a USB or BT OBDII adapter.
yillw » 28 июл 2013, 05:17
Hi All,
I have a 2006 Chevorlet Equinox (US market) using 11bit CAN bus. HobDrive works, I just wished that more sensors were implemented in hobdrive. ie EGR Error, Commanded EGR, Catalyst temp,total misfire(which is very useful when diag trouble on the car). ...
cail » 05 авг 2013, 05:20
Thanks for the info.
There are some of them on "all sensors" page. You can check it out.
yillw » 06 авг 2013, 13:15
Hi Cail,
Some of them worked before, but since upgraded to beta 1182, none of the sensors worked in the all sensors page. Aren't they all for toyoto can21?
cail » 07 авг 2013, 22:53
You should not see any of toyota can21 sensors unless you've selected this ECU explicitly. Please check your settings.
phuarchi » 27 сен 2013, 21:06
Is possible to connect Passat B5 1997?
I try HD 1.1.1 and connect to ELM but can read only battery voltage. I try many configuration but can read only this.
cail » 29 сен 2013, 05:39
Unfortunately the year is too old, vehicles of these years do not support OBD2 specification.
boow » 18 ноя 2013, 18:24
ralf.mars21202 писал(а):hi,
Ralf
hobdrive works with my subaru legacy 2000 USA 2,5 manual gear in russia perfectly =)
HobDrive(1.6.28_лицензия) + RedMi7 + Elm327 BluetoothV1.5 + Discovery3 4.4
