Back to documentation index
ECUXML Format Specification
ECUXML is an XML-based format used by HOBDrive to define vehicle ECU (Electronic Control Unit) sensor parameters. Each .ecuxml file describes a set of OBD2/KWP2000 diagnostic parameters — how to request data from a vehicle’s ECU, how to parse the raw response bytes, and how to present the resulting values to the user.
ECUXML files are compiled into C# sensor provider classes at build time by the ecuxml2cs tool, or loaded dynamically at runtime from external files.
Table of Contents
File Structure
Root Element: <parameters>
Every ECUXML file has a single root element <parameters>:
<parameters namespace="MyECU"
            description="My ECU description"
            description-ru="Описание ЭБУ"
            standard-header="7E1">
  <!-- global elements and parameter definitions -->
</parameters>
Root Attributes
Attribute Required Description
namespace No Sensor namespace prefix. All parameter IDs within this file will be prefixed with Namespace. unless the ID already contains a dot. Defaults to "Default".
description No Short English description of this ECU profile. Shown in profile selection UI.
description-ru No Short Russian description.
standard-header No Default ELM327 header (ATSH) applied to all OBD2 sensors in this file, unless overridden per-parameter.
Global Elements
These child elements of <parameters> configure the ECU profile as a whole. They must appear before <parameter> elements.
<include>
Includes another ECUXML file. The included file’s parameters are loaded into the same sensor registry. Paths are relative to the current file.
<include>../kwp2000.ecuxml</include>
<include>IM-FAN.ecuxml</include>
Multiple <include> elements are allowed.
Default ELM327 header string. Applied to all OBD2 sensors unless overridden. This is an alternative to the standard-header attribute on the root element.
<header>7E1</header>
Can also contain extended AT commands separated by semicolons:
<header>ATSH773; ATCRA774; ATFCSH773; 1092;</header>
<obd2-header>
Optional OBD2 default header. When present, this value is appended to the ELM327 initialization string. It is also used to restore the header back to default after a sensor with a custom header has been read.
<obd2-header>7E0</obd2-header>
Or with extended commands:
<obd2-header>ATSH7E0; ATCRA7E8; ATFCSH7E0;</obd2-header>
<init-string>
ELM327 initialization commands, separated by semicolons. Sent to the adapter when this ECU profile is activated.
<init-string>
  ATSP6; ATAL; ATSH7E0; ATST32;
</init-string>
<disable-obd2>
Controls whether standard OBD2 sensors are loaded alongside this file’s custom sensors.
<disable-obd2>false</disable-obd2>
When disabled, only the sensors defined in this ECUXML file (and its includes) are available.
<models>
Comma or newline-separated list of vehicle manufacturer names. Used for grouping in the ECU selection UI.
<models>
  Mitsubishi
</models>
<models>Peugeot, Citroen</models>
<description lang="...">
Detailed description of the ECU profile, shown in the UI. The lang attribute specifies the language ("en" or "ru").
<description lang="en">
  Extra OBD2 sensors for turbocharger diagnostics.
</description>
<description lang="ru">
  Дополнительные датчики OBD2 для диагностики турбокомпрессора.
</description>
Parameter Element: <parameter>
Each <parameter> defines a single sensor. The id attribute is required and serves as the sensor’s identifier within its namespace.
<parameter id="CoolantTemp" display="PID05">
  <!-- child elements defining the sensor -->
</parameter>
Parameter Attributes
Attribute Description
id Required. Unique sensor identifier. The final sensor ID becomes Namespace.id unless the id already contains a dot.
display Optional display alias. Used by some ECU profiles as an alternative reference code (e.g., Renault PR003, Toyota PID1).
Sensor Types
The type of sensor created depends on which child elements are present within <parameter>. The parser checks for these in a specific priority order:
1. Direct OBD2 Sensor
A sensor that directly queries the ECU with a command (mode+PID or raw command) and parses the response bytes.
Created when: No <base>, <base-raw>, <base-data>, <class>, or <text> element is present.
<parameter id="CoolantTemp">
  <mode>1</mode>
  <command>05</command>
  <valuea>1</valuea>
  <offset>-40</offset>
  <description>
    <name>Coolant Temperature</name>
    <unit>celsius</unit>
  </description>
</parameter>
Or using <address> shorthand (OBD2 Mode 1):
<parameter id="Lambda11" display="LAMBDA11">
  <address><byte>0x34</byte></address>
  <valueab>0.0000305</valueab>
</parameter>
Or using a raw command string:
<parameter id="Core03">
  <raw>2103</raw>
  <valuea>0</valuea>
</parameter>
2. Derived Sensor
A sensor whose value is computed from one or two other sensors.
Created when: <base> is present and <average> is not.
<parameter id="TC_CINP">
  <base>IntakeManifoldPressure</base>
  <valuea>0.01</valuea>
  <offset>0</offset>
  <description>
    <name>TC Pressure</name>
    <unit>bar</unit>
  </description>
</parameter>
With two base sensors and an eval expression:
<parameter id="CombinedValue">
  <base>SensorA</base>
  <base2>SensorB</base2>
  <eval>Sensor_Value * 2 + Sensor2_Value</eval>
</parameter>
Variables available in <eval> for derived sensors:
3. Base-Raw Derived Sensor
A sensor that reads raw response bytes (including all headers) from another OBD2 sensor and extracts a value at a specific byte offset.
Created when: <base-raw> is present and <text> / <dump> are not.
<parameter id="CVTdegr">
  <base-raw>Core10</base-raw>
  <word-31>1</word-31>
  <offset>0</offset>
</parameter>
The getraw() family of methods is used — offsets are absolute positions in the raw byte array (including any protocol headers).
Variables available in <eval> for base-raw sensors:
4. Base-Data Derived Sensor
A sensor that reads data bytes from another OBD2 sensor, skipping the standard protocol headers.
Created when: <base-data> is present (and <base> / <base-raw> are not).
<parameter id="TireSensor1">
  <base-data>Core_21A8</base-data>
  <eval>get(15)*0.2</eval>
  <description>
    <unit>psi</unit>
  </description>
</parameter>
The get() family of methods is used — offsets are relative to the start of the data payload (after mode+command bytes).
Variables available in <eval> for base-data sensors:
5. Text Sensor
A sensor that returns a text string from the ECU response rather than a numeric value (e.g., VIN code, ECU name).
Created when: <text> element is present.
As a direct OBD2 text sensor:
<parameter id="VIN">
  <mode>9</mode>
  <command>2</command>
  <text/>
</parameter>
As a derived text sensor from raw data:
<parameter id="ECUID_ECUIDT">
  <raw>1A80</raw>
  <text/>
</parameter>
As a derived text sensor from another sensor’s raw data with eval:
<parameter id="StatusText">
  <base-data>CoreSensor</base-data>
  <text/>
  <eval>... expression returning a string ...</eval>
</parameter>
<text> Attributes
offset Byte offset within the response to start reading text.
length Maximum number of bytes to read.
6. Dump Sensor
Similar to text sensor but produces a hex dump of raw bytes. Useful for diagnostic display of raw data.
Created when: <dump> element is present with a <base-data> source.
<parameter id="ID_TireSensor_1">
  <base-data>TireSensorID</base-data>
  <dump offset="1" length="4"/>
</parameter>
<dump> Attributes
offset Byte offset within the data to start dumping.
length Number of bytes to dump.
7. Average Sensor
A sensor that computes a running average of another sensor’s values over a specified number of readings.
Created when: <average> element is present along with <base>.
<parameter id="Avg_ECUFuelLevel">
  <base>ECUFuelInTank</base>
  <average length="15"/>
  <description>
    <unit>liters</unit>
  </description>
</parameter>
<average> Attributes
length Number of values to average over (integration window size).
8. Class-Based Sensor
A sensor implemented by a named C# class rather than ECUXML value extraction logic.
Created when: <class> element is present.
<parameter id="MIL">
  <class>KWPMILSensor</class>
</parameter>
<parameter id="ClearDTC">
  <class>hobd.ClearDTCSensor</class>
</parameter>
The class must be registered in the sensor registry and inherit from CoreSensor.
Value Extraction
Command Specification
There are three ways to specify what command to send to the ECU:
Mode + Command (Standard OBD2)
<mode>1</mode>        <!-- OBD2 Mode, in hex (e.g., 1 = live data) -->
<command>0C</command>  <!-- OBD2 PID, in hex -->
Default mode is 1 if not specified.
Address shorthand
Equivalent to specifying mode 1 + the given PID:
Raw command
A raw hex string sent to the ELM327. Semicolons in the string are converted to carriage returns (multiple commands). This overrides mode+command.
<raw>2103</raw>
<raw>14FF00</raw>
<raw>1A80</raw>
<header>
Per-parameter header override. Changes the ELM327 header (ATSH) for this sensor’s requests, overriding both standard-header and the global <header>.
<parameter id="SpecialSensor">
  <raw>2201</raw>
  <valuea>1</valuea>
</parameter>
<data-offset>
Overrides the default command length for response parsing. Normally, the parser skips CommandLength bytes (default: 2, for Mode+Command) after finding the reply marker. This element changes that skip size.
<data-offset>2</data-offset>  <!-- skip 2 bytes after reply marker -->
<data-offset>3</data-offset>  <!-- skip 3 bytes (e.g., for 3-byte request commands) -->
Single-Byte Values
Extract a single byte from the response data and multiply by the scale factor.
Element Reply Offset Description
<value> or <valuea> 0 First data byte (byte A)
<valueb> 1 Second data byte (byte B)
<valuec> 2 Third data byte (byte C)
<valued> 3 Fourth data byte (byte D)
<value-N> N Byte at offset N
The element content is the scale factor (multiplier):
<valuea>0.392157</valuea>   <!-- result = byte_A * 0.392157 -->
<valueb>1</valueb>           <!-- result = byte_B * 1 -->
<value-6>1</value-6>         <!-- result = byte_at_offset_6 * 1 -->
Word Values (16-bit)
Extract a 16-bit big-endian word (two consecutive bytes) and multiply by scale.
<valueab> 0 Word from bytes A,B (offset 0,1)
<valuebc> 1 Word from bytes B,C (offset 1,2)
<valuecd> 2 Word from bytes C,D (offset 2,3)
<word-N> N Word starting at offset N
<valueab>0.0000305</valueab>  <!-- result = word(A,B) * 0.0000305 -->
<word-31>1</word-31>           <!-- result = word at offset 31 -->
DWord Values (32-bit)
Extract a 32-bit big-endian double word (four consecutive bytes) and multiply by scale.
<dword-N> N DWord starting at offset N
<dword-0>0.001</dword-0>  <!-- result = dword at offset 0 * 0.001 -->
Little-Endian Variants
For ECUs that transmit data in little-endian byte order:
Element Description
<wordle-N> 16-bit little-endian word at offset N
<dwordle-N> 32-bit little-endian double word at offset N
<wordle-8>0.0018252</wordle-8>  <!-- LE word at offset 8 -->
Value Transformation Pipeline
After extracting the raw numeric value, the following transformations are applied in order:
1. Signed conversion (<signed/>)
If present, the extracted value is reinterpreted as a signed integer:
<signed/>
2. Scale and Offset
result = raw_value * scale + offset
Where scale comes from the value element content and offset from the <offset> element.
<valuea>1</valuea>
<offset>-40</offset>   <!-- e.g., Coolant Temp: byte_A * 1 + (-40) -->
3. Bit extraction (<bit> and <bit-width>)
If <bit> is specified, the result is right-shifted by the given number of bits, then masked to extract <bit-width> bits (default: 1).
<bit>10</bit>          <!-- extract bit 10 -->
<bit-width>3</bit-width> <!-- extract 3 bits -->
Formula: result = (int(scaled_value) >> bit) & ((1 << bit_width) - 1)
This is commonly used to extract boolean flags or small fields from status bytes:
<parameter id="FuelSystemStatus_Trim">
  <base>FuelSystemStatus</base>
  <value>1</value>
  <bit>10</bit>
</parameter>
4. Cut filters (<cut-low> and <cut-high>)
Clamp invalid/noisy values to zero:
<cut-low>500</cut-low>    <!-- values below 500 become 0 -->
<cut-high>220</cut-high>   <!-- values above 220 become 0 -->
Useful for filtering ECU bugs (e.g., phantom RPM readings when engine is off):
<parameter id="RPM">
  <base>RPM</base>
  <value>1</value>
</parameter>
MIL Group (<mil-group>)
For MIL (Malfunction Indicator Lamp) sensors, specifies which group of diagnostic trouble codes this sensor belongs to:
<mil-group>TPMS_Suzuki</mil-group>
<mil-group>HyundaiSRS</mil-group>
Dynamic Expressions (<eval>)
The <eval> element contains a dynamic expression that computes the sensor value. When present, it overrides the standard value extraction (scale/offset) pipeline.
<eval>get(13)*0.2</eval>
<eval>(0.000000002344*(get(13)^5))+(-0.000001387*(get(13)^4))+(0.0003193*(get(13)^3))+(-0.03501*(get(13)^2))+(2.302*get(13))+(-36.6)</eval>
<eval>get(6)*65536+get(7)*256+get(8)</eval>
Expression Syntax
The expression evaluator is based on an Excel-like formula engine. It supports:
Operator Precedence (highest to lowest)
Priority Operators Description
1 ( ), f(x) Grouping, function calls
2 !, ~, -, + Unary operators
3 ^ Power (left-associative: a^b^c = (a^b)^c)
4 *, /, % Multiplication, division, modulo
5 +, - Addition, subtraction
6 & String concatenation
7 <, <=, >, >= Comparison
8 =, !=, <> Equality
9 && Logical AND
10 \|\| Logical OR
11 ?: Ternary conditional
12 := Assignment
Data Types
Five data types are supported: double, int, hexadecimal, string, and boolean.
Integers and hexadecimals are automatically converted to double in calculations. Use int() to convert explicitly.
Built-in Functions
The expression engine supports these standard functions:
Abs, Acos, And, Asin, Atan, Atan2, Avg, Ceiling, Cos, Cosh, Exp, Fact, Floor, Format, Hex, If, Left, Len, Ln, Log, Lower, Max, Min, Mid, Not, Or, Pow, Right, Round, Sign, Sin, Sinh, Sqr, Sqrt, StDev, Trunc, Upper, Val, Var
If(condition; true_value; false_value)
Conditional function. Equivalent to condition ? true_value : false_value.
Note: function arguments are separated by semicolons (;), not commas.
ECUXML-Specific Functions
These functions are available only within <eval> expressions in ECUXML parameter definitions. They operate on the current sensor’s raw data buffer.
get(offset)
Returns a single byte from the sensor’s data buffer at the given offset. The offset is relative to the start of the data payload (after skipping the reply marker and command bytes).
<eval>get(0)</eval>          <!-- first data byte -->
<eval>get(13)*0.2</eval>     <!-- byte at offset 13, scaled -->
get_word(offset)
Returns a 16-bit big-endian word (two bytes) starting at the given offset.
<eval>get_word(8)*0.1</eval>
<eval>get_word(2)*0.005+2.1</eval>
get_dword(offset)
Returns a 32-bit big-endian double word (four bytes) starting at the given offset.
<eval>get_dword(0)*0.001</eval>
get_wordle(offset)
Returns a 16-bit little-endian word starting at the given offset.
<eval>get_wordle(0)*0.3144</eval>
get_dwordle(offset)
Returns a 32-bit little-endian double word starting at the given offset.
<eval>get_dwordle(0)</eval>
to_signed_byte(value) / to_signed(value)
Converts a byte value (0–255) to a signed byte (-128 to 127).
<eval>to_signed_byte(get(5))*0.5</eval>
to_signed_word(value)
Converts a 16-bit unsigned value to a signed 16-bit integer (-32768 to 32767).
<eval>to_signed_word(get_word(0))*0.1</eval>
to_signed_dword(value)
Converts a 32-bit unsigned value to a signed 32-bit integer.
Eval context variables
Depending on the sensor type, different variables are available in eval expressions:
Sensor Type Available Variables
Direct OBD2 (<raw> or <mode>/<command>) Sensor — the OBD2 sensor object (use get(), get_word(), etc.)
Derived (<base>) Sensor_Value — double value of the base sensor; Sensor2_Value — value of <base2> sensor
Base-raw (<base-raw>) Sensor — the base OBD2 sensor object
Base-data (<base-data>) Sensor — the base OBD2 sensor object
Description and Localization
Each parameter can have one or more <description> blocks for localization.
<parameter id="CVTTemp">
  <description>
    <name>CVT Temperature</name>
    <description>CVT oil temperature</description>
    <display>CVTTEMP</display>
  </description>
    <name>Темп. CVT</name>
    <description>Температура масла вариатора</description>
  </description>
</parameter>
<description> Attributes
lang Language code ("en", "ru", etc.). If omitted, defaults to "" (default/English).
<description> Child Elements
Element Description
<name> Human-readable sensor name. Shown in the UI.
<description> Longer description / tooltip text.
<unit> Measurement unit string (e.g., celsius, bar, psi, km, volts, liters, rpm, cm). HOBDrive uses this for unit conversion.
<display> Display format override.
Complete Examples
Example 1: Simple OBD2 Sensor with Mode/Command
Standard OBD2 coolant temperature (PID 0x05):
  <address><byte>0x05</byte></address>
  <valuea>1</valuea>
  <description>
  </description>
</parameter>
Value formula: byte_A * 1 + (-40) → temperature in °C.
Example 2: Derived Sensor with Cut Filter
Filtering noisy RPM values:
  <base>RPM</base>
  <value>1</value>
</parameter>
Takes the existing RPM sensor value, passes it through (scale=1), but returns 0 if below 500.
Example 3: Base-Data with Eval Expression
TPMS pressure from a multi-byte response:
  <description>
    <unit>psi</unit>
  </description>
</parameter>
Reads byte at offset 15 from Core_21A8’s data payload, multiplies by 0.2.
Example 4: Polynomial Eval Expression
CVT oil temperature conversion from a lookup-like polynomial:
  </description>
  <base-data>Core03</base-data>
</parameter>
Example 5: Raw Command with Text Response
Reading the Vehicle Identification Number:
  <description>
    <name>VIN Code</name>
    <description>Vehicle's VIN code</description>
  </description>
  <mode>9</mode>
  <text/>
</parameter>
Example 6: Hex Dump Sensor
Displaying raw tire sensor IDs:
</parameter>
Example 7: KWP2000 Raw Command with Text
  <raw>1A90</raw>
  <text/>
</parameter>
Example 8: Signed Word Value with Little-Endian
<parameter id="SteeringAngle">
  <signed/>
</parameter>
Example 9: Class-Based MIL Sensor
  <raw>1800FF00</raw>
</parameter>
Example 10: Average Sensor
    <name>Уровень топлива (ЭБУ, сред.)</name>
    <unit>liters</unit>
  </description>
</parameter>
Example 11: File with Includes and Global Configuration
<parameters namespace='Mitsubishi_4N15'
            description="Mitsubishi 4N15+AT_V8AWG+TPMS+OBD">
  <header>ATSH7E0; ATCRA7E8; ATFCSH7E0;</header>
  <init-string>
    ATSP6; ATST32; ATAT0; ATSH7E0; ATCRA7E8; ATFCSH7E0; ATFCSD300040; ATFCSM1;
  </init-string>
  <models>Mitsubishi</models>
  <include>mitsubishi_eng_4n15.ecuxml</include>
  <include>mitsubishi_at_v8awg.ecuxml</include>
  <include>mitsubishi_ks_tpms.ecuxml</include>
  <!-- Additional parameters specific to this combination -->
</parameters>
File Organization
ECUXML files in the HOBDrive project are organized by vehicle manufacturer:
ecu/
├── obd2.ecuxml              # Standard extra OBD2 sensors
├── kwp2000.ecuxml           # Common KWP2000 protocol sensors
├── _cuts.ecuxml             # Patch: filter noisy sensor values
├── _gpsspeed.ecuxml         # Patch: use GPS speed instead of ECU
├── _micas_obd2.ecuxml       # Patch: fuel trim for Micas ECUs
├── _vaz_obd2.ecuxml         # Patch: fuel trim for VAZ vehicles
├── _toyotajdmclear.ecuxml   # Patch: JDM MIL clear logic
├── China/                   # Chinese vehicles (Chery, Geely, Haval, etc.)
├── ChryslerDodgeJeep/
├── CitroenPeugeot/
├── FiatLanciaAlfaRomeo/
├── FordMazda/
├── GM/
├── HyundaiKIA/
├── Mercedes/
├── Mitsubishi/
├── Nissan/
├── Opel/
├── Renault/
├── SsangYong/
├── Subaru/
├── Suzuki/
├── Toyota/
├── VAG/
└── VAZ_GAZ_UAZ_ZAZ/
Files with an underscore prefix (_*.ecuxml) are “patch” files that modify or override existing sensors.
Build Pipeline
ECUXML files are processed by the ecuxml2cs build tool:
  1. Parse: All .ecuxml files are parsed by ECUXMLParser into ECUXMLRootElement objects.
  2. Generate sensor providers: Each ECUXML file generates a C# class (via T4 template EcuXmlTemplate.tt) that extends BaseECUXMLSensorProvider. The generated class contains pre-parsed parameter definitions as ECUXMLParameterElement objects.
  3. Generate registry: ECUXMLSensorProviderRegistry.cs — maps .ecuxml filenames to their generated sensor provider classes.
  4. Generate description registry: ECUXMLDescriptionRegistry.cs — stores ECU profile metadata (name, init string, models) for profiles that have <models> defined.
  5. Generate ECU list: A markdown file listing all available ECU profiles.
At runtime, ECUXMLSensorProvider first checks the compiled registry for a matching filename; if not found, it falls back to parsing the ECUXML file directly from disk via FilesECUXMLSensorProvider.
Quick Reference: All Parameter Child Elements
Element Description
<class> C# class name implementing this sensor
<mode> OBD2 mode (hex), default: 1
<command> OBD2 PID (hex)
<address><byte>0xNN</byte></address> Shorthand for mode 1 + PID NN
<raw> Raw hex command string (semicolons → CR)
<header> Per-sensor ELM327 header override
<data-offset> Reply command length override
<base> Reference to base sensor (derived)
<base2> Reference to second base sensor (derived)
<base-raw> Reference to base sensor (raw byte access)
<base-data> Reference to base sensor (data-offset byte access)
<value> / <valuea> Scale factor, byte at offset 0
<valueb> Scale factor, byte at offset 1
<valuec> Scale factor, byte at offset 2
<valued> Scale factor, byte at offset 3
<value-N> Scale factor, byte at offset N
<valueab> Scale factor, big-endian word at offset 0
<valuebc> Scale factor, big-endian word at offset 1
<valuecd> Scale factor, big-endian word at offset 2
<word-N> Scale factor, big-endian word at offset N
<wordle-N> Scale factor, little-endian word at offset N
<dword-N> Scale factor, big-endian dword at offset N
<dwordle-N> Scale factor, little-endian dword at offset N
<signed/> Interpret value as signed integer
<offset> Additive offset applied after scaling
<bit> Right-shift amount for bit extraction
<bit-width> Number of bits to extract (default: 1)
<cut-low> Zero result if below threshold
<cut-high> Zero result if above threshold
<eval> Dynamic expression (overrides scale/offset)
<text/> Mark as text sensor
<dump/> Mark as hex dump sensor
<average/> Mark as averaging sensor
<mil-group> MIL/DTC group identifier
<description> Localized name, description, unit
