Disconnecting OBD
maxman
Disconnecting OBD
Сообщение maxman »
Hi,
i noticed, that hobdrive sometimes disconnected from BT dongle OBD2. I looking to log file, and found some errors. Can you check it an tell me what is wrong? Dont look at date and time, it is set wrong.
[INFO]  12/4/2012 9:17:22 AM.002[HOBD]  HOBD 1.1.55 Sun 11/11/2012  07:34 AM
[INFO]  12/4/2012 9:17:22 AM.359[HOBD]  Env: 3.5.7283.0
[INFO]  12/4/2012 9:17:23 AM.836[HOBD]  SN: *******************************
[INFO]  12/4/2012 9:17:25 AM.329[HOBD]  Vehicle: My Vehicle
[ERROR]  12/4/2012 9:17:26 AM.395[HOBD]  File Not Found in ecuxml://\SDMMC\hobd\user.ecuxml : Could not find file '\SDMMC\hobd\user.ecuxml'.
[INFO]  12/4/2012 9:17:27 AM.211[HOBD]  system width: 800, height: 480
[INFO]  12/4/2012 9:17:27 AM.226[HOBD]  wa width: 800, wa height: 480
[INFO]  12/4/2012 9:17:27 AM.721[HOBDAll]  hobDrive registered: hdman217300 - Pavel ÄŚech
[INFO]  12/4/2012 9:17:28 AM.287[HomePage]  System DPI: 96
[INFO]  12/4/2012 9:17:28 AM.300[HomePage]  App DPI: 57
[INFO]  12/4/2012 9:17:28 AM.315[HomePage]  layout: 475x285
[INFO]  12/4/2012 9:17:28 AM.331[HomePage]  form: 242x293
[INFO]  12/4/2012 9:17:37 AM.365[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 9:17:50 AM.569[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 9:17:54 AM.749[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 9:17:54 AM.884[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 9:18:02 AM.033[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 9:18:02 AM.630[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 9:18:42 AM.519[OBD2Engine]  VersionInfo: ELM327 v1.2a
[ERROR]  12/4/2012 9:18:49 AM.245[OBD2Engine]  Critical error:SEARCHING...
UNABLE TO CONNECT
[ERROR]  12/4/2012 9:19:01 AM.733[OBD2Engine]  Init Error
System.Threading.ThreadAbortException: ThreadAbortException
   at System.Net.Sockets.Socket.ConnectNoCheck(EndPoint remoteEP)
   at System.Net.Sockets.Socket.Connect(EndPoint remoteEP)
   at InTheHand.Net.Sockets.SocketBluetoothClient.Connect(BluetoothEndPoint remoteEP)
   at InTheHand.Net.Sockets.BluetoothClient.Connect(BluetoothEndPoint remoteEP)
   at hobd.BluetoothStream.Open(String url)
   at hobd.OBD2Engine.Run()
[INFO]  12/4/2012 9:28:32 AM.002[HOBD]  HOBD 1.1.55 Sun 11/11/2012  07:34 AM
[INFO]  12/4/2012 9:28:32 AM.353[HOBD]  Env: 3.5.7283.0
[INFO]  12/4/2012 9:28:33 AM.868[HOBD]  SN: 20E41800-0009-0000-0000-4E00610076002D00360031000000
[INFO]  12/4/2012 9:28:35 AM.411[HOBD]  Vehicle: My Vehicle
[ERROR]  12/4/2012 9:28:36 AM.510[HOBD]  File Not Found in ecuxml://\SDMMC\hobd\user.ecuxml : Could not find file '\SDMMC\hobd\user.ecuxml'.
[INFO]  12/4/2012 9:28:37 AM.366[HOBD]  system width: 800, height: 480
[INFO]  12/4/2012 9:28:37 AM.377[HOBD]  wa width: 800, wa height: 480
[INFO]  12/4/2012 9:28:37 AM.867[HOBDAll]  hobDrive registered: hdman217300 - Pavel ÄŚech
[INFO]  12/4/2012 9:28:38 AM.424[HomePage]  System DPI: 96
[INFO]  12/4/2012 9:28:38 AM.435[HomePage]  App DPI: 57
[INFO]  12/4/2012 9:28:38 AM.452[HomePage]  layout: 475x285
[INFO]  12/4/2012 9:28:38 AM.469[HomePage]  form: 242x293
[INFO]  12/4/2012 9:28:49 AM.418[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 9:28:37 AM.433[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 9:28:37 AM.657[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 9:28:44 AM.428[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 9:28:45 AM.061[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 9:30:52 AM.766[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 9:30:59 AM.515[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 9:31:00 AM.760[OBD2Engine]  ProtocolId: 4
[INFO]  12/4/2012 9:32:53 AM.682[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 9:33:02 AM.261[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 9:33:03 AM.701[OBD2Engine]  ProtocolId: 4
[INFO]  12/4/2012 9:33:51 AM.693[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 9:34:00 AM.223[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 9:34:01 AM.188[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 9:34:09 AM.150[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 9:34:09 AM.499[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 9:34:53 AM.671[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 9:35:02 AM.376[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 9:35:03 AM.835[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 9:39:21 AM.595[MILTrace]  dataraw: DA
[ERROR]  12/4/2012 9:39:22 AM.690[MILTrace]  dataraw: DA
[ERROR]  12/4/2012 9:44:25 AM.732[MILTrace]  dataraw: DA
[ERROR]  12/4/2012 9:44:26 AM.726[MILTrace]  dataraw: DA
[ERROR]  12/4/2012 9:45:25 AM.712[OBD2Engine]  Connection error threshold
[INFO]  12/4/2012 9:45:29 AM.864[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 9:45:38 AM.360[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 9:45:39 AM.778[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 9:47:31 AM.312[HomePage]  Invalid Action: default
[INFO]  12/4/2012 9:48:01 AM.678[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 9:48:11 AM.460[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 9:48:12 AM.904[OBD2Engine]  ProtocolId: 4
[INFO]  12/4/2012 9:48:56 AM.683[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 9:49:05 AM.353[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 9:49:06 AM.823[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 9:49:36 AM.840[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 9:49:37 AM.846[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 9:49:57 AM.661[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 9:50:06 AM.341[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 9:50:07 AM.806[OBD2Engine]  ProtocolId: 4
[INFO]  12/4/2012 9:52:00 AM.882[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 9:52:08 AM.962[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 9:52:10 AM.002[OBD2Engine]  ProtocolId: 4
[INFO]  12/4/2012 9:52:57 AM.711[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 9:53:06 AM.391[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 9:53:07 AM.927[OBD2Engine]  ProtocolId: 4
[INFO]  12/4/2012 9:53:59 AM.209[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 9:54:07 AM.930[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 9:54:09 AM.549[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 9:54:37 AM.924[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 9:54:39 AM.083[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 9:57:02 AM.207[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 9:57:09 AM.462[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 9:57:11 AM.152[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 9:59:41 AM.662[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 9:59:42 AM.831[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 10:03:07 AM.050[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 10:03:14 AM.359[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 10:03:15 AM.950[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 10:04:48 AM.558[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 10:04:49 AM.767[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 10:06:10 AM.743[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 10:06:18 AM.428[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 10:06:20 AM.113[OBD2Engine]  ProtocolId: 4
[INFO]  12/4/2012 10:08:13 AM.084[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 10:08:22 AM.378[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 10:08:24 AM.051[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 10:10:09 AM.217[MILTrace]  dataraw: 43 00 00 00 00 00 00
[INFO]  12/4/2012 10:10:14 AM.413[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 10:10:23 AM.308[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 10:10:24 AM.928[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 10:10:48 AM.268[MILTrace]  dataraw: 47 00 00 00 00 00 00
[ERROR]  12/4/2012 10:15:24 AM.956[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 10:15:50 AM.375[MILTrace]  dataraw: 47 00 00 00 00 00 00
[ERROR]  12/4/2012 10:20:30 AM.545[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 10:20:57 AM.443[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 10:23:28 AM.244[OBD2Engine]  VersionInfo: ELM327 v1.2a
[ERROR]  12/4/2012 10:23:38 AM.211[OBD2Engine]  Critical error:SEARCHING...
UNABLE TO CONNECT
[INFO]  12/4/2012 10:23:53 AM.243[OBD2Engine]  VersionInfo: ELM327 v1.2a
[ERROR]  12/4/2012 10:24:05 AM.670[OBD2Engine]  Critical error:SEARCHING...
UNABLE TO CONNECT
[INFO]  12/4/2012 10:24:21 AM.216[OBD2Engine]  VersionInfo: ELM327 v1.2a
[ERROR]  12/4/2012 10:24:31 AM.282[OBD2Engine]  Critical error:SEARCHING...
UNABLE TO CONNECT
[INFO]  12/4/2012 10:24:46 AM.108[OBD2Engine]  VersionInfo: ELM327 v1.2a
[ERROR]  12/4/2012 10:24:56 AM.266[OBD2Engine]  Critical error:SEARCHING...
UNABLE TO CONNECT
[INFO]  12/4/2012 10:25:11 AM.186[OBD2Engine]  VersionInfo: ELM327 v1.2a
[ERROR]  12/4/2012 10:25:19 AM.167[OBD2Engine]  Critical error:SEARCHING...
UNABLE TO CONNECT
[INFO]  12/4/2012 10:25:34 AM.167[OBD2Engine]  VersionInfo: ELM327 v1.2a
[ERROR]  12/4/2012 10:25:44 AM.324[OBD2Engine]  Critical error:SEARCHING...
UNABLE TO CONNECT
[INFO]  12/4/2012 11:50:30 AM.002[HOBD]  HOBD 1.1.55 Sun 11/11/2012  07:34 AM
[INFO]  12/4/2012 11:50:30 AM.449[HOBD]  Env: 3.5.7283.0
[INFO]  12/4/2012 11:50:31 AM.924[HOBD]  SN: 20E41800-0009-0000-0000-4E00610076002D00360031000000
[INFO]  12/4/2012 11:50:33 AM.446[HOBD]  Vehicle: My Vehicle
[ERROR]  12/4/2012 11:50:34 AM.548[HOBD]  File Not Found in ecuxml://\SDMMC\hobd\user.ecuxml : Could not find file '\SDMMC\hobd\user.ecuxml'.
[INFO]  12/4/2012 11:50:35 AM.413[HOBD]  system width: 800, height: 480
[INFO]  12/4/2012 11:50:35 AM.432[HOBD]  wa width: 800, wa height: 480
[INFO]  12/4/2012 11:50:35 AM.931[HOBDAll]  hobDrive registered: hdman217300 - Pavel ÄŚech
[INFO]  12/4/2012 11:50:36 AM.533[HomePage]  System DPI: 96
[INFO]  12/4/2012 11:50:36 AM.544[HomePage]  App DPI: 57
[INFO]  12/4/2012 11:50:36 AM.557[HomePage]  layout: 475x285
[INFO]  12/4/2012 11:50:36 AM.573[HomePage]  form: 242x293
[INFO]  12/4/2012 11:50:45 AM.752[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 11:50:58 AM.990[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 11:51:03 AM.469[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 11:51:03 AM.728[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 11:51:10 AM.453[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 11:51:11 AM.004[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 11:51:52 AM.465[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 11:51:58 AM.420[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 11:51:59 AM.032[OBD2Engine]  ProtocolId: 4
[INFO]  12/4/2012 11:52:49 AM.813[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 11:52:57 AM.593[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 11:52:58 AM.858[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 11:56:14 AM.908[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 11:56:15 AM.894[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 11:56:52 AM.898[OBD2Engine]  VersionInfo: ELM327 v1.2a
[ERROR]  12/4/2012 11:57:01 AM.844[OBD2Engine]  Critical error:SEARCHING...
UNABLE TO CONNECT
[INFO]  12/4/2012 11:57:16 AM.782[OBD2Engine]  VersionInfo: ELM327 v1.2a
[ERROR]  12/4/2012 11:57:26 AM.228[OBD2Engine]  Critical error:SEARCHING...
UNABLE TO CONNECT
[INFO]  12/4/2012 11:57:40 AM.019[OBD2Engine]  VersionInfo: ELM327 v1.2a
[ERROR]  12/4/2012 11:57:48 AM.895[OBD2Engine]  Critical error:SEARCHING...
UNABLE TO CONNECT
[INFO]  12/4/2012 11:58:01 AM.929[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 11:58:10 AM.178[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 11:58:11 AM.093[OBD2Engine]  ProtocolId: 4
[INFO]  12/4/2012 12:01:05 PM.853[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 12:01:14 PM.492[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 12:01:15 PM.961[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 12:01:28 PM.039[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 12:01:29 PM.236[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 12:06:11 PM.957[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 12:06:21 PM.237[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 12:06:22 PM.186[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 12:06:37 PM.670[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 12:06:38 PM.788[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 12:07:11 PM.015[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 12:07:19 PM.570[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 12:07:21 PM.227[OBD2Engine]  ProtocolId: 4
[INFO]  12/4/2012 12:08:10 PM.908[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 12:08:17 PM.568[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 12:08:19 PM.113[OBD2Engine]  ProtocolId: 4
[INFO]  12/4/2012 12:09:11 PM.419[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 12:09:20 PM.489[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 12:09:22 PM.059[OBD2Engine]  ProtocolId: 4
[INFO]  12/4/2012 12:10:12 PM.350[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 12:10:21 PM.470[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 12:10:23 PM.041[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 12:11:46 PM.194[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 12:11:47 PM.378[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 12:13:16 PM.028[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 12:13:23 PM.483[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 12:13:25 PM.049[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 12:16:55 PM.902[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 12:16:56 PM.971[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 12:17:22 PM.976[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 12:17:29 PM.406[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 12:17:31 PM.022[OBD2Engine]  ProtocolId: 4
[INFO]  12/4/2012 12:19:22 PM.815[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 12:19:28 PM.486[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 12:19:30 PM.096[OBD2Engine]  ProtocolId: 4
[INFO]  12/4/2012 12:20:18 PM.781[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 12:20:24 PM.566[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 12:20:26 PM.261[OBD2Engine]  ProtocolId: 4
[INFO]  12/4/2012 12:21:23 PM.347[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 12:21:32 PM.617[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 12:21:34 PM.327[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 12:22:27 PM.936[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 12:22:29 PM.042[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 12:25:30 PM.772[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 12:25:36 PM.557[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 12:25:38 PM.377[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 12:27:35 PM.463[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 12:27:36 PM.673[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 12:29:38 PM.929[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 12:29:46 PM.384[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 12:29:48 PM.100[OBD2Engine]  ProtocolId: 4
[INFO]  12/4/2012 12:30:35 PM.488[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 12:30:46 PM.568[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 12:30:48 PM.338[OBD2Engine]  ProtocolId: 4
[INFO]  12/4/2012 12:32:38 PM.287[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 12:32:47 PM.357[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 12:32:49 PM.067[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 12:33:09 PM.608[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 12:33:10 PM.813[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 12:35:46 PM.183[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 12:35:55 PM.407[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 12:35:57 PM.067[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 12:38:10 PM.933[MILTrace]  dataraw: DA
[ERROR]  12/4/2012 12:38:12 PM.046[MILTrace]  dataraw: DA
[INFO]  12/4/2012 1:08:38 PM.002[HOBD]  HOBD 1.1.55 Sun 11/11/2012  07:34 AM
[INFO]  12/4/2012 1:08:38 PM.377[HOBD]  Env: 3.5.7283.0
[INFO]  12/4/2012 1:08:39 PM.897[HOBD]  SN: 20E41800-0009-0000-0000-4E00610076002D00360031000000
[INFO]  12/4/2012 1:08:41 PM.493[HOBD]  Vehicle: My Vehicle
[ERROR]  12/4/2012 1:08:42 PM.586[HOBD]  File Not Found in ecuxml://\SDMMC\hobd\user.ecuxml : Could not find file '\SDMMC\hobd\user.ecuxml'.
[INFO]  12/4/2012 1:08:43 PM.420[HOBD]  system width: 800, height: 480
[INFO]  12/4/2012 1:08:43 PM.431[HOBD]  wa width: 800, wa height: 480
[INFO]  12/4/2012 1:08:43 PM.910[HOBDAll]  hobDrive registered: hdman217300 - Pavel ÄŚech
[INFO]  12/4/2012 1:08:44 PM.467[HomePage]  System DPI: 96
[INFO]  12/4/2012 1:08:44 PM.478[HomePage]  App DPI: 57
[INFO]  12/4/2012 1:08:44 PM.493[HomePage]  layout: 475x285
[INFO]  12/4/2012 1:08:44 PM.509[HomePage]  form: 242x293
[INFO]  12/4/2012 1:08:53 PM.720[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 1:09:06 PM.986[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 1:09:11 PM.091[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 1:09:11 PM.365[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 1:09:18 PM.566[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 1:09:19 PM.120[MILTrace]  dataraw: 47 00 00 00 00 00 00
[ERROR]  12/4/2012 1:09:30 PM.061[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 1:09:30 PM.643[MILTrace]  dataraw: 47 00 00 00 00 00 00
[ERROR]  12/4/2012 1:09:35 PM.941[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 1:09:36 PM.484[MILTrace]  dataraw: 47 00 00 00 00 00 00
[ERROR]  12/4/2012 1:09:55 PM.626[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 1:09:56 PM.033[MILTrace]  dataraw: 47 00 00 00 00 00 00
[ERROR]  12/4/2012 1:10:01 PM.089[MILTrace]  dataraw: DA
[ERROR]  12/4/2012 1:10:01 PM.616[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 1:15:02 PM.091[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 1:15:10 PM.258[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 1:15:11 PM.225[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 1:15:17 PM.087[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 1:15:17 PM.451[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 1:39:28 PM.002[HOBD]  HOBD 1.1.55 Sun 11/11/2012  07:34 AM
[INFO]  12/4/2012 1:39:28 PM.361[HOBD]  Env: 3.5.7283.0
[INFO]  12/4/2012 1:39:29 PM.879[HOBD]  SN: 20E41800-0009-0000-0000-4E00610076002D00360031000000
[INFO]  12/4/2012 1:39:31 PM.438[HOBD]  Vehicle: My Vehicle
[ERROR]  12/4/2012 1:39:32 PM.525[HOBD]  File Not Found in ecuxml://\SDMMC\hobd\user.ecuxml : Could not find file '\SDMMC\hobd\user.ecuxml'.
[INFO]  12/4/2012 1:39:33 PM.396[HOBD]  system width: 800, height: 480
[INFO]  12/4/2012 1:39:33 PM.409[HOBD]  wa width: 800, wa height: 480
[INFO]  12/4/2012 1:39:33 PM.912[HOBDAll]  hobDrive registered: hdman217300 - Pavel ÄŚech
[INFO]  12/4/2012 1:39:34 PM.503[HomePage]  System DPI: 96
[INFO]  12/4/2012 1:39:34 PM.515[HomePage]  App DPI: 57
[INFO]  12/4/2012 1:39:34 PM.528[HomePage]  layout: 475x285
[INFO]  12/4/2012 1:39:34 PM.546[HomePage]  form: 242x293
[INFO]  12/4/2012 1:39:42 PM.420[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 1:39:46 PM.470[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 1:39:46 PM.695[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 1:39:53 PM.840[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 1:39:54 PM.435[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 1:40:49 PM.170[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 1:40:55 PM.273[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 1:40:55 PM.835[OBD2Engine]  ProtocolId: 4
[INFO]  12/4/2012 1:42:49 PM.894[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 1:42:58 PM.099[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 1:42:59 PM.288[OBD2Engine]  ProtocolId: 4
[INFO]  12/4/2012 1:43:48 PM.827[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 1:43:57 PM.082[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 1:43:58 PM.072[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 1:44:57 PM.957[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 1:44:58 PM.958[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 1:45:51 PM.925[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 1:46:00 PM.155[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 1:46:01 PM.120[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 1:50:03 PM.357[MILTrace]  dataraw: DA
[ERROR]  12/4/2012 1:50:03 PM.710[MILTrace]  dataraw: DA
[INFO]  12/4/2012 1:50:07 PM.801[HOBD]  Vehicle: My Vehicle
[ERROR]  12/4/2012 1:50:08 PM.334[HOBD]  File Not Found in ecuxml://\SDMMC\hobd\user.ecuxml : Could not find file '\SDMMC\hobd\user.ecuxml'.
[INFO]  12/4/2012 1:50:13 PM.501[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 1:50:22 PM.422[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 1:50:23 PM.941[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 1:50:33 PM.344[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 1:50:34 PM.462[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 1:50:48 PM.613[HOBD]  Vehicle: My Vehicle
[ERROR]  12/4/2012 1:50:48 PM.970[HOBD]  File Not Found in ecuxml://\SDMMC\hobd\user.ecuxml : Could not find file '\SDMMC\hobd\user.ecuxml'.
[INFO]  12/4/2012 1:50:54 PM.144[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 1:51:02 PM.713[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 1:51:04 PM.057[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 1:51:17 PM.990[MILTrace]  dataraw: 43 00 00 00 00 00 00
[ERROR]  12/4/2012 1:51:18 PM.988[MILTrace]  dataraw: 47 00 00 00 00 00 00
[INFO]  12/4/2012 1:51:50 PM.821[OBD2Engine]  VersionInfo: ELM327 v1.2a
[INFO]  12/4/2012 1:51:58 PM.600[OBD2Engine]  Sensor Init:SEARCHING...
41 00 BE 3E B8 11
[INFO]  12/4/2012 1:52:00 PM.015[OBD2Engine]  ProtocolId: 4
[ERROR]  12/4/2012 1:52:12 PM.105[OBD2Engine]  Init Error
System.Net.Sockets.SocketException: A connect request was made on an already connected socket
Последний раз редактировалось maxman 16 дек 2012, 22:59, всего редактировалось 1 раз.
Re: Disconnecting OBD
maxman, If you can reproduce this stable, its better to set log level to TRACE to get better picture.
From that I see that adapter sometimes stop responding. That could be OBD adapter issue (I see its version 1.2 which is quite old).
maxman
Сообщение maxman »
Hi cail,
i set log level to TRACE and this is result (attachment)
hobd_log.rar
Trace log
(9.91 КБ) 1041 скачивание
I see ECU stops responding to sensors at some moment. That could be ELM bug, or ECU issue.
I see you instantly fetch Lambda and Lambdab1s1 sensors - but ECU reports them as unavailable. Try removing these from screens - they could interfere somehow and make ELM adapter mad.
maxman
Сообщение maxman »
Hi cail,
i removed Lambda from screens and now no errors in log.
Thank you for helping me.
