--------- beginning of /dev/log/system
D/ActivityThread( 3833): BIND_APPLICATION handled : 0 / AppBindData{appInfo=ApplicationInfo{42661538 hobdrive.android}}
D/ActivityThread( 3833): ACT-AM_ON_RESUME_CALLED ActivityRecord{426630d8 token=android.os.BinderProxy@426628a8 {hobdrive.android/hobdroid.SplashActivity}}
D/ActivityThread( 3833): ACT-LAUNCH_ACTIVITY handled : 0 / ActivityRecord{426630d8 token=android.os.BinderProxy@426628a8 {hobdrive.android/hobdroid.SplashActivity}}
D/ActivityThread( 3833): SVC-Creating service: CreateServiceData{token=android.os.BinderProxy@4267f548 className=hobdroid.HobdriveService packageName=hobdrive.android intent=null}
D/ActivityThread( 3833): SVC-CREATE_SERVICE handled : 0 / CreateServiceData{token=android.os.BinderProxy@4267f548 className=hobdroid.HobdriveService packageName=hobdrive.android intent=null}
D/ActivityThread( 3833): SVC-SERVICE_ARGS handled : 0 / ServiceArgsData{token=android.os.BinderProxy@4267f548 startId=1 args=Intent { act=hobdroid.HobdriveService }}
D/ActivityThread( 3833): ACT-AM_ON_PAUSE_CALLED ActivityRecord{426630d8 token=android.os.BinderProxy@426628a8 {hobdrive.android/hobdroid.SplashActivity}}
D/ActivityThread( 3833): ACT-PAUSE_ACTIVITY handled : 1 / android.os.BinderProxy@426628a8
D/ActivityThread( 3833): ACT-AM_ON_RESUME_CALLED ActivityRecord{4281b338 token=android.os.BinderProxy@4281aac8 {hobdrive.android/hobdroid.HomeActivity}}
D/ActivityThread( 3833): ACT-LAUNCH_ACTIVITY handled : 0 / ActivityRecord{4281b338 token=android.os.BinderProxy@4281aac8 {hobdrive.android/hobdroid.HomeActivity}}
--------- beginning of /dev/log/main
E/HOBD ( 3833): [ERROR] 09.01.2014 11:50:35.057[AndroidBT] Java.Lang.Throwable
E/HOBD ( 3833): Java.Lang.Throwable: Exception of type 'Java.Lang.Throwable' was thrown.
E/HOBD ( 3833): at Android.Runtime.JNIEnv.CallVoidMethod (IntPtr jobject, IntPtr jmethod) [0x00000] in <filename unknown>:0
E/HOBD ( 3833): at Android.Bluetooth.BluetoothSocket.Connect () [0x00000] in <filename unknown>:0
E/HOBD ( 3833): at hobdroid.AndroidBlueToothStream.Open (System.String #=qlvTZ6gYEFrynGgotpjmeAA==) [0x00000] in <filename unknown>:0
E/HOBD ( 3833): --- End of managed exception stack trace ---
E/HOBD ( 3833): java.io.IOException: [JSR82] connect: Connection is not created (failed or aborted).
E/HOBD ( 3833): at android.bluetooth.BluetoothSocket.connect(BluetoothSocket.java:395)
E/HOBD ( 3833): at dalvik.system.NativeStart.run(Native Method)
E/HOBD ( 3833): [ERROR] 09.01.2014 11:50:35.127[OBD2Engine] Init Error:
btspp://00:0D:18:3A:67:89;pin=insecureE/HOBD ( 3833): System.Exception: Can't connect BT socket
btspp://00:0D:18:3A:67:89;pin=insecureE/HOBD ( 3833): at hobdroid.AndroidBlueToothStream.Open (System.String #=qlvTZ6gYEFrynGgotpjmeAA==) [0x00000] in <filename unknown>:0
E/HOBD ( 3833): at hobd.OBD2Engine.SetState (System.String state2) [0x00000] in <filename unknown>:0 BaseException:
D/dalvikvm( 3833): GC_EXPLICIT freed 282K, 9% free 7967K/8695K, paused 1ms+4ms, total 37ms
I/BluetoothSocket_MTK( 3833): [JSR82] close
I/BluetoothSocket_MTK( 3833): [JSR82] readLock got.
I/monodroid-gc( 3833): GC cleanup summary: 73 objects tested - resurrecting 25.
D/dalvikvm( 3833): threadid=14: interp stack at 0x53bf8000
D/dalvikvm( 3833): threadid=15: interp stack at 0x53d33000
D/dalvikvm( 3833): threadid=14: bye!
D/dalvikvm( 3833): GC_FOR_ALLOC freed 76K, 9% free 7952K/8695K, paused 13ms, total 14ms
I/dalvikvm-heap( 3833): Grow heap (frag case) to 10.088MB for 2261008-byte allocation
D/dalvikvm( 3833): GC_FOR_ALLOC freed <1K, 8% free 10160K/10935K, paused 16ms, total 16ms
D/dalvikvm( 3833): GC_CONCURRENT freed <1K, 8% free 10169K/10935K, paused 1ms+2ms, total 28ms
D/dalvikvm( 3833): threadid=16: interp stack at 0x53ed0000
D/OpenGLRenderer( 3833): Flushing caches (mode 0)
D/dalvikvm( 3833): threadid=17: interp stack at 0x53eeb000
V/InputMethodManager( 3833): onWindowFocus: null softInputMode=288 first=true flags=#1810180
V/InputMethodManager( 3833): Starting input: view=com.android.internal.policy.impl.PhoneWindow$DecorView@42835778
V/InputMethodManager( 3833): Starting input: tba=android.view.inputmethod.EditorInfo@42668628 ic=null
V/InputMethodManager( 3833): START INPUT: com.android.internal.policy.impl.PhoneWindow$DecorView@42835778 ic=null tba=android.view.inputmethod.EditorInfo@42668628 controlFlags=#104
V/InputMethodManager( 3833): Starting input: Bind result=InputBindResult{com.android.internal.view.IInputMethodSession$Stub$Proxy@42664cc8 com.touchtype.swiftkey/com.touchtype.KeyboardService #169}
D/dalvikvm( 3833): threadid=15: bye!
D/ActivityThread( 3833): ACT-STOP_ACTIVITY_HIDE handled : 0 / android.os.BinderProxy@426628a8
D/jdwp ( 3833): Can't connect to ADB control socket:Connection refused
D/dalvikvm( 3833): GC_EXPLICIT freed 75K, 7% free 10173K/10935K, paused 2ms+3ms, total 47ms
I/monodroid-gc( 3833): GC cleanup summary: 6 objects tested - resurrecting 2.
D/dalvikvm( 3833): threadid=16: bye!
D/dalvikvm( 3833): threadid=14: interp stack at 0x53ed0000
I/SurfaceTextureClient( 3833): [0x53d49210] frames:7, duration:5.581000, fps:1.254107
D/dalvikvm( 3833): threadid=15: interp stack at 0x53f3f000
D/dalvikvm( 3833): threadid=15: interp stack at 0x53f85000
D/dalvikvm( 3833): threadid=16: interp stack at 0x53f8d000
I/SurfaceTextureClient( 3833): [0x53d49210] frames:8, duration:1.249000, fps:6.400284
D/dalvikvm( 3833): threadid=18: interp stack at 0x53f95000
D/ActivityThread( 3833): ACT-AM_ON_PAUSE_CALLED ActivityRecord{4281b338 token=android.os.BinderProxy@4281aac8 {hobdrive.android/hobdroid.HomeActivity}}
D/ActivityThread( 3833): ACT-PAUSE_ACTIVITY handled : 1 / android.os.BinderProxy@4281aac8
D/AbsListView( 3833): checkAbsListViewlLogProperty get invalid command
D/ActivityThread( 3833): ACT-AM_ON_RESUME_CALLED ActivityRecord{42a975d0 token=android.os.BinderProxy@42a96da0 {hobdrive.android/hobdroid.SettingsActivity}}
D/ActivityThread( 3833): ACT-LAUNCH_ACTIVITY handled : 0 / ActivityRecord{42a975d0 token=android.os.BinderProxy@42a96da0 {hobdrive.android/hobdroid.SettingsActivity}}
V/InputMethodManager( 3833): Not IME target window, ignoring
V/InputMethodManager( 3833): onWindowFocus: android.widget.ListView@42aad930 softInputMode=272 first=true flags=#1810100
V/InputMethodManager( 3833): Starting input: view=android.widget.ListView@42aad930
V/InputMethodManager( 3833): Starting input: tba=android.view.inputmethod.EditorInfo@42ad20b8 ic=null
V/InputMethodManager( 3833): START INPUT: android.widget.ListView@42aad930 ic=null tba=android.view.inputmethod.EditorInfo@42ad20b8 controlFlags=#105
V/InputMethodManager( 3833): Starting input: Bind result=InputBindResult{com.android.internal.view.IInputMethodSession$Stub$Proxy@42ad2be0 com.touchtype.swiftkey/com.touchtype.KeyboardService #170}
D/ActivityThread( 3833): ACT-DESTROY_ACTIVITY handled : 1 / android.os.BinderProxy@426628a8
D/dalvikvm( 3833): threadid=18: bye!
D/ActivityThread( 3833): ACT-STOP_ACTIVITY_HIDE handled : 0 / android.os.BinderProxy@4281aac8
I/SurfaceTextureClient( 3833): [0x53d4b960] frames:3, duration:1.092000, fps:2.745034
D/VelocityTracker( 3833): VelocityTracker: int datax = 10
D/VelocityTracker( 3833): VelocityTracker: int m_velocity_magnify_x = 1.000000
D/VelocityTracker( 3833): VelocityTracker: int datay = 10
D/VelocityTracker( 3833): VelocityTracker: int m_velocity_magnify_y = 1.000000
V/Provider/Setting( 3833): invalidate [system]: current 44 != cached 0
V/Provider/Setting( 3833): from db cache, name = sound_effects_enabled value = 0
D/dalvikvm( 3833): create interp thread : stack size=32KB
D/dalvikvm( 3833): create new thread
D/dalvikvm( 3833): new thread created
D/dalvikvm( 3833): update thread list
D/dalvikvm( 3833): threadid=18: interp stack at 0x54c47000
D/dalvikvm( 3833): threadid=18: created from interp
D/dalvikvm( 3833): start new thread
D/dalvikvm( 3833): threadid=18: notify debugger
D/dalvikvm( 3833): threadid=18 (java.lang.ProcessManager): calling run()
D/dalvikvm( 3833): threadid=19: interp stack at 0x54c4f000
V/InputMethodManager( 3833): focusOut: android.widget.ListView@42aad930 mServedView=android.widget.ListView@42aad930 winFocus=false
I/SurfaceTextureClient( 3833): [0x54c3cf08] frames:2, duration:1.164000, fps:1.717061
V/InputMethodManager( 3833): onWindowFocus: android.widget.ListView@42aad930 softInputMode=16 first=false flags=#1810100
D/ActivityThread( 3833): ACT-AM_ON_PAUSE_CALLED ActivityRecord{42a975d0 token=android.os.BinderProxy@42a96da0 {hobdrive.android/hobdroid.SettingsActivity}}
D/ActivityThread( 3833): ACT-PAUSE_ACTIVITY_FINISHING handled : 0 / android.os.BinderProxy@42a96da0
D/ActivityThread( 3833): ACT-RESUME_ACTIVITY handled : 0 / android.os.BinderProxy@4281aac8
E/HOBD ( 3833): [INFO ] 09.01.2014 11:50:51.973[HOBD] hobd locale: ru android: ru
E/HOBD ( 3833): [INFO] 09.01.2014 11:50:52.100[HomePage] System DPI: 160
E/HOBD ( 3833): [INFO] 09.01.2014 11:50:52.108[HomePage] App DPI: 75
E/HOBD ( 3833): [INFO] 09.01.2014 11:50:52.108[HomePage] layout: 480x258
D/dalvikvm( 3833): threadid=20: interp stack at 0x54c6b000
D/dalvikvm( 3833): threadid=21: interp stack at 0x54c73000
D/dalvikvm( 3833): threadid=20: bye!
V/InputMethodManager( 3833): onWindowFocus: null softInputMode=32 first=true flags=#1810180
V/InputMethodManager( 3833): Starting input: tba=android.view.inputmethod.EditorInfo@42b5fe38 ic=null
V/InputMethodManager( 3833): START INPUT: com.android.internal.policy.impl.PhoneWindow$DecorView@42835778 ic=null tba=android.view.inputmethod.EditorInfo@42b5fe38 controlFlags=#104
V/InputMethodManager( 3833): Starting input: Bind result=InputBindResult{com.android.internal.view.IInputMethodSession$Stub$Proxy@42b609c8 com.touchtype.swiftkey/com.touchtype.KeyboardService #171}
V/InputMethodManager( 3833): focusOut: android.widget.ListView@42aad930 mServedView=com.android.internal.policy.impl.PhoneWindow$DecorView@42835778 winFocus=false
D/dalvikvm( 3833): threadid=21: bye!
D/ActivityThread( 3833): ACT-DESTROY_ACTIVITY handled : 1 / android.os.BinderProxy@42a96da0
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:6, duration:2.627000, fps:2.283886
E/HOBD ( 3833): [INFO ] 09.01.2014 11:50:55.349[AndroidBT] Closing Socket
I/BluetoothSocket_MTK( 3833): [JSR82] Bluetooth Socket Constructor
I/BluetoothSocket_MTK( 3833): [JSR82] type=1 fd=-1 auth=false encrypt=false port=-1
I/BluetoothSocket_MTK( 3833): [JSR82] connect: do SDP
D/dalvikvm( 3833): GC_CONCURRENT freed 1064K, 11% free 10533K/11831K, paused 2ms+5ms, total 31ms
I/BluetoothSocket_MTK( 3833): [JSR82] SdpHelper::onRfcommChannelFound: channel=1
I/BluetoothSocket_MTK( 3833): [JSR82] connect: do SDP done; mPort=1
D/dalvikvm( 3833): threadid=20: interp stack at 0x53feb000
I/SurfaceTextureClient( 3833): [STC::queueBuffer] this:0x54a1a008, api:1, last queue time elapsed :5116 ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:5.116000, fps:0.195435
E/HOBD ( 3833): [INFO] 09.01.2014 11:51:01.281[OBD2Engine] VersionInfo: ELM327 v1.5
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:2, duration:1.183000, fps:1.689976
E/HOBD ( 3833): [INFO] 09.01.2014 11:51:06.902[OBD2Engine] Sensor Init:SEARCHING...
41 00 BE 3E B8 11
I/SurfaceTextureClient( 3833): [STC::queueBuffer] this:0x54a1a008, api:1, last queue time elapsed :5383 ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:5.383000, fps:0.185764
E/HOBD ( 3833): [INFO] 09.01.2014 11:51:06.970[OBD2Engine] ProtocolId: 3
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:3, duration:1.250000, fps:2.398830
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:3, duration:1.034000, fps:2.900986
D/dalvikvm( 3833): GC_EXPLICIT freed 579K, 13% free 10400K/11831K, paused 23ms+7ms, total 76ms
I/monodroid-gc( 3833): GC cleanup summary: 76 objects tested - resurrecting 19.
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.165000, fps:3.432722
E/HOBD ( 3833): [ERROR] 09.01.2014 11:51:10.745[MILTrace] dataraw: DA
E/HOBD ( 3833): [ERROR] 09.01.2014 11:51:11.079[MILTrace] dataraw: 47 00 00 00 00 00 00
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:3, duration:1.033000, fps:2.903214
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.235000, fps:3.238786
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.233000, fps:3.241757
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.183000, fps:3.380152
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.051000, fps:3.802996
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.068000, fps:3.744217
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.163000, fps:3.439223
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.084000, fps:3.690018
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.113000, fps:3.591174
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:5, duration:1.223000, fps:4.085303
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.109000, fps:3.605271
I/BluetoothSocket_MTK( 3833): [JSR82] Start to aquire writeLock.
I/BluetoothSocket_MTK( 3833): [JSR82] writeLock got.
I/SurfaceTextureClient( 3833): [STC::queueBuffer] this:0x54a1a008, api:1, last queue time elapsed :5029 ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:3, duration:5.616000, fps:0.534106
E/HOBD ( 3833): [INFO ] 09.01.2014 11:51:29.111[AndroidBT] Closing Socket
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:2.399000, fps:0.416692
E/HOBD ( 3833): [INFO] 09.01.2014 11:51:31.733[OBD2Engine] VersionInfo: 4ELM327 v1.5
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:2, duration:1.101000, fps:1.816142
E/HOBD ( 3833): [ERROR] 09.01.2014 11:51:37.331[OBD2Engine] Critical error on sensor init:SEARCHING...
UNABLE TO CONNECT
I/SurfaceTextureClient( 3833): [STC::queueBuffer] this:0x54a1a008, api:1, last queue time elapsed :5493 ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:5.493000, fps:0.182027
D/dalvikvm( 3833): GC_CONCURRENT freed 1239K, 13% free 10549K/12023K, paused 1ms+4ms, total 29ms
I/SurfaceTextureClient( 3833): [STC::queueBuffer] this:0x54a1a008, api:1, last queue time elapsed :19888 ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:19.888000, fps:0.050281
E/HOBD ( 3833): [INFO] 09.01.2014 11:51:58.272[OBD2Engine] VersionInfo: ELM327 v1.5
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:2, duration:1.169000, fps:1.710215
E/HOBD ( 3833): [INFO] 09.01.2014 11:52:03.993[OBD2Engine] Sensor Init:SEARCHING...
41 00 BE 3E B8 11
I/SurfaceTextureClient( 3833): [STC::queueBuffer] this:0x54a1a008, api:1, last queue time elapsed :5465 ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:5.465000, fps:0.182981
E/HOBD ( 3833): [INFO] 09.01.2014 11:52:04.057[OBD2Engine] ProtocolId: 3
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:3, duration:1.238000, fps:2.422476
I/SurfaceTextureClient( 3833): [STC::queueBuffer] this:0x54a1a008, api:1, last queue time elapsed :5012 ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:5.012000, fps:0.199516
E/HOBD ( 3833): [INFO ] 09.01.2014 11:52:10.872[AndroidBT] Closing Socket
I/BluetoothSocket_MTK( 3833): [JSR82] SdpHelper::onRfcommChannelFound: channel=-1
E/HOBD ( 3833): [ERROR] 09.01.2014 11:52:17.428[AndroidBT] Java.Lang.Throwable
E/HOBD ( 3833): java.io.IOException: Service discovery failed
E/HOBD ( 3833): at android.bluetooth.BluetoothSocket$SdpHelper.doSdp(BluetoothSocket.java:813)
E/HOBD ( 3833): at android.bluetooth.BluetoothSocket.connect(BluetoothSocket.java:382)
E/HOBD ( 3833): [ERROR] 09.01.2014 11:52:17.430[OBD2Engine] Init Error:
I/SurfaceTextureClient( 3833): [STC::queueBuffer] this:0x54a1a008, api:1, last queue time elapsed :7286 ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:7.286000, fps:0.137245
I/SurfaceTextureClient( 3833): [STC::queueBuffer] this:0x54a1a008, api:1, last queue time elapsed :19962 ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:19.962000, fps:0.050095
E/HOBD ( 3833): [INFO ] 09.01.2014 11:52:37.609[AndroidBT] Closing Socket
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:2.749000, fps:0.363640
E/HOBD ( 3833): [INFO] 09.01.2014 11:52:41.132[OBD2Engine] VersionInfo: 41 0B ELM327 v1.5
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:2, duration:1.116000, fps:1.790840
E/HOBD ( 3833): [ERROR] 09.01.2014 11:52:46.768[OBD2Engine] Critical error on sensor init:SEARCHING...
UNABLE TO CONNECT
I/SurfaceTextureClient( 3833): [STC::queueBuffer] this:0x54a1a008, api:1, last queue time elapsed :5453 ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:5.453000, fps:0.183376
I/SurfaceTextureClient( 3833): [STC::queueBuffer] this:0x54a1a008, api:1, last queue time elapsed :19996 ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:19.996000, fps:0.050008
E/HOBD ( 3833): [INFO] 09.01.2014 11:53:07.694[OBD2Engine] VersionInfo: ELM327 v1.5
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:2, duration:1.100000, fps:1.817634
D/dalvikvm( 3833): GC_CONCURRENT freed 1506K, 15% free 10476K/12215K, paused 2ms+3ms, total 27ms
E/HOBD ( 3833): [INFO] 09.01.2014 11:53:13.349[OBD2Engine] Sensor Init:SEARCHING...
41 00 BE 3E B8 11
I/SurfaceTextureClient( 3833): [STC::queueBuffer] this:0x54a1a008, api:1, last queue time elapsed :5434 ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:5.434000, fps:0.184024
E/HOBD ( 3833): [INFO] 09.01.2014 11:53:13.418[OBD2Engine] ProtocolId: 3
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:3, duration:1.248000, fps:2.402236
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.300000, fps:3.074736
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:3, duration:1.033000, fps:2.903614
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.185000, fps:3.375430
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.197000, fps:3.340168
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.133000, fps:3.528417
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.133000, fps:3.528481
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.200000, fps:3.332493
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.017000, fps:3.932928
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.107000, fps:3.610190
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.014000, fps:3.943592
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.143000, fps:3.498789
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.217000, fps:3.284927
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:5, duration:1.233000, fps:4.052653
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.035000, fps:3.863243
D/dalvikvm( 3833): GC_CONCURRENT freed 1218K, 13% free 10650K/12215K, paused 11ms+51ms, total 109ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.015000, fps:3.939859
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.119000, fps:3.573753
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.099000, fps:3.637396
D/dalvikvm( 3833): GC_EXPLICIT freed 490K, 15% free 10400K/12215K, paused 2ms+4ms, total 41ms
I/monodroid-gc( 3833): GC cleanup summary: 154 objects tested - resurrecting 2.
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.113000, fps:3.593045
I/SurfaceTextureClient( 3833): [STC::queueBuffer] this:0x54a1a008, api:1, last queue time elapsed :5015 ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:3, duration:5.499000, fps:0.545519
E/HOBD ( 3833): [INFO ] 09.01.2014 11:53:41.025[AndroidBT] Closing Socket
I/SurfaceTextureClient( 3833): [STC::queueBuffer] this:0x54a1a008, api:1, last queue time elapsed :6183 ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:6.183000, fps:0.161729
E/HOBD ( 3833): [INFO] 09.01.2014 11:53:47.413[OBD2Engine] VersionInfo: 41 0D 33 ELM327 v1.5
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:2, duration:1.084000, fps:1.843927
E/HOBD ( 3833): [ERROR] 09.01.2014 11:53:53.007[OBD2Engine] Critical error on sensor init:SEARCHING...
UNABLE TO CONNECT
I/SurfaceTextureClient( 3833): [STC::queueBuffer] this:0x54a1a008, api:1, last queue time elapsed :5429 ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:5.429000, fps:0.184177
I/SurfaceTextureClient( 3833): [STC::queueBuffer] this:0x54a1a008, api:1, last queue time elapsed :19985 ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:19.985001, fps:0.050036
E/HOBD ( 3833): [INFO] 09.01.2014 11:54:13.982[OBD2Engine] VersionInfo: ELM327 v1.5
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:2, duration:1.159000, fps:1.724364
E/HOBD ( 3833): [INFO] 09.01.2014 11:54:19.687[OBD2Engine] Sensor Init:SEARCHING...
41 00 BE 3E B8 11
E/HOBD ( 3833): [INFO] 09.01.2014 11:54:19.755[OBD2Engine] ProtocolId: 3
I/SurfaceTextureClient( 3833): [STC::queueBuffer] this:0x54a1a008, api:1, last queue time elapsed :5457 ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:5.457000, fps:0.183238
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:3, duration:1.217000, fps:2.464384
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:3, duration:1.087000, fps:2.758786
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.263000, fps:3.165270
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.264000, fps:3.163634
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.149000, fps:3.478545
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.091000, fps:3.664496
D/dalvikvm( 3833): GC_CONCURRENT freed 1280K, 14% free 10511K/12215K, paused 12ms+12ms, total 79ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.108000, fps:3.608706
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.150000, fps:3.477438
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.155000, fps:3.463041
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:5, duration:1.238000, fps:4.038235
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.127000, fps:3.548348
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.048000, fps:3.816635
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.032000, fps:3.875441
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.016000, fps:3.934736
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:5, duration:1.365000, fps:3.660723
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.101000, fps:3.630446
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:5, duration:1.235000, fps:4.048364
I/SurfaceTextureClient( 3833): [STC::queueBuffer] this:0x54a1a008, api:1, last queue time elapsed :5097 ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:5.097000, fps:0.196177
E/HOBD ( 3833): [INFO ] 09.01.2014 11:54:45.065[AndroidBT] Closing Socket
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:2.335000, fps:0.428166
E/HOBD ( 3833): [INFO] 09.01.2014 11:54:47.637[OBD2Engine] VersionInfo: 4ELM327 v1.5
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:2, duration:1.097000, fps:1.821631
E/HOBD ( 3833): [ERROR] 09.01.2014 11:54:53.227[OBD2Engine] Critical error on sensor init:SEARCHING...
UNABLE TO CONNECT
I/SurfaceTextureClient( 3833): [STC::queueBuffer] this:0x54a1a008, api:1, last queue time elapsed :5451 ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:5.451000, fps:0.183424
D/dalvikvm( 3833): GC_CONCURRENT freed 1321K, 14% free 10567K/12215K, paused 1ms+10ms, total 59ms
I/SurfaceTextureClient( 3833): [STC::queueBuffer] this:0x54a1a008, api:1, last queue time elapsed :19933 ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:19.933001, fps:0.050167
E/HOBD ( 3833): [INFO] 09.01.2014 11:55:14.161[OBD2Engine] VersionInfo: ELM327 v1.5
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:2, duration:1.151000, fps:1.737014
E/HOBD ( 3833): [INFO] 09.01.2014 11:55:19.863[OBD2Engine] Sensor Init:SEARCHING...
41 00 BE 3E B8 11
I/SurfaceTextureClient( 3833): [STC::queueBuffer] this:0x54a1a008, api:1, last queue time elapsed :5447 ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:1, duration:5.447000, fps:0.183557
E/HOBD ( 3833): [INFO] 09.01.2014 11:55:19.933[OBD2Engine] ProtocolId: 3
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:3, duration:1.216000, fps:2.466473
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:3, duration:1.084000, fps:2.766064
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.306000, fps:3.060744
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.189000, fps:3.361702
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.116000, fps:3.582377
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.084000, fps:3.689736
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.075000, fps:3.717714
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.146000, fps:3.489250
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.022000, fps:3.912859
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.238000, fps:3.230234
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.000000, fps:3.999799
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:5, duration:1.223000, fps:4.085784
D/dalvikvm( 3833): GC_EXPLICIT freed 1353K, 14% free 10561K/12215K, paused 6ms+6ms, total 56ms
I/monodroid-gc( 3833): GC cleanup summary: 126 objects tested - resurrecting 1.
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.309000, fps:3.054857
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.038000, fps:3.850813
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.002000, fps:3.989638
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:5, duration:1.259000, fps:3.970074
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:5, duration:1.237000, fps:4.039079
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.294000, fps:3.089331
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.083000, fps:3.692530
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:5, duration:1.250000, fps:3.999277
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:5, duration:1.249000, fps:4.000113
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.018000, fps:3.925993
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.138000, fps:3.514253
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.050000, fps:3.807723
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.008000, fps:3.965304
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:5, duration:1.335000, fps:3.745209
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:5, duration:1.215000, fps:4.115011
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.103000, fps:3.624192
D/dalvikvm( 3833): GC_CONCURRENT freed 1402K, 14% free 10592K/12215K, paused 1ms+7ms, total 107ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.147000, fps:3.485772
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:5, duration:1.218000, fps:4.104683
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.030000, fps:3.881621
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.003000, fps:3.986820
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.073000, fps:3.725114
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.107000, fps:3.612809
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.015000, fps:3.937300
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:5, duration:1.234000, fps:4.048751
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:5, duration:1.214000, fps:4.115571
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.100000, fps:3.636236
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.000000, fps:3.998842
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.216000, fps:3.286946
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:5, duration:1.216000, fps:4.111498
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:5, duration:1.216000, fps:4.109310
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.085000, fps:3.684992
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:5, duration:1.217000, fps:4.106640
D/dalvikvm( 3833): GC_CONCURRENT freed 1404K, 14% free 10591K/12215K, paused 1ms+17ms, total 99ms
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.036000, fps:3.860826
E/HOBD ( 3833): [ERROR] 09.01.2014 11:56:11.986[MILTrace] dataraw: DA
E/HOBD ( 3833): [ERROR] 09.01.2014 11:56:12.240[MILTrace] dataraw: 47 00 00 00 00 00 00
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:4, duration:1.144000, fps:3.496000
D/dalvikvm( 3833): threadid=21: interp stack at 0x53fff000
D/dalvikvm( 3833): GC_EXPLICIT freed 451K, 16% free 10368K/12215K, paused 14ms+3ms, total 48ms
I/monodroid-gc( 3833): GC cleanup summary: 39 objects tested - resurrecting 0.
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:6, duration:1.034000, fps:5.801282
I/SurfaceTextureClient( 3833): [0x54a1a008] frames:7, duration:1.149000, fps:6.090209
D/ActivityThread( 3833): ACT-AM_ON_RESUME_CALLED ActivityRecord{42ab0f88 token=android.os.BinderProxy@42809830 {hobdrive.android/hobdroid.SettingsActivity}}
D/ActivityThread( 3833): ACT-LAUNCH_ACTIVITY handled : 0 / ActivityRecord{42ab0f88 token=android.os.BinderProxy@42809830 {hobdrive.android/hobdroid.SettingsActivity}}
V/InputMethodManager( 3833): onWindowFocus: android.widget.ListView@42819310 softInputMode=272 first=true flags=#1810100
V/InputMethodManager( 3833): Starting input: view=android.widget.ListView@42819310
V/InputMethodManager( 3833): Starting input: tba=android.view.inputmethod.EditorInfo@4281f3b8 ic=null
V/InputMethodManager( 3833): START INPUT: android.widget.ListView@42819310 ic=null tba=android.view.inputmethod.EditorInfo@4281f3b8 controlFlags=#105
V/InputMethodManager( 3833): Starting input: Bind result=InputBindResult{com.android.internal.view.IInputMethodSession$Stub$Proxy@42b2f250 com.touchtype.swiftkey/com.touchtype.KeyboardService #172}
I/SurfaceTextureClient( 3833): [0x53f42548] frames:3, duration:1.092000, fps:2.745287
V/Provider/Setting( 3833): from settings cache , name = sound_effects_enabled value = 0
