Iranian Care Connect
hamed-pc » 13 фев 2018, 07:30
hi
good day
i have Car Kia Pride ( KIA Avella ) included ECU Siemens 1.3i
i try connect with ELM USB version FTDI Chip . But Do not connect and communicated my care and hobdrive android version
also not included template kia/ pride or Avella Car . If possible please add this model to hobdrive
But i can connect with original software hi scan pro pc base version
Can you hellp me fo solve this problem ?
Re: Iranian Care Connect
kdika » 13 фев 2018, 19:29
Hi.
What year is the car?
hamed-pc » 14 фев 2018, 04:37
Hi
my car year is after 1996 . i mean is 2003
cail » 14 фев 2018, 14:01
Then you basically should try to connect with "Standard OBD" profile.
hamed-pc » 15 фев 2018, 06:58
hi
thank you
do you mean this page ?
https://www.overpic.net/viewer.php?file ... 4u4wfu.jpg
and please tell me how to setting other field . for example
elm lnit template
elm lnit string
MPG method
please help Full
thank you
hamed-pc » 17 фев 2018, 04:20
cail писал(а):Then you basically should try to connect with "Standard OBD" profile.
hi
i try to connect this model . But not connect . also change other protocol and test many vehicle model . not response on hobdrive . But very good work with original software on desktop windows
i think my care not obd2 standard . maybe obd1 . but i don't know witch protocol using .
please tell me how to connect hobdrive or how to use hobdrive on this care .
for Remind . my care very simple kia avella because on original software when use kia avella section
is ok and connect very well
i have question , Is there any other protocol? Except all obd2 iso ?
Can you help me for run this way ?
can do scan k line signal for know with protocol use .? and use on hobdrive software ?
excuse me for bad English typing
thank you and best regards
kdika » 17 фев 2018, 04:47
Hi.
hamed-pc писал(а): But very good work with original software on desktop windows
What is soft?
hamed-pc писал(а):i think my care not obd2 standard . maybe obd1
maybe
hamed-pc » 17 фев 2018, 16:07
kdika писал(а):Hi.
What is soft?
maybe
Hi
The soft Hi scan Pro Desktop windows .
if this ecu obd1 How to connect with hobdrive ?
kdika » 21 фев 2018, 17:30
elm not support obd1
hamed-pc » 23 фев 2018, 11:29
hi
what do you mean of eml ? inside elm adapter have FT Chip and level converter ic . i have this adapter work on my car but with original soft well , and support obd2 all of Asian Korean and European Care up to 2011 .
i think this adapter should be work with hobdrive and mycar . If Config and setting k line signal only receive for RX pin . do not send signal with TX pin
kdika » 24 фев 2018, 05:37
hamed-pc писал(а):hi
Hi.
Elm adapter has internally programmed chip: https://www.elmelectronics.com/wp-conte ... M327DS.pdf
hamed-pc писал(а): i have this adapter work on my car but with original soft well , and support obd2 all of Asian Korean and European Care up to 2011 .
You probably have an ordinary k-line adapter. With such adapters hobdrive does not work.
hamed-pc » 24 фев 2018, 10:57
hi
thank you answer me
i Have Interface VAG 409.1 this picture
Do you mean i need programmable chip for example ELm327 CHIP ?
Can i use STN1110 ?
please send me with model of adapter compatible hobdrtive . i need see chip for this model adapter becuse i want to make with myself . because i'm living in Iran . i have not this model adapter on store
thank you
