Back to documentation index
Automatically Launch hobDrive on CarPlay Connection Using iOS Shortcuts
This guide will help you set up automatic launching of the hobDrive app when you connect your iPhone to CarPlay using the Apple Shortcuts app.
Table of Contents
Overview
The iOS Shortcuts app allows you to create automation that triggers when specific events occur on your device. By setting up a CarPlay connection automation, you can ensure that hobDrive automatically starts whenever you connect to your car’s CarPlay system, making your driving experience seamless and convenient.
Important Notes About iOS Behavior
These limitations are part of iOS security and privacy features. For the best experience, ensure your phone is unlocked when connecting to CarPlay.
Requirements
Setting Up the Automation
Follow these step-by-step instructions to create the automation:
Step 1: Open the Shortcuts App
Locate and tap the Shortcuts app on your iPhone home screen. The icon looks like two overlapping squares with rounded corners.
If you can’t find the Shortcuts app, you can download it from the App Store (it’s free and made by Apple).
Step 2: Navigate to Automation
  1. Tap on the Automation tab at the bottom of the screen
  2. If this is your first automation, you’ll see a screen explaining what automations can do
  3. Tap the Create Personal Automation button (or the + button if you already have other automations)
Step 3: Select CarPlay Trigger
Scroll through the list of automation triggers and select CarPlay.
This trigger will activate whenever your iPhone connects to or disconnects from a CarPlay system.
Step 4: Configure When to Run
You’ll see two options:
Select When Connecting by tapping it. A checkmark will appear next to your selection.
Tap Next in the top right corner to continue.
Step 5: Add the Open App Action
Now you need to tell the automation what to do when CarPlay connects.
  1. Tap Add Action or use the search field
  2. In the search field, type “Open App”
  3. Select the Open App action from the results
Step 6: Select hobDrive App
  1. Tap on the word App in the action block (it will appear as a blue link)
  2. Scroll through your installed apps or use the search field to find hobDrive
  3. Tap hobDrive to select it
The action block should now read “Open hobDrive”.
Step 7: Disable Ask Before Running
By default, iOS will ask for your confirmation before running the automation. To make it truly automatic:
  1. Tap Next in the top right corner
  2. You’ll see a summary screen with a toggle for Ask Before Running
  3. Turn OFF the “Ask Before Running” toggle
A dialog will appear warning you that the automation will run without your confirmation. Tap Don’t Ask to confirm.
Step 8: Complete the Setup
Tap Done in the top right corner to save your automation.
Your automation is now active and will automatically launch hobDrive whenever you connect to CarPlay!
Testing the Automation
To verify that your automation works correctly:
  1. Make sure the hobDrive app is installed and configured
  2. If already connected to CarPlay, disconnect your iPhone
  3. Close the hobDrive app if it’s currently running
  4. Connect your iPhone to CarPlay
  5. The hobDrive app should automatically launch within a few seconds
Troubleshooting
The automation doesn’t run
hobDrive doesn’t open
The automation asks for confirmation
Additional Tips
Adding a Delay
If you experience issues with the app launching too quickly (before CarPlay is fully connected), you can add a short delay:
  1. Edit your automation
  2. Before the “Open App” action, tap the + button
  3. Search for and add a “Wait” action
  4. Set the wait time to 2-5 seconds
  5. The automation will now wait before opening hobDrive
Multiple Actions
You can add more actions to your automation, such as:
Simply tap the + button between actions and search for what you want to add.
Editing or Deleting the Automation
To modify or remove the automation:
  1. Open the Shortcuts app
  2. Go to the Automation tab
  3. Tap on your CarPlay automation
  4. To edit: Make your changes and tap Done
  5. To delete: Scroll down and tap Delete Automation
Conclusion
Setting up this automation makes using hobDrive with CarPlay effortless. Once configured, you’ll never need to manually launch the app when connecting to your car—it will be ready and waiting for you automatically.
For additional help with hobDrive features and settings, please refer to the User Guide or contact support@hobdrive.com.
