Unsuccessful connect with car.
opel
Сообщение opel »
Hello,I have Opel Astra G, ELM327 Bluetooth, and GPS with Windows 6.0
When I trying connection with my car at the beginning files are initiated (point in left corner is yellow)
but next I have fault:
" /hobd ERROR UNABLE TO CONNECT "
and point is red.
What am I doing wrong?
It is by car?
I waiting for help.Thanks
Re: Unsuccessful connect with car.
Hi!
This error means that ELM adapter can't find your vehicle. Are you sure your vehicle is OBD2 compatible?
If so, try to setup ELM init template as "ELM Reset" in vehicle settings. This may reset the adapter and force it to find your vehicle.
opel
Сообщение opel »
Ok, I go to garage and checking :)
EDIT:
I checked and no results.
If I click "UPDATE" for searching bluetooth device, in field "ELM Port Name" is "CHX" or "001112170111".
I get PIN for adapter too, then Ok. But point is ever yellow or red and "/hobd ERROR UNABLE TO CONNECT"
I have OBDII in my car.
In "Vehicle settings" i have:
Vehicle Type - Standard
ELM Init Template - ELM RESET
ELM Init String - ATSP 0
MPG method - MAF SENSOR
cail have you to me more suggestions , what I can make?
Thanks
What year your vehicle is? Is there any other OBD2 software you was able to successfully use with your vehicle? It looks like the vehicle is not OBD2 compatible and ELM adapter just can't read it.
opel
Сообщение opel »
Hi cail,
I have Opel Astra G year:ending 1999.
I connect with ELM327 BT in my laptop.Pro"easyOBDII"
Can you try connect it with HOBD on your laptop? (use hobd-win32 package)
opel
Сообщение opel »
Hello,
Sorry I had leave.
I can try with laptop in next week.
But I have new information.I try today again connect with my GPS.
And first when I started GPS was "voice engine". I could read only 'Battery Volltage' (11,6 to 13,5V with on engine).
Point was for a while Green, then again Yellow (was INIT etc) but not once Red.
When point was Green, was alert :
/hobd OK 180ms (307old) 0
What do you think ceil , maybe will be connect my car?
could you please enable TRACE logging (in system settings), try to connect and then put here the log.txt file.
opel
Сообщение opel »
Hi cail
I tried with enable Trace logging but no results.
Here log.txt:
[INFO]   1/1/2003 12:00:53 PM.002[HOBD]  HOBD 1.1.1 24.02.2012  14:34
[INFO]   1/1/2003 12:00:53 PM.149[HOBD]  Env: 3.5.7283.0
[INFO]   1/1/2003 12:00:53 PM.970[ConfigData]  failure loading config.xml, using defaults
[ERROR]   1/1/2003 12:00:54 PM.304[ConfigData]  ReadVehicles error
System.IO.FileNotFoundException: An error message is available for this exception but cannot be displayed because these messages are optional and are not currently installed on this device. Please install ‘NETCFv35.Messages.EN.wm.cab’ for Windows Mobile 5.0 and above or  ‘NETCFv35.Messages.EN.cab’ for other platforms. Restart the application to see the message.
   at #=qtdNp7kzD4N4Mqty82ZHFPafYzKKnJq3n0xzCEsSE$s4=.#=qRsBmIbwgRkAGtBZxdzlgLA==(String #=qdWNWOAbk3sSvV7Orb04_EA==, String #=q7qwateEzrYXJzUFaND4M8g==)
   at #=qtdNp7kzD4N4Mqty82ZHFPafYzKKnJq3n0xzCEsSE$s4=..ctor(String #=qkR5VSHJ0ZOE1w0Dti9MNaw==)
   at #=queSlQ6WOwqlLYH3QsyFJK3LG9wDtR6wuXiVTPMnBgSo=.#=q_EH4fEFbfiQ_tqFflfFKmA==()
   at #=qemyrhFzVjqMRdsGEWu$9lQ==.#=qrIZO76EQPMJEaiXgp3O51Q==()
   at #=qsn5YiReJqOOgWguWkwcpkg==.#=qp$Y68N4sL$EWs2aDqswyWA==(String[] #=qM$ch0Osy81ygpZG0onoQ5g==)
[INFO]   1/1/2003 12:00:54 PM.416[HOBD]  SN: 504100E1-1000-1003-3001-4E00610076002D00360031000000
[INFO]   1/1/2003 12:00:54 PM.807[HOBD]  Vehicle: OBD-II compatible
[ERROR]   1/1/2003 12:00:54 PM.998[HOBD]  bad provider ecuxml://\SDMMC\Pictures\hobd-1.1.1.wince-standalone-1\ecu/obd2.ecuxml
System.Exception: unknown tag `command` while creating PID Lambda11
   at hobd.ECUXMLSensorProvider.init(SensorRegistry registry)
   at hobd.ECUXMLSensorProvider.Activate(SensorRegistry registry)
   at hobd.SensorRegistry.RegisterProvider(SensorProvider provider)
   at #=queSlQ6WOwqlLYH3QsyFJK3LG9wDtR6wuXiVTPMnBgSo=.#=qYbfmgSv9IK7nU8yg9itpObmzP2a8HTUFWGe0jLVvkvE=(String #=qCpA2yT9JmyyxP5CYdok8Cw==)
   at #=queSlQ6WOwqlLYH3QsyFJK3LG9wDtR6wuXiVTPMnBgSo=.#=q4p1l7P2TL5YDzMbY2p0Dew==()
   at #=queSlQ6WOwqlLYH3QsyFJK3LG9wDtR6wuXiVTPMnBgSo=.#=qNkRdgpRnBCG8_s7mBF4X6g==()
[ERROR]   1/1/2003 12:00:55 PM.099[HOBD]  bad provider ecuxml://\SDMMC\Pictures\hobd-1.1.1.wince-standalone-1\user.ecuxml
[ERROR]   1/1/2003 12:00:55 PM.275[SensorStorage]  error reading
   at System.IO.FileStream..ctor(String path, FileMode mode)
   at hobd.SensorStorage.Attach(SensorRegistry registry)
[INFO]   1/1/2003 12:00:55 PM.699[HOBD]  system width: 480, height: 272
[INFO]   1/1/2003 12:00:55 PM.709[HOBD]  wa width: 480, wa height: 272
[INFO]   1/1/2003 12:00:56 PM.537[HomePage]  System DPI: 96
[INFO]   1/1/2003 12:00:56 PM.545[HomePage]  App DPI: 96
[INFO]   1/1/2003 12:00:56 PM.553[HomePage]  layout: 480x272
[INFO]   1/1/2003 12:00:56 PM.562[HomePage]  form: 242x293
[ERROR]   1/1/2003 12:00:59 PM.833[OBD2Engine]  Init Error
System.ArgumentNullException: An error message is available for this exception but cannot be displayed because these messages are optional and are not currently installed on this device. Please install ‘NETCFv35.Messages.EN.wm.cab’ for Windows Mobile 5.0 and above or  ‘NETCFv35.Messages.EN.cab’ for other platforms. Restart the application to see the message.
   at System.IO.Ports.SerialPort.set_PortName(String value)
   at System.IO.Ports.SerialPort..ctor(String portName, Int32 baudRate, Parity parity, Int32 dataBits, StopBits stopBits)
   at hobd.SerialRawStream.Open(String url)
   at hobd.OBD2Engine.SetState(String state2)
   at hobd.OBD2Engine.Run()
[ERROR]  3/23/2012 12:57:15 PM.990[OBD2Engine]  Init Error
[ERROR]  3/23/2012 12:57:18 PM.215[ConfigData]  ReadVehicles error
   at #=qp79t5UdhpuWPDK7YDjoQhqKn1w0dyvZrQkHxjYFgeX8=.#=q0kzEOpeRrLBeSAgFSjX5sQ==()
   at #=qp79t5UdhpuWPDK7YDjoQhqKn1w0dyvZrQkHxjYFgeX8=.#=qgImm$$lJisAoVVfyTZQQxnFQOPefbhI8T65YeyN7Xls=()
   at #=qp79t5UdhpuWPDK7YDjoQhqKn1w0dyvZrQkHxjYFgeX8=..ctor(Form #=qICGqLWEGYS6fR$OS66xJuA==)
   at hobd.HomePage.#=qNz1gUZTLUdvk$YHrtqU$VQ==(#=qBMJMYTSMEd4NYTyE5bizaSWJYKefxFY8uHKOcuZrT7E= #=qSSPostWgU38RjmwQJKCeCw==)
   at hobd.HomePage.#=qezklVWnb8QTEN3hVS8vyyA==(#=qBMJMYTSMEd4NYTyE5bizaSWJYKefxFY8uHKOcuZrT7E= #=q1DWEi_LAzi$$qaE1XcaGHw==)
   at hobd.HomePage.#=q4tqpcve_sKcQ8AjIfirf7A==(String #=qK_j2hSF6Ay5u4oM0XiX2$Q==, Sensor #=qa5Cg36WOWkrM4Y3mY7TpVQ==)
   at hobd.HomePage.#=qs40thvuMbqykfQURvOYNCSDA5n4LLYzwx8Q0qV7YCnQ=()
   at hobd.HomePage.#=qVnJF1eeXbuus8THjtVlou7nUE9zro3wk5FPTWPRFfTs=.#=qXmPVFnikGo8VsYVlsUuhzIvs6uHPwfa29WE45BapNj4=(Object #=qpccw33UQ7G4rgIzqOOZ9fg==, EventArgs #=qP$y860crBlaI5FL4sIUSTA==)
   at System.Windows.Forms.Timer._WnProc(WM wm, Int32 wParam, Int32 lParam)
   at System.Windows.Forms.ApplicationThreadContext._InternalContextMessages(WM wm, Int32 wParam, Int32 lParam)
   at Microsoft.AGL.Forms.EVL.EnterMainLoop(IntPtr hwnMain)
   at System.Windows.Forms.Application.Run(Form fm)
   at Fleux.Core.FleuxApplication.Run(FleuxPage mainPage)
   at #=qemyrhFzVjqMRdsGEWu$9lQ==.#=q5ir67gooYkvb4akERGWjRQ==(String #=qPWCaamlevqDfMrc2HMTttg==)
[INFO]  3/23/2012 12:57:19 PM.930[OBD2Engine]  VersionInfo: ELM327 v1.4
[INFO]  3/23/2012 12:57:21 PM.306[OBD2Engine]  Sensor Init:BUS INIT: ERROR
[INFO]  3/23/2012 12:57:21 PM.455[OBD2Engine]  ProtocolId: 5
[ERROR]  3/23/2012 12:57:27 PM.176[MILTrace]  dataraw:
[ERROR]  3/23/2012 12:57:28 PM.101[MILTrace]  dataraw:
[ERROR]  3/23/2012 12:57:59 PM.645[MILTrace]  dataraw:
[ERROR]  3/23/2012 12:58:00 PM.578[MILTrace]  dataraw:
[ERROR]  3/23/2012 12:58:01 PM.545[VehicleForm]  LoadModel
System.ArgumentNullException: ArgumentNullException
   at System.Double.Parse(String s, NumberStyles style, IFormatProvider provider)
   at System.Double.Parse(String s, IFormatProvider provider)
   at #=qsNd0vr3JL1jqtJeODxSSpm3LVgar9PiwhbwVd83ntYA=.#=qzEmE66fikSaTLWrz$AWBSg==()
   at #=qsNd0vr3JL1jqtJeODxSSpm3LVgar9PiwhbwVd83ntYA=.#=qcC9C1AyOp5bmEBB6gfKnt1b$dXeBuWujEOmfZrC9IAw=()
   at #=qsNd0vr3JL1jqtJeODxSSpm3LVgar9PiwhbwVd83ntYA=..ctor(Form #=qitNwZiA0QeKVQOcDoxU50Q==)
   at hobd.HomePage.#=q$5aNkDzW5Yv_NfXBIMtS9g==(#=qBMJMYTSMEd4NYTyE5bizaSWJYKefxFY8uHKOcuZrT7E= #=qPLL$o6ivrGQ$TGURQBtebQ==)
   at hobd.HomePage.#=q_I3dem$m9sLQXAdirR2y9WCGjlGytReoUjWlZqj7rpg=.#=qNstp_U5bub1SYCDWE1meNmk4I9mq5O6dDaaUklvT6B0=(Point #=qbxJkkxklnS9qEbcPJWnZ3w==)
   at Fleux.UIElements.UIElement.Tap(Point p)
   at Fleux.UIElements.UIElement.<>c__DisplayClassa.<Tap>b__9(UIElement el)
   at Fleux.UIElements.UIElement.TraverseHandle(Point start, Func`2 elementHandler)
   at Fleux.UIElements.Panorama.PanoramaElement.Tap(Point p)
   at Fleux.Controls.FleuxControl.<>c__DisplayClass1b.<Tap>b__19()
   at System.Reflection.RuntimeMethodInfo.InternalInvoke(RuntimeMethodInfo rtmi, Object obj, BindingFlags invokeAttr, Binder binder, Object parameters, CultureInfo culture, Boolean isBinderDefault, Assembly caller, Boolean verifyAccess, StackCrawlMark& stackMark)
   at System.Reflection.RuntimeMethodInfo.InternalInvoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean verifyAccess, StackCrawlMark& stackMark)
   at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
   at System.Reflection.MethodBase.Invoke(Object obj, Object[] parameters)
   at System.Windows.Forms.Control.TASK.Invoke()
   at System.Windows.Forms.Control._InvokeAll()
   at System.Windows.Forms.Control.InvokeHelper(Delegate method, Boolean fSynchronous, Object[] rgobjArgs)
   at Fleux.Controls.FleuxControl.Tap(Point p)
   at Fleux.Controls.Gestures.GesturesEngine.RaiseTap(Point p)
   at Fleux.Controls.Gestures.GesturesEngine.MouseUp(Point point)
   at Fleux.Controls.FleuxControl.OnMouseUp(MouseEventArgs e)
   at System.Windows.Forms.Control.WnProc(WM wm, Int32 wParam, Int32 lParam)
   at System.Windows.Forms.Control._InternalWnProc(WM wm, Int32 wParam, Int32 lParam)
   at Microsoft.AGL.Forms.EVL.Yield()
   at Fleux.Animations.StoryBoard.AnimateSync()
   at Fleux.Animations.StoryBoard.Play(IAnimation animation)
   at #=q8zb1AsDA8ukzCYw4e533Eg==.#=qtNj1ivde8uu7WZk5tIHh6w==()
   at #=q8zb1AsDA8ukzCYw4e533Eg==.#=qZ0hXIV6DaD0rXkFLPOzMFQ==()
   at hobd.HomePage.#=quSt4MyE0kcFRcnKNF_xjv1WPrueV8GM17eWzWI0p5T0=.#=qUt08T$MxZpelpP2brQLI6$ZvpH4cMmDg$tdJb59msmc=.#=qnvvoZ2dkHs9BbARin$6K5N1DiArU1JVll42Fl2ijJEc=(Point #=qst3vFxhRCyX$A1onutqlcw==)
   at Microsoft.AGL.Forms.EVL.EnterModalDialog(IntPtr hwnModal)
   at System.Windows.Forms.Form.ShowDialog()
[INFO]  3/23/2012 12:58:38 PM.780[HOBD]  Vehicle: My Vehicle
[ERROR]  3/23/2012 12:58:39 PM.222[HOBD]  bad provider ecuxml://\SDMMC\Pictures\hobd-1.1.1.wince-standalone-1\ecu/obd2.ecuxml
[ERROR]  3/23/2012 12:58:39 PM.578[HOBD]  bad provider ecuxml://\SDMMC\Pictures\hobd-1.1.1.wince-standalone-1\user.ecuxml
[INFO]  3/23/2012 12:58:40 PM.396[HomePage]  System DPI: 96
[INFO]  3/23/2012 12:58:40 PM.405[HomePage]  App DPI: 96
[INFO]  3/23/2012 12:58:40 PM.411[HomePage]  layout: 480x272
[INFO]  3/23/2012 12:58:40 PM.419[HomePage]  form: 480x272
[INFO]  3/23/2012 12:58:44 PM.995[OBD2Engine]  VersionInfo: ELM327 v1.4
[INFO]  3/23/2012 12:58:46 PM.463[OBD2Engine]  Sensor Init:BUS INIT: ERROR
[INFO]  3/23/2012 12:58:46 PM.616[OBD2Engine]  ProtocolId: 5
[ERROR]  3/23/2012 12:58:50 PM.628[MILTrace]  dataraw:
[ERROR]  3/23/2012 12:58:51 PM.559[MILTrace]  dataraw:
[INFO]  3/23/2012 1:00:26 PM.003[HOBD]  HOBD 1.1.1 24.02.2012  14:34
[INFO]  3/23/2012 1:00:26 PM.127[HOBD]  Env: 3.5.7283.0
[INFO]  3/23/2012 1:00:27 PM.401[HOBD]  SN: 504100E1-1000-1003-3001-4E00610076002D00360031000000
[INFO]  3/23/2012 1:00:27 PM.811[HOBD]  Vehicle: My Vehicle
[ERROR]  3/23/2012 1:00:27 PM.996[HOBD]  bad provider ecuxml://\SDMMC\Pictures\hobd-1.1.1.wince-standalone-1\ecu/obd2.ecuxml
opel
Сообщение opel »
[ERROR]  3/23/2012 1:00:28 PM.114[HOBD]  bad provider ecuxml://\SDMMC\Pictures\hobd-1.1.1.wince-standalone-1\user.ecuxml
[INFO]  3/23/2012 1:00:28 PM.452[HOBD]  system width: 480, height: 272
[INFO]  3/23/2012 1:00:28 PM.464[HOBD]  wa width: 480, wa height: 272
[INFO]  3/23/2012 1:00:29 PM.307[HomePage]  System DPI: 96
[INFO]  3/23/2012 1:00:29 PM.314[HomePage]  App DPI: 96
[INFO]  3/23/2012 1:00:29 PM.321[HomePage]  layout: 480x272
[INFO]  3/23/2012 1:00:29 PM.332[HomePage]  form: 242x293
[INFO]  3/23/2012 1:00:36 PM.635[OBD2Engine]  VersionInfo: ELM327 v1.4
[INFO]  3/23/2012 1:00:38 PM.100[OBD2Engine]  Sensor Init:BUS INIT: ERROR
[INFO]  3/23/2012 1:00:38 PM.250[OBD2Engine]  ProtocolId: 5
[ERROR]  3/23/2012 1:00:44 PM.045[MILTrace]  dataraw:
[ERROR]  3/23/2012 1:00:44 PM.983[MILTrace]  dataraw:
[ERROR]  3/23/2012 1:01:03 PM.731[VehicleForm]  LoadModel
[ERROR]  3/23/2012 1:01:04 PM.165[MILTrace]  dataraw:
[ERROR]  3/23/2012 1:01:05 PM.137[MILTrace]  dataraw:
[INFO]  3/23/2012 1:01:43 PM.002[HOBD]  HOBD 1.1.1 24.02.2012  14:34
[INFO]  3/23/2012 1:01:43 PM.137[HOBD]  Env: 3.5.7283.0
[INFO]  3/23/2012 1:01:44 PM.435[HOBD]  SN: 504100E1-1000-1003-3001-4E00610076002D00360031000000
[INFO]  3/23/2012 1:01:46 PM.821[HOBD]  Vehicle: My Vehicle
[TRACE]  3/23/2012 1:01:46 PM.979[HOBD]  RegisterProvider: hobd.OBD2Sensors
[TRACE]  3/23/2012 1:01:47 PM.156[HOBD]  RegisterProvider: ecuxml://ecu/obd2.ecuxml
[ERROR]  3/23/2012 1:01:47 PM.211[HOBD]  bad provider ecuxml://\SDMMC\Pictures\hobd-1.1.1.wince-standalone-1\ecu/obd2.ecuxml
[TRACE]  3/23/2012 1:01:47 PM.261[HOBD]  RegisterProvider: hobd.ELMSensors
[TRACE]  3/23/2012 1:01:47 PM.278[HOBD]  RegisterProvider: hobd.MAFSensors
[TRACE]  3/23/2012 1:01:47 PM.293[HOBD]  RegisterProvider: hobd.CommonSensors
[TRACE]  3/23/2012 1:01:47 PM.316[HOBD]  RegisterProvider: ecuxml://ecu/default.ecuxml
[TRACE]  3/23/2012 1:01:47 PM.338[HOBD]  RegisterProvider: ecuxml://user.ecuxml
[ERROR]  3/23/2012 1:01:47 PM.383[HOBD]  bad provider ecuxml://\SDMMC\Pictures\hobd-1.1.1.wince-standalone-1\user.ecuxml
[TRACE]  3/23/2012 1:01:47 PM.517[FCS]  lph: MAF.LitersPerHour
[TRACE]  3/23/2012 1:01:47 PM.535[FCS]  lph: MAF.LitersPerHour
[TRACE]  3/23/2012 1:01:47 PM.545[FCS]  lph: MAF.LitersPerHour
[TRACE]  3/23/2012 1:01:47 PM.797[HOBD]  Connecting stream: btspp://001112170111;pin=6789
[INFO]  3/23/2012 1:01:47 PM.815[HOBD]  system width: 480, height: 272
[INFO]  3/23/2012 1:01:47 PM.826[HOBD]  wa width: 480, wa height: 272
[TRACE]  3/23/2012 1:01:48 PM.535[HomePage]  tap distance 26
[INFO]  3/23/2012 1:01:48 PM.602[HomePage]  System DPI: 96
[INFO]  3/23/2012 1:01:48 PM.613[HomePage]  App DPI: 96
[INFO]  3/23/2012 1:01:48 PM.627[HomePage]  layout: 480x272
[INFO]  3/23/2012 1:01:48 PM.638[HomePage]  form: 242x293
[INFO ]  3/23/2012 1:01:55 PM.427[HomePage]  no layout file user.layout
[TRACE]  3/23/2012 1:01:56 PM.147[OBD2Engine]   -> INIT
[INFO ]  3/23/2012 1:01:56 PM.241[OBD2Engine]  Open btspp://001112170111;pin=6789
[TRACE]  3/23/2012 1:01:57 PM.156[BluetoothStream]  Open 001112170111 serviceid  pin 6789
[TRACE]  3/23/2012 1:02:02 PM.535[BluetoothStream]  Open 001112170111 serviceid  pin 6789
[TRACE]  3/23/2012 1:02:05 PM.313[OBD2Engine]   -> ATZ
[TRACE]  3/23/2012 1:02:05 PM.406[OBD2Engine]  SendCommand:ATZ
[TRACE]  3/23/2012 1:02:06 PM.281[OBD2Engine]  HandleReply: ELM327 v1.4
[TRACE]  3/23/2012 1:02:06 PM.293[OBD2Engine]  SendCommand:ATZ
[TRACE]  3/23/2012 1:02:07 PM.155[OBD2Engine]  HandleReply: ATZ
ELM327 v1.4
[INFO]  3/23/2012 1:02:07 PM.165[OBD2Engine]  VersionInfo: ELM327 v1.4
[TRACE]  3/23/2012 1:02:07 PM.179[OBD2Engine]   -> ATE0
[TRACE]  3/23/2012 1:02:07 PM.288[OBD2Engine]  SendCommand:ATE0
[TRACE]  3/23/2012 1:02:07 PM.355[OBD2Engine]  HandleReply: ATE0
OK
[TRACE]  3/23/2012 1:02:07 PM.365[OBD2Engine]   -> ATL0
[TRACE]  3/23/2012 1:02:07 PM.462[OBD2Engine]  SendCommand:ATL0
[TRACE]  3/23/2012 1:02:07 PM.530[OBD2Engine]  HandleReply: OK
[TRACE]  3/23/2012 1:02:07 PM.541[OBD2Engine]   -> EXTRAINIT
[TRACE]  3/23/2012 1:02:07 PM.648[OBD2Engine]   -> SENSOR_INIT
[TRACE]  3/23/2012 1:02:07 PM.801[OBD2Engine]  SendCommand:0100
[TRACE]  3/23/2012 1:02:08 PM.750[OBD2Engine]  HandleReply: BUS INIT: ERROR
[INFO]  3/23/2012 1:02:08 PM.758[OBD2Engine]  Sensor Init:BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:08 PM.769[OBD2Engine]   -> QUERY_PROTOCOL
[TRACE]  3/23/2012 1:02:08 PM.861[OBD2Engine]  SendCommand:ATDPN
[TRACE]  3/23/2012 1:02:08 PM.925[OBD2Engine]  HandleReply: 5
[INFO]  3/23/2012 1:02:08 PM.931[OBD2Engine]  ProtocolId: 5
[TRACE]  3/23/2012 1:02:08 PM.942[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:09 PM.062[OBD2Engine]   ----> OBD2.Speed
[TRACE]  3/23/2012 1:02:09 PM.069[OBD2Engine]  SendCommand:010D
[TRACE]  3/23/2012 1:02:09 PM.079[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:10 PM.015[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:10 PM.022[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:10 PM.029[OBD2Engine]   ----> OBD2.MAF
[TRACE]  3/23/2012 1:02:10 PM.037[OBD2Engine]  SendCommand:0110
[TRACE]  3/23/2012 1:02:10 PM.046[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:10 PM.985[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:10 PM.994[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:11 PM.002[OBD2Engine]   ----> OBD2.CoolantTemp
[TRACE]  3/23/2012 1:02:11 PM.009[OBD2Engine]  SendCommand:0105
[TRACE]  3/23/2012 1:02:11 PM.018[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:11 PM.950[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:11 PM.959[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:11 PM.967[OBD2Engine]   ----> OBD2.LTFT1
[TRACE]  3/23/2012 1:02:11 PM.977[OBD2Engine]  SendCommand:0107
[TRACE]  3/23/2012 1:02:11 PM.988[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:12 PM.920[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:12 PM.927[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:12 PM.937[OBD2Engine]   ----> OBD2.LTFT2
[TRACE]  3/23/2012 1:02:12 PM.945[OBD2Engine]  SendCommand:0109
[TRACE]  3/23/2012 1:02:12 PM.953[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:13 PM.895[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:13 PM.907[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:13 PM.915[OBD2Engine]   ----> OBD2.MIL
[TRACE]  3/23/2012 1:02:13 PM.923[OBD2Engine]  SendCommand:03
[TRACE]  3/23/2012 1:02:13 PM.932[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:14 PM.860[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:14 PM.868[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:14 PM.876[OBD2Engine]   ----> OBD2.PMIL
[TRACE]  3/23/2012 1:02:14 PM.885[OBD2Engine]  SendCommand:07
[TRACE]  3/23/2012 1:02:14 PM.895[OBD2Engine]   -> SENSOR_ACK
[ERROR]  3/23/2012 1:02:14 PM.905[MILTrace]  dataraw:
[TRACE]  3/23/2012 1:02:15 PM.830[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:15 PM.841[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:15 PM.851[OBD2Engine]   ----> ELM.BatteryVoltage
[TRACE]  3/23/2012 1:02:15 PM.859[OBD2Engine]  SendCommand:ATRV
[TRACE]  3/23/2012 1:02:15 PM.868[OBD2Engine]   -> SENSOR_ACK
[ERROR]  3/23/2012 1:02:15 PM.879[MILTrace]  dataraw:
[TRACE]  3/23/2012 1:02:15 PM.939[OBD2Engine]  HandleReply: 11.2V
[TRACE]  3/23/2012 1:02:15 PM.947[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:15 PM.956[OBD2Engine]   ----> OBD2.RPM
[TRACE]  3/23/2012 1:02:15 PM.965[OBD2Engine]  SendCommand:010C
[TRACE]  3/23/2012 1:02:15 PM.975[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:16 PM.921[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:16 PM.928[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:16 PM.938[OBD2Engine]   ----> OBD2.IntakeAirTemp
[TRACE]  3/23/2012 1:02:16 PM.950[OBD2Engine]  SendCommand:010F
[TRACE]  3/23/2012 1:02:16 PM.960[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:17 PM.895[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:17 PM.905[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:17 PM.914[OBD2Engine]   ----> OBD2.AirTemp
[TRACE]  3/23/2012 1:02:17 PM.922[OBD2Engine]  SendCommand:0146
[TRACE]  3/23/2012 1:02:17 PM.934[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:18 PM.867[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:18 PM.875[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:18 PM.887[OBD2Engine]   ----> OBD2.Speed
[TRACE]  3/23/2012 1:02:18 PM.897[OBD2Engine]  SendCommand:010D
[TRACE]  3/23/2012 1:02:18 PM.906[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:19 PM.830[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:19 PM.840[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:19 PM.852[OBD2Engine]   ----> OBD2.MAF
[TRACE]  3/23/2012 1:02:19 PM.863[OBD2Engine]  SendCommand:0110
[TRACE]  3/23/2012 1:02:19 PM.875[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:20 PM.800[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:20 PM.809[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:20 PM.819[OBD2Engine]   ----> OBD2.RPM
[TRACE]  3/23/2012 1:02:20 PM.829[OBD2Engine]  SendCommand:010C
[TRACE]  3/23/2012 1:02:20 PM.841[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:21 PM.790[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:21 PM.802[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:21 PM.814[OBD2Engine]   ----> OBD2.Speed
[TRACE]  3/23/2012 1:02:21 PM.824[OBD2Engine]  SendCommand:010D
[TRACE]  3/23/2012 1:02:21 PM.835[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:22 PM.786[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:22 PM.797[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:22 PM.808[OBD2Engine]   ----> OBD2.MAF
[TRACE]  3/23/2012 1:02:22 PM.818[OBD2Engine]  SendCommand:0110
[TRACE]  3/23/2012 1:02:22 PM.833[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:23 PM.761[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:23 PM.771[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:23 PM.784[OBD2Engine]   ----> OBD2.CoolantTemp
[TRACE]  3/23/2012 1:02:23 PM.794[OBD2Engine]  SendCommand:0105
[TRACE]  3/23/2012 1:02:23 PM.805[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:24 PM.753[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:24 PM.763[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:24 PM.777[OBD2Engine]   ----> ELM.BatteryVoltage
[TRACE]  3/23/2012 1:02:24 PM.787[OBD2Engine]  SendCommand:ATRV
[TRACE]  3/23/2012 1:02:24 PM.801[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:24 PM.865[OBD2Engine]  HandleReply: 13.3V
[TRACE]  3/23/2012 1:02:24 PM.875[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:24 PM.886[OBD2Engine]   ----> OBD2.RPM
[TRACE]  3/23/2012 1:02:24 PM.898[OBD2Engine]  SendCommand:010C
[TRACE]  3/23/2012 1:02:24 PM.913[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:25 PM.845[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:25 PM.858[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:25 PM.873[OBD2Engine]   ----> OBD2.Speed
[TRACE]  3/23/2012 1:02:25 PM.886[OBD2Engine]  SendCommand:010D
[TRACE]  3/23/2012 1:02:25 PM.911[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:26 PM.845[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:26 PM.852[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:26 PM.864[OBD2Engine]   ----> OBD2.MAF
[TRACE]  3/23/2012 1:02:26 PM.874[OBD2Engine]  SendCommand:0110
[TRACE]  3/23/2012 1:02:26 PM.883[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:27 PM.812[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:27 PM.819[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:27 PM.828[OBD2Engine]   ----> OBD2.RPM
[TRACE]  3/23/2012 1:02:27 PM.835[OBD2Engine]  SendCommand:010C
[TRACE]  3/23/2012 1:02:27 PM.847[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:28 PM.797[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:28 PM.805[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:28 PM.816[OBD2Engine]   ----> OBD2.IntakeAirTemp
[TRACE]  3/23/2012 1:02:28 PM.826[OBD2Engine]  SendCommand:010F
[TRACE]  3/23/2012 1:02:28 PM.836[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:29 PM.770[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:29 PM.779[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:29 PM.791[OBD2Engine]   ----> OBD2.AirTemp
[TRACE]  3/23/2012 1:02:29 PM.801[OBD2Engine]  SendCommand:0146
[TRACE]  3/23/2012 1:02:29 PM.812[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:30 PM.765[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:30 PM.772[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:30 PM.783[OBD2Engine]   ----> OBD2.Speed
[TRACE]  3/23/2012 1:02:30 PM.792[OBD2Engine]  SendCommand:010D
[TRACE]  3/23/2012 1:02:30 PM.804[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:31 PM.752[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:31 PM.763[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:31 PM.776[OBD2Engine]   ----> OBD2.MAF
[TRACE]  3/23/2012 1:02:31 PM.792[OBD2Engine]  SendCommand:0110
[TRACE]  3/23/2012 1:02:31 PM.801[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:32 PM.759[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:32 PM.767[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:32 PM.776[OBD2Engine]   ----> ELM.BatteryVoltage
[TRACE]  3/23/2012 1:02:32 PM.783[OBD2Engine]  SendCommand:ATRV
[TRACE]  3/23/2012 1:02:32 PM.796[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:32 PM.856[OBD2Engine]  HandleReply: 13.3V
[TRACE]  3/23/2012 1:02:32 PM.864[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:32 PM.873[OBD2Engine]   ----> OBD2.RPM
[TRACE]  3/23/2012 1:02:32 PM.882[OBD2Engine]  SendCommand:010C
[TRACE]  3/23/2012 1:02:32 PM.890[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:33 PM.834[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:33 PM.844[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:33 PM.855[OBD2Engine]   ----> OBD2.Speed
[TRACE]  3/23/2012 1:02:33 PM.863[OBD2Engine]  SendCommand:010D
[TRACE]  3/23/2012 1:02:33 PM.873[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:34 PM.816[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:34 PM.824[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:34 PM.832[OBD2Engine]   ----> OBD2.MAF
[TRACE]  3/23/2012 1:02:34 PM.842[OBD2Engine]  SendCommand:0110
[TRACE]  3/23/2012 1:02:34 PM.852[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:35 PM.790[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:35 PM.800[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:35 PM.810[OBD2Engine]   ----> OBD2.CoolantTemp
[TRACE]  3/23/2012 1:02:35 PM.818[OBD2Engine]  SendCommand:0105
[TRACE]  3/23/2012 1:02:35 PM.827[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:36 PM.787[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:36 PM.796[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:36 PM.805[OBD2Engine]   ----> OBD2.RPM
[TRACE]  3/23/2012 1:02:36 PM.817[OBD2Engine]  SendCommand:010C
[TRACE]  3/23/2012 1:02:36 PM.829[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:37 PM.753[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:37 PM.761[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:37 PM.773[OBD2Engine]   ----> OBD2.Speed
[TRACE]  3/23/2012 1:02:37 PM.783[OBD2Engine]  SendCommand:010D
[TRACE]  3/23/2012 1:02:37 PM.793[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:38 PM.748[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:38 PM.761[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:38 PM.770[OBD2Engine]   ----> OBD2.MAF
[TRACE]  3/23/2012 1:02:38 PM.778[OBD2Engine]  SendCommand:0110
[TRACE]  3/23/2012 1:02:38 PM.790[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:39 PM.752[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:39 PM.761[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:39 PM.771[OBD2Engine]   ----> ELM.BatteryVoltage
[TRACE]  3/23/2012 1:02:39 PM.785[OBD2Engine]  SendCommand:ATRV
[TRACE]  3/23/2012 1:02:39 PM.804[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:39 PM.865[OBD2Engine]  HandleReply: 13.3V
[TRACE]  3/23/2012 1:02:39 PM.876[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:39 PM.888[OBD2Engine]   ----> OBD2.RPM
[TRACE]  3/23/2012 1:02:39 PM.896[OBD2Engine]  SendCommand:010C
[TRACE]  3/23/2012 1:02:39 PM.906[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:40 PM.835[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:40 PM.948[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:40 PM.958[OBD2Engine]   ----> OBD2.IntakeAirTemp
[TRACE]  3/23/2012 1:02:40 PM.969[OBD2Engine]  SendCommand:010F
[TRACE]  3/23/2012 1:02:40 PM.982[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:41 PM.905[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:41 PM.915[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:41 PM.926[OBD2Engine]   ----> OBD2.AirTemp
[TRACE]  3/23/2012 1:02:41 PM.937[OBD2Engine]  SendCommand:0146
[TRACE]  3/23/2012 1:02:41 PM.950[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:43 PM.999[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:43 PM.010[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:43 PM.022[OBD2Engine]   ----> OBD2.Speed
[TRACE]  3/23/2012 1:02:43 PM.032[OBD2Engine]  SendCommand:010D
[TRACE]  3/23/2012 1:02:43 PM.045[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:43 PM.991[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:44 PM.002[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:44 PM.017[OBD2Engine]   ----> OBD2.MAF
[TRACE]  3/23/2012 1:02:44 PM.030[OBD2Engine]  SendCommand:0110
[TRACE]  3/23/2012 1:02:44 PM.044[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:44 PM.980[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:44 PM.992[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:45 PM.004[OBD2Engine]   ----> ELM.BatteryVoltage
[TRACE]  3/23/2012 1:02:45 PM.015[OBD2Engine]  SendCommand:ATRV
[TRACE]  3/23/2012 1:02:45 PM.041[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:45 PM.105[OBD2Engine]  HandleReply: 13.3V
[TRACE]  3/23/2012 1:02:45 PM.113[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:45 PM.121[OBD2Engine]   ----> OBD2.RPM
[TRACE]  3/23/2012 1:02:45 PM.128[OBD2Engine]  SendCommand:010C
[TRACE]  3/23/2012 1:02:45 PM.139[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:46 PM.126[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:46 PM.132[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:46 PM.141[OBD2Engine]   ----> OBD2.Speed
[TRACE]  3/23/2012 1:02:46 PM.153[OBD2Engine]  SendCommand:010D
[TRACE]  3/23/2012 1:02:46 PM.161[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:47 PM.108[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:47 PM.118[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:47 PM.128[OBD2Engine]   ----> OBD2.MAF
[TRACE]  3/23/2012 1:02:47 PM.137[OBD2Engine]  SendCommand:0110
[TRACE]  3/23/2012 1:02:47 PM.147[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:48 PM.092[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:48 PM.103[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:48 PM.481[OBD2Engine]   ----> OBD2.CoolantTemp
[TRACE]  3/23/2012 1:02:48 PM.492[OBD2Engine]  SendCommand:0105
[TRACE]  3/23/2012 1:02:48 PM.502[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:49 PM.450[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:49 PM.458[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:49 PM.469[OBD2Engine]   ----> OBD2.RPM
[TRACE]  3/23/2012 1:02:49 PM.477[OBD2Engine]  SendCommand:010C
[TRACE]  3/23/2012 1:02:49 PM.497[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:50 PM.425[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:50 PM.434[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:50 PM.444[OBD2Engine]   ----> OBD2.Speed
[TRACE]  3/23/2012 1:02:50 PM.450[OBD2Engine]  SendCommand:010D
[TRACE]  3/23/2012 1:02:50 PM.460[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:51 PM.396[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:51 PM.405[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:51 PM.413[OBD2Engine]   ----> OBD2.MAF
[TRACE]  3/23/2012 1:02:51 PM.423[OBD2Engine]  SendCommand:0110
[TRACE]  3/23/2012 1:02:51 PM.434[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:52 PM.370[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:52 PM.377[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:52 PM.389[OBD2Engine]   ----> ELM.BatteryVoltage
[TRACE]  3/23/2012 1:02:52 PM.398[OBD2Engine]  SendCommand:ATRV
[TRACE]  3/23/2012 1:02:52 PM.409[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:52 PM.510[OBD2Engine]  HandleReply: 13.2V
[TRACE]  3/23/2012 1:02:52 PM.518[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:52 PM.528[OBD2Engine]   ----> OBD2.RPM
[TRACE]  3/23/2012 1:02:52 PM.535[OBD2Engine]  SendCommand:010C
[TRACE]  3/23/2012 1:02:52 PM.547[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:53 PM.485[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:53 PM.492[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:53 PM.509[OBD2Engine]   ----> OBD2.IntakeAirTemp
[TRACE]  3/23/2012 1:02:53 PM.522[OBD2Engine]  SendCommand:010F
[TRACE]  3/23/2012 1:02:53 PM.529[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:54 PM.456[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:54 PM.465[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:54 PM.473[OBD2Engine]   ----> OBD2.AirTemp
[TRACE]  3/23/2012 1:02:54 PM.480[OBD2Engine]  SendCommand:0146
[TRACE]  3/23/2012 1:02:54 PM.488[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:55 PM.420[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:55 PM.427[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:55 PM.435[OBD2Engine]   ----> OBD2.Speed
[TRACE]  3/23/2012 1:02:55 PM.443[OBD2Engine]  SendCommand:010D
[TRACE]  3/23/2012 1:02:55 PM.453[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:56 PM.390[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:56 PM.397[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:56 PM.407[OBD2Engine]   ----> OBD2.MAF
[TRACE]  3/23/2012 1:02:56 PM.417[OBD2Engine]  SendCommand:0110
[TRACE]  3/23/2012 1:02:56 PM.425[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:57 PM.365[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:57 PM.374[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:57 PM.382[OBD2Engine]   ----> OBD2.RPM
[TRACE]  3/23/2012 1:02:57 PM.389[OBD2Engine]  SendCommand:010C
[TRACE]  3/23/2012 1:02:57 PM.400[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:58 PM.330[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:58 PM.340[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:58 PM.350[OBD2Engine]   ----> OBD2.Speed
[TRACE]  3/23/2012 1:02:58 PM.359[OBD2Engine]  SendCommand:010D
[TRACE]  3/23/2012 1:02:58 PM.368[OBD2Engine]   -> SENSOR_ACK
[TRACE]  3/23/2012 1:02:59 PM.300[OBD2Engine]  HandleReply: BUS INIT: ERROR
[TRACE]  3/23/2012 1:02:59 PM.310[OBD2Engine]   -> SENSOR
[TRACE]  3/23/2012 1:02:59 PM.319[OBD2Engine]   ----> OBD2.MAF
[TRACE]  3/23/2012 1:02:59 PM.327[OBD2Engine]  SendCommand:0110
[TRACE]  3/23/2012 1:02:59 PM.340[OBD2Engine]   -> SENSOR_ACK
[INFO ]  3/23/2012 1:03:00 PM.311[HOBD]  app exit
Or here:
http://www.mediafire.com/?1i3iirhtaw544ce
opel
Сообщение opel »
Also,it is not possible to connect?
From log it looks like your vehicle is not OBD2 compatible and just can't be read with ELM adapter.
Since however you say you can connect it via easyOBDII, probably there is some custom mode it which it can be read.
Have you had to do any custom settings in easyOBDII to connect? Probably it tells you the name of the protocol or similar?
natturaju
Сообщение natturaju »
Hi,
I have similar problem. I too get only the Battery Voltage displayed nothing else. I can confirm that I have OBD2 Compatible ECU. My vehicle make is Fiat Palio 1.2 NV - Petrol.
The program FiatECUScan works correctly with my Palio.
Thanks
Natarajan
natturaju,
FiatECUScan supports custom (non OBD2) fiat protocol. Hobdrive now have no this support included.
Think your vehicle is not fully OBD2 compliant, since otherwise it could be read by and standard "ELM-based" software. Have you tried anything else?
As a guess, try to choose "ELM Reset" in elm init template parameter in vehicle settings.
Also, vehicle settings contains init template for "Fiat" ECU. However I don't have information if it working or not.
