Suzuki Jimny M13A engine 2017
ahaghshenas » 03 сен 2018, 19:51
Hello,
OBD dongle : OBDLINK MX
I have read the forum for settings with other Suzuki cars, I have similar issues!
I can only connect to my car with SZ viewer app, with Hobdrive there is an error (bus init error) when connecting.
Settings used
Screens/Settings/Vehicle settings:
- vehicle type - Suzuki_JDM_KWP11
- ELM Init Template - SuzukiKWP
I have attached a trace log file and a btsnoop of SZ viewer
btsnoop_hci.log
logcat.txt
Re: Suzuki Jimny M13A engine 2017
kdika » 03 сен 2018, 20:07
Hello.
You have a new car with a CAN bus
ahaghshenas писал(а):Settings used
Try it like this
- vehicle type - Standard OBD2
- ELM Init Template - select protocol 6
Send me log.txt (logging level trace)
HobDrive(1.5.43_lic)+ZenFone2(5.0)+ElmWiFiUSB+RenMegane3(SID305)
ahaghshenas » 03 сен 2018, 20:23
Thanks for your quick response.
I have attached the files.
I have a different error now, error timeout
logcat.txt
kdika » 03 сен 2018, 20:41
Make changes.
- ELM Init - ATSP6; ATAL; ATSH7E0; ATST32; ATAT0; 1A8A; 1A8E; 1A9A; 1A91; 1A99; 2100; 2101;
the start of the system log is not necessary.
Run auto and run programm.
Send log.txt.
PS. Sensor values may not be correct
ahaghshenas » 03 сен 2018, 21:07
New log file attached
Yes it connected with wrong values.
Thanks
kdika » 03 сен 2018, 21:10
excellent
it takes several days to finalize the protocol
how will the test version be ready - I'll write here
ahaghshenas » 03 сен 2018, 21:13
Thank you for your help.
Look forward to receive the test version
kdika » 11 сен 2018, 19:11
Install demo version 1.5.38: https://drive.google.com/file/d/1oejYpk ... sp=sharing
- vehicle type - Suzuki_JDM_CAN
read/clear dtc work in full version
MartyGek » 26 янв 2019, 05:11
Hi I want 04-05 ZX10R Kawasaki front forks for my Suzuki GSX-R 1100 -94.
Is there anyone which would have done this before?
Thanks
