Calibration for LPG
Добавлено: 22 янв 2013, 19:30
ikayaoglu
Hi Cail,
I use a Sequential injection LPG System for my car.
LPG System is working like that:
When
Coolant Temp < 47 C LPG is OFF, Petrol is ON
Coolant Temp => 47 C LPG is ON, Petrol is OFF
I set my Warm Engine Temprature:47
With this
"Fuel in Cold" means "Fuel Consumed on Petrol"
"Fuel in Warm" means "Fuel Consumed on LPG"
First question:
I want to see a value like "c/w ratio" (Fuel in Cold/Fuel in Warm) on Hobdrive Screen. if it is possible this value gives me "Petrol/LPG consumed fuel ratio"
Second question:
I want to calibrate my "Tank Level" value to "LPG Tank Level "
I want
Tank Level's calculating ON when Coolant Temp => 47
Tank Level's calculating OFF when Coolant Temp < 47
In other words, can we make Tank Level's calculation with "Fuel economy_WarmEngine" parameter and can i see the different name on Hobdrive screen like "LPG Tank Level" ?
Last question:
If these are possible, i want to enter 2 values on "Fuel Price Setup Menu".
Petrol Cost
LPG Cost
So new "Fuel Cost" or can be rename "LPG Fuel Cost"= Fuel Consumed in Warm(LPG) x LPG Cost + Fuel Consumed in Cold(Petrol) x Petrol Cost" can be calculating like this.
If all this is possible, may be i can see LPG values in the different section like Hobdrive's new "Hybrid" section.
I modified "GPS" section to "LPG" . May be i can add new LPG parameters here :)
Thanks for answering.
PS SORRY FOR MY ENGLISH :oops:
Re: Calibration for LPG
Добавлено: 24 янв 2013, 08:12
Hello.
Exactly right now we have a talk in russian part of the forum, discussing features for LPG (and other two-tank systems) support.
You may try to read (via automatic translator) it to know current status
viewtopic.php?f=12&t=144
The outcome is the feature considered important but not simple, we'll form the requirements and try to introduce the functionality in future versions.
