ิีBUG on shift position
Hi, I currently use it is much better hobdrive 1.2.7. Since version 1.2.8, but I find is to find bug display gear position is that it will show the gear does not match. That put ratio similar to that put in all respects 1.2.7 and 1.2.12 is the latest experimental results also show the same.
Re: ิีBUG on shift position
tongxray,
Gear position is for sure calculated value and may be wrong.
Are you sure your wheel radios is correct and gear coefficients are ok as well?
You may give us your settings here and tell at what speed and rpm you see wrong data.
