I use a Sequential injection LPG System for my car.
LPG System is working like that:
When
Coolant Temp < 47 C LPG is OFF, Petrol is ON
Coolant Temp => 47 C LPG is ON, Petrol is OFF
I set my Warm Engine Temprature:47
With this
"Fuel in Cold" means "Fuel Consumed on Petrol"
"Fuel in Warm" means "Fuel Consumed on LPG"
First question:
I want to see a value like "c/w ratio" (Fuel in Cold/Fuel in Warm) on Hobdrive Screen. if it is possible this value gives me "Petrol/LPG consumed fuel ratio"
Second question:
I want to calibrate my "Tank Level" value to "LPG Tank Level "
I want
Tank Level's calculating ON when Coolant Temp => 47
Tank Level's calculating OFF when Coolant Temp < 47
In other words, can we make Tank Level's calculation with "Fuel economy_WarmEngine" parameter and can i see the different name on Hobdrive screen like "LPG Tank Level" ?
Last question:
If these are possible, i want to enter 2 values on "Fuel Price Setup Menu".
Petrol Cost
LPG Cost
So new "Fuel Cost" or can be rename "LPG Fuel Cost"= Fuel Consumed in Warm(LPG) x LPG Cost + Fuel Consumed in Cold(Petrol) x Petrol Cost" can be calculating like this.
If all this is possible, may be i can see LPG values in the different section like Hobdrive's new "Hybrid" section.
I modified "GPS" section to "LPG" . May be i can add new LPG parameters here
Thanks for answering.
PS SORRY FOR MY ENGLISH
