[SOLVED] Can't Connect RoadRover Civic unit: BT dongle issue
Добавлено: 28 июн 2012, 00:40
Rapa
Hi,
i was trying to use hobdrive in my RoadRover unit, i can see the adapter, but it fails to connect.
I'm using:
Bluetooth usb dongle in the head unit
Bluetooth OBD2 adapter from ebay
Standalone Hobd version with compact framework
already tested a different OBD2 adapter...
I can use the bluetooth adapter in Torque and HOBD for android with no problems... also in my laptop running windows 7...
a friend is using with no problems on his unit.. but his RoadRover is older than mine... he has the D2280 folder... i have the I9 folder...
i have two different cables too.. one VAG copy and one that looks like the bluettoth obd2 ebay adapter but with a usb cable... however i can't use then cause everytime turn off my unit the dll files i put in windows are gone...
this is my config..
already tried all options in Delay for elm interactions...
any ideas? my next move will be to extend the usb cable to leave the dongle right next the obd2 adapter
edit: my friend just sent me a video with his steps to setup the program.. i did the same thing http://www.youtube.com/watch?v=dppMxe5F-6Q
Re: Can't Connect... RoadRover Civic unit
Добавлено: 28 июн 2012, 00:53
Rapa, please try choosing "ELM Reset" in vehicle settings, elm init template field.
Since you see ELM device, you definitely should be able to connect. share your log.txt file just in case - I'll checkout the problem.
Regarding files being ovewritten - thats a common problem, the workaround is basically store all the required files on flash and do initialization on each start.
Добавлено: 28 июн 2012, 00:56
Rapa
yeah i know... a real pain..
but using bluetooth i don't have this problem.. just using hobd in my sdcard..
i'll try the elm reset options and post the log here...
Добавлено: 28 июн 2012, 01:24
Rapa
[INFO]  6/27/2012 7:09:01 PM.001[HOBD]  HOBD 1.1.1 29.02.2012  13:19
[INFO]  6/27/2012 7:09:01 PM.132[HOBD]  Env: 3.5.7283.0
[INFO]  6/27/2012 7:09:03 PM.025[HOBD]  SN: 00540054-0034-0058-0030-545434583042445F3000
[INFO]  6/27/2012 7:09:03 PM.607[HOBD]  Vehicle: My Vehicle
[ERROR]  6/27/2012 7:09:04 PM.304[HOBD]  bad provider ecuxml://\Storage Card\hobd\user.ecuxml
System.IO.FileNotFoundException: An error message is available for this exception but cannot be displayed because these messages are optional and are not currently installed on this device. Please install ‘NETCFv35.Messages.EN.wm.cab’ for Windows Mobile 5.0 and above or  ‘NETCFv35.Messages.EN.cab’ for other platforms. Restart the application to see the message.
   at #=qPc42lWHPoKxIqKdcjwMgbzOeBwIB1hBW3db4DxsshaE=.#=qYS30yvukWtx47te4aQsStWF5XhVpKTjCxQgTQK$8qzw=(String #=qTz48NWnxmwHlsbiLP01Cwg==)
   at #=qPc42lWHPoKxIqKdcjwMgbzOeBwIB1hBW3db4DxsshaE=.#=qzxMhj8Gh2rCc4Bbh6IsDgQ==()
   at #=qPc42lWHPoKxIqKdcjwMgbzOeBwIB1hBW3db4DxsshaE=.#=qU_NaK4iQgFsz2eVBQQIT3A==()
   at #=q_mMq$NOUI_Mh5XgmJXNMWw==.#=q4X9QL3AHYVnqpOvWKfJm7Q==()
   at #=qcYnIe2yAE8WwfyM2YoPa6c$Chdcbj19kQ7Tt9gXXWiM=.#=q9G0e0sdmJBhMIik8S7yjzA==(String[] #=qSh09aj13RyzMSIKnTMESqg==)
[INFO]  6/27/2012 7:09:05 PM.143[HOBD]  system width: 800, height: 480
[INFO]  6/27/2012 7:09:05 PM.159[HOBD]  wa width: 800, wa height: 480
[INFO]  6/27/2012 7:09:05 PM.873[HOBDAll]  hobDrive registered: hdtco4740289376 - Raphael Pais
[INFO]  6/27/2012 7:09:07 PM.009[HomePage]  System DPI: 96
[INFO]  6/27/2012 7:09:07 PM.024[HomePage]  App DPI: 57
[INFO]  6/27/2012 7:09:07 PM.037[HomePage]  layout: 475x285
[INFO]  6/27/2012 7:09:07 PM.055[HomePage]  form: 242x293
[ERROR]  6/27/2012 7:09:23 PM.022[OBD2Engine]  Init Error
System.Net.Sockets.SocketException: An error message is available for this exception but cannot be displayed because these messages are optional and are not currently installed on this device. Please install ‘NETCFv35.Messages.EN.wm.cab’ for Windows Mobile 5.0 and above or  ‘NETCFv35.Messages.EN.cab’ for other platforms. Restart the application to see the message.
   at System.Net.Sockets.Socket.ConnectNoCheck(EndPoint remoteEP)
   at System.Net.Sockets.Socket.Connect(EndPoint remoteEP)
   at InTheHand.Net.Sockets.SocketBluetoothClient.Connect(BluetoothEndPoint remoteEP)
   at InTheHand.Net.Sockets.BluetoothClient.Connect(BluetoothEndPoint remoteEP)
   at hobd.BluetoothStream.Open(String url)
   at hobd.OBD2Engine.SetState(String state2)
   at hobd.OBD2Engine.Run()
[ERROR]  6/27/2012 7:10:00 PM.181[OBD2Engine]  Init Error
System.Threading.ThreadAbortException: ThreadAbortException
[ERROR]  6/27/2012 7:10:04 PM.500[VehicleForm]  LoadModel
System.ArgumentNullException: ArgumentNullException
   at System.Double.Parse(String s, NumberStyles style, IFormatProvider provider)
   at System.Double.Parse(String s, IFormatProvider provider)
   at #=q5JnDHXv9AGMsDlnbIh7501gbE9GujXikXdT0USjO$2M=.#=qnGRfpGQI7z0MNAF0KTizAQ==()
   at #=q5JnDHXv9AGMsDlnbIh7501gbE9GujXikXdT0USjO$2M=.#=qn29ahhFwD6_vViwFYuP7EYPYLi4EIqMyzbOcXuB$9xM=()
   at #=q5JnDHXv9AGMsDlnbIh7501gbE9GujXikXdT0USjO$2M=..ctor(Form #=qOG2nU0Q$NLrcibBznM0DtQ==)
   at hobd.HomePage.#=q0VsJq4aeKpSvEluQi$Ohdg==(#=qn$k1OcXjzh18tZeN3in7xiO4dq5AypqcTEtALyT$gXY= #=qorH1Kd4AmBDhr$SbfFm7tQ==)
   at hobd.HomePage.#=qzttQmebTI0bQ2iBGkat4VA==(#=qn$k1OcXjzh18tZeN3in7xiO4dq5AypqcTEtALyT$gXY= #=qweNTupbbUMXskT2TuGQjkA==)
   at hobd.HomePage.#=qWJwe3QyeyaRSgNLSssaZVA==(String #=qrBHSBcmrwvXkhqAfSuyN8g==, Sensor #=qRPEyqbvesYKvmwej_E7EPg==)
   at hobd.HomePage.#=qTAkifM3iirsuWsZADSHdmbE56FbZZiebZTZ8fvEZ59Y=.#=qxOaswMfymc9Nzx$2b7TSoRwWN9paPLDXJkbRPYPXYpQ=(Point #=qXxx05VTL3q9sO4WRSzpDRQ==)
   at Fleux.UIElements.UIElement.Tap(Point p)
   at Fleux.UIElements.UIElement.<>c__DisplayClassa.<Tap>b__9(UIElement el)
   at Fleux.UIElements.UIElement.TraverseHandle(Point start, Func`2 elementHandler)
   at Fleux.UIElements.Panorama.PanoramaElement.Tap(Point p)
   at Fleux.Controls.FleuxControl.<>c__DisplayClass1b.<Tap>b__19()
   at System.Reflection.RuntimeMethodInfo.InternalInvoke(RuntimeMethodInfo rtmi, Object obj, BindingFlags invokeAttr, Binder binder, Object parameters, CultureInfo culture, Boolean isBinderDefault, Assembly caller, Boolean verifyAccess, StackCrawlMark& stackMark)
   at System.Reflection.RuntimeMethodInfo.InternalInvoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean verifyAccess, StackCrawlMark& stackMark)
   at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
   at System.Reflection.MethodBase.Invoke(Object obj, Object[] parameters)
   at System.Windows.Forms.Control.TASK.Invoke()
   at System.Windows.Forms.Control._InvokeAll()
   at System.Windows.Forms.Control.InvokeHelper(Delegate method, Boolean fSynchronous, Object[] rgobjArgs)
   at Fleux.Controls.FleuxControl.Tap(Point p)
   at Fleux.Controls.Gestures.GesturesEngine.RaiseTap(Point p)
   at Fleux.Controls.Gestures.GesturesEngine.MouseUp(Point point)
   at Fleux.Controls.FleuxControl.OnMouseUp(MouseEventArgs e)
   at System.Windows.Forms.Control.WnProc(WM wm, Int32 wParam, Int32 lParam)
   at System.Windows.Forms.Control._InternalWnProc(WM wm, Int32 wParam, Int32 lParam)
   at Microsoft.AGL.Forms.EVL.EnterMainLoop(IntPtr hwnMain)
   at System.Windows.Forms.Application.Run(Form fm)
   at Fleux.Core.FleuxApplication.Run(FleuxPage mainPage)
   at #=q_mMq$NOUI_Mh5XgmJXNMWw==.#=q2U0o1ZJsCIQgWY516yswJg==(String #=qJVailhWBGgCRpqroCofFSg==)
[ERROR]  6/27/2012 7:10:13 PM.352[BluetoothStream]  set_Mode
System.ComponentModel.Win32Exception: Error setting BluetoothRadio mode
   at InTheHand.Net.Bluetooth.WindowsBluetoothRadio.set_Mode(RadioMode value)
   at InTheHand.Net.Bluetooth.BluetoothRadio.set_Mode(RadioMode value)
[ERROR]  6/27/2012 7:10:13 PM.453[OBD2Engine]  Init Error
[INFO]  6/27/2012 7:10:30 PM.261[HOBD]  Vehicle: My Vehicle
[ERROR]  6/27/2012 7:10:30 PM.369[HOBD]  bad provider ecuxml://\Storage Card\hobd\user.ecuxml
[ERROR]  6/27/2012 7:10:30 PM.775[OBD2Engine]  Init Error
[INFO]  6/27/2012 7:10:31 PM.451[HomePage]  System DPI: 96
[INFO]  6/27/2012 7:10:31 PM.460[HomePage]  App DPI: 57
[INFO]  6/27/2012 7:10:31 PM.469[HomePage]  layout: 475x285
[INFO]  6/27/2012 7:10:31 PM.479[HomePage]  form: 800x480
[ERROR]  6/27/2012 7:10:32 PM.499[HomePage]  Invalid Action: default
[ERROR]  6/27/2012 7:10:32 PM.646[HomePage]  Invalid Action: default
[ERROR]  6/27/2012 7:10:42 PM.105[BluetoothStream]  set_Mode
[ERROR]  6/27/2012 7:10:42 PM.312[OBD2Engine]  Init Error
[ERROR]  6/27/2012 7:11:03 PM.729[BluetoothStream]  set_Mode
[ERROR]  6/27/2012 7:11:03 PM.818[OBD2Engine]  Init Error
[ERROR]  6/27/2012 7:11:09 PM.579[VehicleForm]  LoadModel
[INFO]  6/27/2012 7:11:22 PM.220[HOBD]  Vehicle: My Vehicle
[ERROR]  6/27/2012 7:11:22 PM.253[HOBD]  bad provider ecuxml://\Storage Card\hobd\user.ecuxml
[ERROR]  6/27/2012 7:11:22 PM.537[OBD2Engine]  Init Error
[INFO]  6/27/2012 7:11:23 PM.253[HomePage]  System DPI: 96
[INFO]  6/27/2012 7:11:23 PM.267[HomePage]  App DPI: 57
[INFO]  6/27/2012 7:11:23 PM.279[HomePage]  layout: 475x285
[INFO]  6/27/2012 7:11:23 PM.292[HomePage]  form: 800x480
[ERROR]  6/27/2012 7:11:24 PM.193[HomePage]  Invalid Action: default
[ERROR]  6/27/2012 7:11:37 PM.108[OBD2Engine]  Init Error
[ERROR]  6/27/2012 7:12:11 PM.709[OBD2Engine]  Init Error
                   H           .text   Ää      æ                   `.rsrc   X         è             @  @.reloc      @     î             @  B        [ERROR]  6/27/2012 7:12:11 PM.746[OBD2Engine]  Init Error
Добавлено: 28 июн 2012, 01:43
I only see that BT connection is failed again and again.
Try to remove pin code from hobdrive's dialog, but enter system BT manager and add ELM adapter into Trusted devices (entering the pin code there).
Добавлено: 28 июн 2012, 02:11
Rapa
 D2Engine.Run() [INFO] 6/27/2012 7:50:56 PM.001[HOBD] HOBD 1.1.1 29.02.2012 13:19 [INFO] 6/27/2012 7:50:56 PM.379[HOBD] Env: 3.5.7283.0 [INFO] 6/27/2012 7:50:58 PM.814[HOBD] SN: 00540054-0034-0058-0030- 545434583042445F3000 [INFO] 6/27/2012 7:50:59 PM.449[HOBD] Vehicle: My Vehicle [ERROR] 6/27/2012 7:50:59 PM.778[HOBD] bad provider ecuxml://\Storage Card\hobd\user.ecuxml System.IO.FileNotFoundException: An error message is available for this exception but cannot be displayed because these messages are optional and are not currently installed on this device. Please install â €˜NETCFv35.Messages.EN.wm.cab’ for Windows Mobile 5.0 and above or â €˜NETCFv35.Messages.EN.cab’ for other platforms. Restart the application to see the message. at System.IO.__Error.WinIOError(Int32 errorCode, String str) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean useAsync, String msgPath) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize) at System.Xml.XmlDownloadManager.GetStream(Uri uri, ICredentials credentials) at System.Xml.XmlUrlResolver.GetEntity(Uri absoluteUri, String role, Type ofObjectToReturn) at System.Xml.XmlReader.Create(String inputUri, XmlReaderSettings settings, XmlParserContext inputContext) at hobd.ECUXMLSensorProvider..ctor(String ecuxml) at hobd.SensorRegistry.RegisterProvider(String provider) at #=qPc42lWHPoKxIqKdcjwMgbzOeBwIB1hBW3db4Dxss haE=.#=qYS30yvukWtx47te4aQsStWF5XhVpKTjCxQg TQK$8qzw=(String #=qTz48NWnxmwHlsbiLP01Cwg==) at System.Collections.Generic.List`1.ForEach(A ction`1 action) at #=qPc42lWHPoKxIqKdcjwMgbzOeBwIB1hBW3db4Dxss haE=.#=qzxMhj8Gh2rCc4Bbh6IsDgQ==() at #=qPc42lWHPoKxIqKdcjwMgbzOeBwIB1hBW3db4Dxss haE=.#=qU_NaK4iQgFsz2eVBQQIT3A==() at #=q_mMq$NOUI_Mh5XgmJXNMWw==.#=q4X9QL3AHYVnq pOvWKfJm7Q==() at #=qcYnIe2yAE8WwfyM2YoPa6c$Chdcbj19kQ7Tt9gXX WiM=.#=q9G0e0sdmJBhMIik8S7yjzA==(String[] #=qSh09aj13RyzMSIKnTMESqg==) [INFO] 6/27/2012 7:51:00 PM.691[HOBD] system width: 800, height: 480 [INFO] 6/27/2012 7:51:00 PM.705[HOBD] wa width: 800, wa height: 480 [INFO] 6/27/2012 7:51:01 PM.657[HOBDAll] hobDrive registered: hdtco4740289376 - Raphael Pais [INFO] 6/27/2012 7:51:02 PM.955[HomePage] System DPI: 96 [INFO] 6/27/2012 7:51:02 PM.975[HomePage] App DPI: 57 [INFO] 6/27/2012 7:51:02 PM.989[HomePage] layout: 475x285 [INFO] 6/27/2012 7:51:03 PM.012[HomePage] form: 242x293 [ERROR] 6/27/2012 7:51:22 PM.404[BluetoothStream] set_Mode System.ComponentModel.Win32Exception: Error setting BluetoothRadio mode at InTheHand.Net.Bluetooth.WindowsBluetoothRad io.set_Mode(RadioMode value) at InTheHand.Net.Bluetooth.BluetoothRadio.set_ Mode(RadioMode value) at hobd.BluetoothStream.Open(String url) at hobd.BluetoothStream.Open(String url) at hobd.OBD2Engine.SetState(String state2) at hobd.OBD2Engine.Run() [ERROR] 6/27/2012 7:51:22 PM.488[OBD2Engine] Init Error System.Net.Sockets.SocketException: An error message is available for this exception but cannot be displayed because these messages are optional and are not currently installed on this device. Please install ‘NETCFv35.Messages.EN.wm.cab’ for Windows Mobile 5.0 and above or â €˜NETCFv35.Messages.EN.cab’ for other platforms. Restart the application to see the message. at System.Net.Sockets.Socket.ConnectNoCheck(En dPoint remoteEP) at System.Net.Sockets.Socket.Connect(EndPoint remoteEP) at InTheHand.Net.Sockets.SocketBluetoothClient .Connect(BluetoothEndPoint remoteEP) at InTheHand.Net.Sockets.BluetoothClient.Conne ct(BluetoothEndPoint remoteEP) at hobd.BluetoothStream.Open(String url) at hobd.BluetoothStream.Open(String url) at hobd.OBD2Engine.SetState(String state2) at hobd.OBD2Engine.Run() [ERROR] 6/27/2012 7:51:45 PM.150[BluetoothStream] set_Mode System.ComponentModel.Win32Exception: Error setting BluetoothRadio mode at InTheHand.Net.Bluetooth.WindowsBluetoothRad io.set_Mode(RadioMode value) at InTheHand.Net.Bluetooth.BluetoothRadio.set_ Mode(RadioMode value) at hobd.BluetoothStream.Open(String url) at hobd.BluetoothStream.Open(String url) at hobd.OBD2Engine.SetState(String state2) at hobd.OBD2Engine.Run() [ERROR] 6/27/2012 7:51:45 PM.195[OBD2Engine] Init Error System.Net.Sockets.SocketException: An error message is available for this exception but cannot be displayed because these messages are optional and are not currently installed on this device. Please install ‘NETCFv35.Messages.EN.wm.cab’ for Windows Mobile 5.0 and above or â €˜NETCFv35.Messages.EN.cab’ for other platforms. Restart the application to see the message. at System.Net.Sockets.Socket.ConnectNoCheck(En dPoint remoteEP) at System.Net.Sockets.Socket.Connect(EndPoint remoteEP) at InTheHand.Net.Sockets.SocketBluetoothClient .Connect(BluetoothEndPoint remoteEP) at InTheHand.Net.Sockets.BluetoothClient.Conne ct(BluetoothEndPoint remoteEP) at hobd.BluetoothStream.Open(String url) at hobd.BluetoothStream.Open(String url) at hobd.OBD2Engine.SetState(String state2) at hobd.OBD2Engine.Run()
Maybe a faulty Bluetooth Dongle?
Добавлено: 28 июн 2012, 03:04
It could be (especially in combination with unstable usb power), but the probability is not high.
My suggestion would be to tryout usb-elm (as it is always a preferred case with in-car audios)
Добавлено: 28 июн 2012, 18:17
Rapa
Thanks for the help... My problem is the Bluetooth dongle... I bought another 2..
One works all the time but don't find the obd2 adapter...
The other 2 turn of the led about 2 seconds after I plug then..
I'll try to find a different dongle or make a external 5v source...
Добавлено: 29 июн 2012, 21:39
Ren001
Hello to all
I am owner of a Roadrover IAI7037V2, also a I9 unit. The problem may be the USB cable: You might need a active USB HUB to provide enough power to drive the OBD device.
I am using a 3G stick and a TMC on my RR and had to install an active hub to have them running reliable.
BTW: I am very interested in your results, cause I am going to connect the OBDII of may car to the RR too. I own a microCAN adapter (USB) produced by Ross Tech, sold by shop.dieselschrauber.de - but have no idea if this is compatible to HobDrive (or ChronoGPS).
Regards
Ren001
Добавлено: 29 июн 2012, 23:32
Yes, the power issue could be quite a reason.
Hobdrive works only with ELM327 compatible adapters. Afraid your adapter is not ELM compatible.
Добавлено: 30 июн 2012, 07:30
Rapa
thanks for the support cail!!!
it was the bluetooth dongle..
i tested 5 different dongles until i find one that works..
I'm so happy!!! see in real time the IAT and Water temp in the dash is awesome..
for reference in future searches: the RoadRover for civic 06-11 with the I9 or D2280 folder works with hobdrive!
one software question... is it possible to change the sensors order? or change what sensor will be displayed on each screen?
for example change the air temp for Timing advance
Добавлено: 30 июн 2012, 10:14
Ren001
Can you give a hint which of the dongles worked? And which ELM adapter you are using?
Thanks!
Добавлено: 30 июн 2012, 13:10
Rapa
that's the tricky part, i'll post picks of what worked... but for example the Bluetooth usb dongle that worked looks identical to other 2 dongles that i tested and didn't work... china cheap stuff.. you never know what you will get...
here we go:
note that is only a internet pic, i really don't remember where I bought the OBD2 adapter(more than 2 years that i have it...) and the usb dongle was from a friend...
Re: [SOLVED]Can't Connect... RoadRover Civic unit
Добавлено: 01 июл 2012, 00:35
Ren001
Thanks, that points to a direction, I think I have to do some testing by myself...
Добавлено: 01 июл 2012, 04:53
Rapa
One more achievement...
Manage to make it work using a cable... In hobd is com6
The driver is from ftdi ser that cail posted
And I followed this instructions from other forum.. Except that I didn't edited anything in the inf file...
When you plug in your wifi dongle a window pops up immediately which is asking for the name of driver.dll. That will happen only the first time. Very important: You have to prepare two things previously. First modify the .inf file to force Windows to create a COM9 Port instead of default COM10. Second copy the .inf file and the .dll to "StaticStore\Bin_CE\" and once more to \Windows. That can be done by Total Commander. When typing in the .dll name you must type the comlete path "\StaticStore\Bin_CE\ftdi_ser.dll". This will create a key to the registry, which is independent of the folder \Windows cause the folder \Windows will be overwritten on every reboot = poweroff/on.
Добавлено: 02 июл 2012, 13:46
Rapa, thanks for sharing!
Добавлено: 14 июл 2012, 19:48
Ren001
Rapa писал(а): but for example the Bluetooth usb dongle that worked looks identical to other 2 dongles that i tested and didn't work.
I bought this one: mumbi Nano Bluetooth Dongle Mini USB-Adapter Class2 EDR V2.0 100m
http://www.amazon.de/mumbi-Bluetooth-Do ... B002T4E7L8
and it works with the Roadrover IAI7037V2 and Hobdrive.
Добавлено: 15 июл 2012, 06:24
Rapa
thanks! that will help future users!!
Re: [SOLVED] Can't Connect RoadRover Civic unit: BT dongle i
Добавлено: 12 фев 2016, 09:45
james442
Hi,
