beta 1182 will not unload when exit the program
yillw
Сообщение yillw »
Hi Cail,
There seems to be a problem for beta11.82, when exited the problem, hobdrive won't unload itself.
The process remains in the memory. Kindly confirm if this is the case.
Thanks in advance
Wilson
PS thanks for the time12 attribute for core.datetime. There is a bug in the transition form am to pm and from pm to am. It will not switch between am and pm unless one close hobdrive and restart it again.
Re: beta 1182 will not unload when exit the program
yillw, will check the am/pm switch, thanks.
As for hangup in memory - thats a known issue with some wince systems. working on it.
siamon
Сообщение siamon »
Hi,
you may try toyota ECU in settings - but from what I read thats a european brand with toyota label, so most probably you only have to use standard default setup. Just configure fuel economy scaling if it seems to be wrong by default.
Its hard to understand the issue, please make a screenshot or video...
