Cut Off Process
Добавлено: 22 ноя 2012, 15:39
Pangadaywalker
I am really interested to know if the Cut Off process is correctly detected?
I tried almost every android app for ODB2 but none can detect the cut off process.
I saw this one have some setups for Trim process (lambda, TFT, etc).
Does anyone ever tried the cut off?
Re: Cut Off Process
Добавлено: 22 ноя 2012, 19:51
hobdrive detects fuel cutoff correctly on major part of vehicles. There are some exceptions with problems, but if your vehicle is problematic, we can review and tuneup detection precistion.
PS. The option is only available in payed version, so unfortunately you have to buy to try.
Re: Cut Off Process
Добавлено: 22 ноя 2012, 20:05
Pangadaywalker
In theory my car is based on Delphi injection system. Does any other car with that works?
The problem is buying something without making sure it will work. It was like this with Torque but at least torque was just couple bucks.
And I only have Galaxy 5 phone. It is pretty heavy. The app almost doesn't work.... the UI should be much much more lighter.
Re: Cut Off Process
Добавлено: 22 ноя 2012, 20:15
What car do you have?
With google play you have 15 mins to tryout full version. Moreover, we can handle order cancellation even later if you really feel unsatisfied or cutoff will not work for your vehicle.
UI speed major improvement is planned on next delivery (couple of weeks). We have a space for optimization in there.
Re: Cut Off Process
Добавлено: 22 ноя 2012, 20:37
Pangadaywalker
ok. I will wait for the next release then and use the 15 minutes try it out.
My car is chinese JAC Motors J6
