Hi,
I'd like know what's the reason of different fuel consumption between the 'Fuel Consumed' and 'Fuel in Tank' sensors.
'Fuel Consumed' calculate 32.86 L consumed fuel, the 'Fuel in Tank' does 28.62 L
I use full version of HD 1.1.1
Different consumed fuel calculate between sensors.
Re: Different consumed fuel calculate between sensors.
Papamaci,
"Fuel Consumed" is a total amount of fuel you spent in current trip cycle/period.
"Fuel in tank" is your current estimated amount of fuel you have in tank.
These two are absolutely unrelated parameters.
Cail,
Understood it, but reseted both sensors when load fuel. So current trip is 'Fill Up'.
"Fuel Consumed" : 0L
"Fuel in Tank" 41L (100%)
Subsequently, the differences arise. I think in this case should be the same as measured by the two sensors quantities.
Thank you in advance for your response.
P.M.
Sorry for my english. (Google translate.)
P.M.
