Hyundai accent 2006 1.4
I have a WiFi OBD elm that no longer able to connect. accurate that until yesterday was fine. of fusion obd goes though. help
- (662.95 КБ) 1815 скачиваний
Re: Hyundai accent 2006 1.4
Please double check your connection settings.
I see your adapters address was 192.168.0.10:35000,
but now you've set it to 192.168.1.10:35000
Also, check vehicle settings and make sure correct vehicle profile selected.
I have already changed the setting to no avail ...... the vehicle is right. Thursday I get obd vgate3 WiFi, I'll see if it works with that. but you know what the weird thing was that the night before, and then I decided to buy the premium version that went well and then one morning just walked no more.
Fabio, as far as I see from logs your adapter is on
192.168.0.10:35000
Address.
Please make sure this address is in settings, then send us log.txt again.
192.168.0.10:35000
Address.
fabiolo1977, install version 1.4.19: https://play.google.com/apps/testing/hobdrive.android
Screens / Settings / System settings / debug logs - Trace
Please try again in connection with the car
Attach files: log.txt, config.xml, user.vehicles
To get 1.4.19 it is necessary to become a beta tester: https://play.google.com/apps/testing/hobdrive.android
You can set 1.4.18.
The main switch on the trace.
Before you all worked fine, and in one day stopped working? I understand you correctly?
You can set 1.4.18.
I was already but does not exist as the 19 by screenshots shoot
While set 1.4.18. After a while (depending on google) you the latest beta version (1.4.19) will be available
PS.Before you all worked fine, and in one day stopped working? I understand you correctly?
yes exactly was once connected with demo then I bought pros and evening for two connections or switching it went. then in the morning he is no longer round.
Fabio, please take the logs as described above with 1.4.18 and send them. Use "report the issue" button.
We already asked you on this multiple times. It seems the issue with vehicle settings or ELM settings. Just double check these.
I come to reiterate that elm and vehicle settings are correct as you can see from the logs. however tomorrow I will send more logs.
Send please 2 log even with these settings.
screens/settings/vehicle settings:
1
-vehicle type- Hyundai G4EE KWP
2
-vehicle type- Hyundai G4EE CAN
1
2
