Connection error Threshold
I was trying connecting using android hobDrive (trial version). It seems it connects but no data shown up except that battery voltage.
it also periodically gives me error "connection error threshold". I am not sure what that means? is that the limit on the trial version?
my vehicle is Toyota Vitz 2010 (from Japan).
using Device of iCar type wireless dongle.
thank you
Sameers
thank you
Sameers
Re: Connection error Threshold
Hello, you should setup vehicle protocol correctly.
Most probably you have to choose One of Toyota JDM profiles, or Toyota21 CAN "Vehicle type" in "vehicle settings".
cail писал(а):Hello, you should setup vehicle protocol correctly.
Thank you for your nice tip. it worked a bit. I was able to get the speed and few other information. However, mainly the fuel details didn't came in.
Is there any way I can get fuel details as well?
I set my settings to "Toyota JDM CAN mode21" and that seems to work to get most of the information.
Is there any other setting for fuel?
thank you
Sameers
You should setup valid Fuel consumption method.
For your toyota, most probably "Injector sensor" would work. If no, try "MAF sensor method"
Hi,
thanks for the tip. I already tried it and tried it again to all methods with no luck.
Settings->Vehicle Settings->MPG Method
Tried to all possible values (MAF Sensor, MAP sensor, Injector Snsor, EngineLoad Sensor, Bultin Consumption sensor)
But no luck.
Any other tip?
thanks
Sameers
But no luck.
Any other tip?
thanks
Sameers
Have you checked Fuel Per Hour sensor? It should work with "Injector" method.
