customize screen
Добавлено: 14 апр 2012, 10:17
rezabeigi
hi please describe how we can change screen layout to data chart and other indicator ..i tghink that is some complicated . thanks cail
Re: customize screen
Добавлено: 14 апр 2012, 12:49
rezabeigi, setup and configuration of concrete sensor view is quite simpe (via "configure UI" mode).
But if you want to setup your own screens - this is now only possible with manual configuration files edit and can be considered quite difficult.
Working on some helpers to make this easier.
Добавлено: 14 апр 2012, 13:44
rezabeigi
ok would you train me how can i change ui configoration when ever i try to change screen layout in setting i change widget but that is not effective . has this any user manual for change correct?
thanks cail
Добавлено: 14 апр 2012, 13:49
with demo version you can change only two widgets: RPM and fuel level.
All others are just plain in demo.
I'll post some insturctions on how to do lowlevel layout configuration later.
Добавлено: 14 апр 2012, 14:13
rezabeigi
thanks my freind
Добавлено: 15 апр 2012, 07:25
WuMeiGuang
I'll be waiting that instructions also Cail, thanks
cail писал(а):with demo version you can change only two widgets: RPM and fuel level.
Добавлено: 16 апр 2012, 10:14
Here is a draft:
viewtopic.php?f=11&t=136
you can ask more in that thread - I'll help with answers as much as I can.
