Hyundai Accent LC (2000-2002) - DTC
Добавлено: 26 дек 2011, 11:51
hpcnr
Because i don't know where to post about this, I write here :
- a file dtc-standard.txt is not compatible with Hyundai Accent 2000 (LC 2000-2002), now
working on a file for this car after yor model. Then I'll put here, on forum, in case if you need it.
After i'm finished a file, i can put it in "doc" near other files ? The program will see it and "work" with him ?
Re: Hyundai Accent LC (2000-2002) - DTC
Добавлено: 26 дек 2011, 14:33
Right, to make it work, put it into "doc" and name it with "dtc-" prefix.
Appreciate if you'll share your work later on here.
Добавлено: 26 дек 2011, 19:28
hpcnr
"Right, to make it work, put it into "doc" and name it with "dtc-" prefix. "
Ok Cail.
"Appreciate if you'll share your work later on here. "
Of course !!! :D
