Back to documentation index
Dynamic Expressions: Core Syntax
The expression evaluator is based on an Excel-like implementation. It can parse mathematical expressions with support for the most commonly used functions.
Examples:
4*(24/2-5)+14
cos(Pi/4)*sin(Pi/6)^2
1-1/E^(0.5^2)
min(5;2;9;10;42;35)
Data Types
Five data types are supported:
Type Description
double Floating-point number (default for all calculations)
int Integer. Use the int() function to convert explicitly
hexadecimal Hexadecimal number. Converted to double in calculations
string Text string
boolean Logical value (true / false)
Note: Integers and hexadecimals are always converted to double when used in calculations. Use int() to convert to integer explicitly.
Built-in Constants
Constant Description
Pi The number π ≈ 3.14159…
E Euler’s number e ≈ 2.71828…
Function Reference
Math Functions
Function Description Example
Abs(x) Absolute value Abs(-5) → 5
Acos(x) Arc cosine (inverse cosine) Acos(0) → 1.5708
Asin(x) Arc sine (inverse sine) Asin(1) → 1.5708
Atan(x) Arc tangent (inverse tangent) Atan(1) → 0.7854
Atan2(y;x) Arc tangent of y/x, using signs to determine quadrant Atan2(1;1) → 0.7854
Ceiling(x) Rounds up to the nearest integer Ceiling(4.1) → 5
Cos(x) Cosine Cos(0) → 1
Cosh(x) Hyperbolic cosine Cosh(0) → 1
Exp(x) e raised to the power x Exp(1) → 2.7183
Fact(x) Factorial Fact(5) → 120
Floor(x) Rounds down to the nearest integer Floor(4.9) → 4
Ln(x) Natural logarithm (base e) Ln(E) → 1
Log(x) Common logarithm (base 10) Log(100) → 2
Pow(x;y) x raised to the power y Pow(2;10) → 1024
Round(x) Rounds to the nearest integer Round(4.5) → 5
Sign(x) Returns the sign: −1, 0, or 1 Sign(-42) → -1
Sin(x) Sine Sin(Pi/2) → 1
Sinh(x) Hyperbolic sine Sinh(1) → 1.1752
Sqr(x) Square (x²) Sqr(5) → 25
Sqrt(x) Square root Sqrt(25) → 5
Trunc(x) Truncates to integer (removes decimal part) Trunc(4.9) → 4
Aggregate / Statistics Functions
Avg(…) Average of values Avg(2;4;6) → 4
Max(…) Maximum value Max(5;2;9) → 9
Min(…) Minimum value Min(5;2;9) → 2
StDev(…) Standard deviation StDev(2;4;6)
Var(…) Variance Var(2;4;6)
Logic Functions
And(a;b) Logical AND And(true;false) → false
Or(a;b) Logical OR Or(true;false) → true
Not(x) Logical NOT Not(true) → false
If(cond;then;else) Conditional: returns then if cond is true, otherwise else If(5>6;"yes";"no") → "no"
String Functions
Format(x;fmt) Formats a value using a format string Format(Pi;"0.00") → "3.14"
Hex(x) Converts a number to hexadecimal string Hex(255) → "FF"
Left(s;n) Returns the first n characters Left("hello";3) → "hel"
Right(s;n) Returns the last n characters Right("hello";3) → "llo"
Mid(s;start;n) Returns n characters starting at start Mid("hello";2;3) → "ell"
Len(s) Returns the length of a string Len("hello") → 5
Lower(s) Converts to lowercase Lower("HELLO") → "hello"
Upper(s) Converts to uppercase Upper("hello") → "HELLO"
Val(s) Converts a string to a number Val("42") → 42
Utility Functions
About Displays version information
Clear Clears all user-defined variables and functions
Help Displays help information
String Operations
The & operator concatenates strings:
"Hello " & "world"          // → "Hello world"
"Pi = " & Pi                // → "Pi = 3.14159265358979"
Len("hello world")          // → 11
Boolean Operators and Conditionals
true != false               // → true
5 > 6 ? "hello" : "world"  // → "world"
If(5 > 6;"hello";"world")  // → "world"
Variable and Function Declaration
Use := to declare variables and functions:
x := 42
f(x) := x^2
f(x) := sin(x) / cos(x)    // declare dynamic functions using built-in functions
Recursion and Scope
Functions can call themselves recursively. Variables declared as function parameters are local to that function; other variables are resolved from the global scope.
fac(n) := (n = 0) ? 1 : fac(n-1)*n
// fac calls itself with different parameters
f(x) := x * Y
// x is in function scope, Y is in global scope
Operator Precedence
From highest to lowest priority:
Priority Operator Description
1 ( ), f(x) Grouping, function calls
2 ! ~ - + Unary operators
3 ^ Exponentiation (Excel rule: a^b^c → (a^b)^c)
4 * / % Multiplication, division, modulo
5 + - Addition, subtraction
6 & String concatenation
7 < <= > >= Comparison operators
8 = != <> Equality and inequality
9 && Logical AND
10 \|\| Logical OR
11 ?: Ternary conditional
12 := Assignment
